C63 AMG (W204) 2008 - 2015
M156 head bolt problems
Old Oct 7, 2012 | 03:01 AM
  #201
DuaneC63's Avatar
AMG GLC63. Audi R8
Originally Posted by morganb
A hopefully second last update on my car. Will let you all know details of the moter rebuild sheet when I get it. A small issue before I got the car back was a broken engine mount. This was replaced before I got the car back.
I got the car back on Friday. First Cold Start this AM
All seems to work well but currently running in phase so hard to tell performance wise. Thanks to MB for covering the majority of the rebuild cost. My cost came in under what I offered (5K) and I ended up with new plugs (which were due), a service completed and 12 months warranty on an almost fully rebuilt engine. Its wrong to say I am happy (as my car had this issue) but so far satisfied with the way it was handled other than the timing (22 weeks) to get the car back.
Thanks to all those who commented and supported through this. Happy Motoring!
Morgan,
Glad to hear you got your car back especially with a new motor.
Old Oct 7, 2012 | 03:02 AM
  #202
DuaneC63's Avatar
AMG GLC63. Audi R8
Originally Posted by mgbrillo
given that morganb's case is outside of US, can this (still) be used as precedence for future complaints/cases/disputes with MB/dealers?
Unless you're going to the World Court, my guess is not.
Old Oct 14, 2012 | 09:45 AM
  #203
Merc63's Avatar
C63 AMG
Has anyone totalled up the number of head bolt failures we've seen on mbworld?
Old Oct 14, 2012 | 02:40 PM
  #204
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
I'd like to see those numbers too.
Old Oct 15, 2012 | 02:14 AM
  #205
bhamg's Avatar
C63 AMG
Eventually I'll try to search all the forums here but it'll be some time before that happens. I have been told that the rate of head bolt failure is higher on the non-C AMG models (the higher output engines) and those would be probably underreorted on a % basis on MB World.
Old Oct 15, 2012 | 02:17 AM
  #206
Interesting.
Old Oct 16, 2012 | 01:16 AM
  #207
DuaneC63's Avatar
AMG GLC63. Audi R8
Originally Posted by sjhugh
Normal wear and tear, failure from age and misuse is the owner’s problem.
It’s the manufacturer’s problem is when the part is known to fail and has undergone a running change during the MY2010 build cycle to rectify the possibility of further issues.
I see your reasoning and for 5k I would have most likely done the same.
That is why they win. If they were not responsible, you’d have gotten nothing.
The cost to pursue this matter as an individual would greatly exceed $5,000 with no guarantee of a successful outcome. MBZ has more money than most individuals and the ramifications of losing for MBZ are very great. MBZ is currently fighting a class action in US court on this issue and the plaintiff is not getting much traction (pun intended). While I agree that MBZ is in the wrong on this issue, proving it in court is a very difficult and expensive battle.
Morgan, I think you ended up with a good result. You got a new motor (not a rebuild or retrofit) for $5,000. I'd take that any time over going to court.
Old Oct 16, 2012 | 01:44 AM
  #208
BerBer63's Avatar
2009 C63
i've had my coolant light come on twice this week.
1st time I was parked on my driveway (steep part) and light came on.
2nd time was on start up in my garage just 1 week after the 1st time.
In between those 2 coolant lights, I changed my oil/filter. Oil looked fine no milky or cloudy fluid. I've also been checking my coolant reservoir for the last 2 months since hearing about all these failures and the level really hasn't moved. It's about 1 inch below the black part (so 1 inch of white showing in the tank).
No white smoke, no driving issues. Was maybe going to top it up, we will see. 37, 000 miles. I could take it in for documentation and get it on file but I have mods.
Old Oct 16, 2012 | 04:04 PM
  #209
DuaneC63's Avatar
AMG GLC63. Audi R8
Unless you parked upside down, the low coolant light should not come on. I'd check for a hose leak, but you could have a head bolt failure. What mods do you have? I'd get the car back to stock engine wise and take it in soon. If it hydro locks you're looking at a new motor.
Old Oct 17, 2012 | 02:19 AM
  #210
DuaneC63's Avatar
AMG GLC63. Audi R8
Originally Posted by Mattie492
We also need to compile mileage statistics at time of failure.
Unfortunately all the forum can accumulate is imperfect data due to the small and selective sample size. Only MBZ knows the full extent of the problem and they are not about to make these public unless compelled to by DOT/EPA etc or through the discovery process of a lawsuit which is cost prohibitive. Most SA will even deny there is a service bulletin on this issue.
Old Oct 23, 2012 | 04:01 PM
  #211
Dogtag114's Avatar
2009 c63
Originally Posted by Valvestud
The affected engines are any engine serial number leass than 569xx 60 060658.
2012s are not affected.
Regards,
Joe
ok... so maybe I'm a litle slow, but is 56985 "less than" 569xx 60 060658.
My engine is 156985 60 043109
...or is it the 043109<060658 that gets me into trouble?
Thx.
Old Oct 23, 2012 | 04:08 PM
  #212
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Thx.
Your engine is in the affected group. It's the last sequential digits that are where you need to look. 043109 is lower than 060658.
Regards,
Old Nov 21, 2012 | 06:22 PM
  #213
LKTB_E63's Avatar
2015 GL450
Hello everyone...I've been following this topic fr a while as I'm in the market for a 2007-2009 e63. I have a hypothetical question regarding cars that are still under warranty and I'm not sure I'm explaining this correctly, but here goes...
Is there anything an owner could do to his car to force the dealer to perform the head bolt/gasket change under warranty before the problem actually occurs? Ie repeatedly remove coolant or loosen some screw? I'm not suggesting people should do this, but wondering if there is anyway to get the dealer to perform this work under warranty.
Just my two cents...thanks
Lktb
Old Nov 21, 2012 | 10:46 PM
  #214
jordanaf's Avatar
507 SEDAN
So, generally speaking, it's the last 6 digits to go by??
And where are they found, prey tell?
Old Nov 21, 2012 | 11:49 PM
  #215
morganb's Avatar
C63 AMG, C36 AMG, SL500
Lktb
I would think removing coolant a few times would force them to remove heads to check. Once Open they would need to put in the new head bolts. Not suggesting anyone does this as running with low coolant may cause its own problems and it is dishonest.
Bruce
Old Nov 21, 2012 | 11:59 PM
  #216
Bruce
I think the dishonesty in this case would cancel out MB's neglect on this issue.
Old Nov 22, 2012 | 03:43 AM
  #217
jordanaf's Avatar
507 SEDAN
Where are you guys pulling these numbers from??
Old Nov 22, 2012 | 08:33 AM
  #218
Mort's Avatar
If you have had any dealer service it may be printed on you Repair Order. That is where I found mine. If not phone the dealer and get them to pull up the info on your car. Mine is a '10 as well and has the old style head bolts. My build month was April 2010 and my engine is 1500 or so below the changeover.
Old Nov 22, 2012 | 01:33 PM
  #219
Sincity's Avatar
Good point.
Old Nov 22, 2012 | 04:13 PM
  #220
Pickles's Avatar
(a)'12 C63 P/P, LSD, 19" m/spoke,comfort pack. (b)Astra SRI.
Question
There's been all sorts of talk about the Class Action/Court Case relative to this issue, but I've never read any concrete specific details about this case.
I'm not interested in any, "general", "suppositions", "opinions", etc etc.....but if anyone knows the REAL situation with respect to this "Case", & where it is currently at....and like I said, REAL facts,.....I'd be interested in learning those "FACTS".
Cheers, Pickles.
Old Nov 22, 2012 | 06:14 PM
  #221
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
I have a 09 C63 with 27K+ miles. I keep a eye on the coolant level. So far the level stays full. Its been like this for 3 years. Seems it doesnt use any. My Clk55 with 72k miles uses a little coolant.
Old Nov 25, 2012 | 01:43 PM
  #222
SonnyakaPig's Avatar
MB
Cheers, Pickles.
I don't believe there is any known litigation involving the head bolt issue.
The class action involves internal engine parts made with incompatible metal.
Old Nov 28, 2012 | 10:16 PM
  #223
bhamg's Avatar
C63 AMG
Some thread catchup.
Originally Posted by rockdizzle
if i tune my car am i making the chances worse?
Originally Posted by DuaneC63
You're making the chances worse that MBZ will deny your warranty claim.
This is JMO, nothing more and totally unsubtantiated with any facts. Based on some conversations with a couple of people who work for M-B about the relative frequency of failure across the output range of the M156, I'd guess it increases the chances of head bolt failure...slightly to moderately. Now, is there a meaningful difference between a 2% or a 3% chance of failure (bearing in mind the latter figure is 50% greater than the former)...the answer for me is "no." A tune will raise cylinder pressures, and with potentially defective head bolts increased cylinder pressure is never a good thing. What's the pressure increase? My guess is a minimum of 10% with a tune. That's one reason why chasing the last few HP with a tune just to put up a number while not a fool's game has never made sense to me.
I am a realistic thinking guy and this post has a ton of common sense in it. Not that the engines shouldn't be able to handle the extra HP, but with the head bolt issue, it will be exacerbate the issue...it just has to do with natural physics...
Agree that a tune that pushes the limits (too much advance etc) will cause all kinds of problems including exacerbating the potential for a head bolt issue. Remember these engines were detuned by the factory for marketing reasons, not engineering reasons. It's rare to find a NA engine that gets up to or over 50HP from just a tune. The real issue with any tune is that it voids your warranty and it may not have caused the head bolt failure to begin with.
Originally Posted by 02Drunkenup
so is anybody having a bolt replacement done on their own terms? as in having the new bolts or weistec heads put in without any failure or symptoms?
I really want to get into an 08 to keep the next 4-ish years stock but this is really pushing me away to alternatives.. but I guess i can always just have it done down the road
I thlnk that ACG Automotive in San Diego has done a few with weistec head studs. If you're not going to mod the car, you might as well wait to see if it fails (just make sure you are alert to the symptoms before you hydrolock the motor), then complain to MBZ who seems too be willing to work out cost sharing in some cases. Don't let them hit you with their insulting "assesment charge" if you decide not to have them do the work.
Old Nov 28, 2012 | 10:17 PM
  #224
bhamg's Avatar
C63 AMG
Here's an interesting treatise I bookmarked some time ago. It's well worth reading about the engineering that went into the M156 motor. I recently went back to it and there's an interesting addendum (which I won't quote beyond the opening).
http://www.marcusfitzhugh.com/CLK/63.html
2012 Addendum: Time is beginning to reveal a few secrets . . . . . . . .
Early M156s have serious top end issues. Early as in through engine number #60658 (those are the last five digits of the engine number and this issue impacts all 63 engines through the early 2010 vehicles). "Issues" as in plural.
Old Nov 28, 2012 | 10:29 PM
  #225
Thanks for summarizing the new comments. And that article is super fascinating!
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
