C63 AMG (W204) 2008 - 2015
Facelift LED lights... how to run as DRL?
Old Jul 4, 2013 | 03:36 PM
Vise_'s Avatar
2013 C63 AMG, 2013 B250
Hoping someone can help answer a question, wondering if there is any coding etc available that allows you to run the LED 'angel eye' or whatever it is called (circled in pic below) as a DRL when in auto light mode. I've tried searching the forum but not really seeing an answer, I know you can enable them as parking lights but my thought is to run them similar to the angel eyes on a BMW as DRLs. Any ideas? Apologies if I'm completely clueless on a way to do this now...
Old Jul 4, 2013 | 03:41 PM
manuel009's Avatar
G 65 AMG
i'm in to. i'd like to have this on with the lower led on.
Old Jul 4, 2013 | 05:49 PM
shades's Avatar
09 C63, 11 Cayenne S
You need the Mercedes software to change that I believe. Here in Canada they are set so you can't change them unless you have the merc scanner.
Old Jul 4, 2013 | 07:02 PM
keiphers's Avatar
2016 C63S
That's generally true for most things on OBDII cars, even the OEM illuminated doorsills. However, is this actually something that can be turned on (e.g., on my Range Rover Sport, there is no possible way to turn on the OEM "angel eyes")?
The C63 is at Mercedes getting some custom paint work and the illuminated sills - I'll ask the dealer tomorrow if they can turn on those lights as DRLs.
Old Jul 4, 2013 | 08:24 PM
Vise_'s Avatar
Yeah that is my point, hoping there is a vendor out there doing coding for our cars that can enable this. In the BMW scene there are tons of guys doing remote coding for all sorts of feature/function changes, hoping something similar for MB.
Not worth asking, the dealer won't be any help I'm sure.
Old Jul 4, 2013 | 10:39 PM
keiphers's Avatar
2016 C63S
I actually have a pretty good relationship with the tech and body shop guys because I ask questions and want things that no one else does, so I'll give it a shot!
Old Jul 4, 2013 | 10:50 PM
Vise_'s Avatar
Cool man, let us know how it goes. I just don't see them helping you modify your car from the stock setup, particularly given it will likely require some custom programming.
Did you get the illuminated doorsills from the dealer as well or are they just handling the installation?
Old Jul 5, 2013 | 12:39 AM
TUF-C63's Avatar
C63
I would love to know this as well!!
Old Jul 5, 2013 | 07:49 AM
austinauflick's Avatar
Veteran: Navy
'14 C63 "Edition 507"; '02 Widebody WS6 Trans Am ~ 1,200hp (kills everything)
Sub'd
Old Jul 5, 2013 | 09:43 AM
Vise_'s Avatar
Seriously I can't be the first person that thought of this?
Any forum vendors have input? Clearly there is a market here...
Old Jul 5, 2013 | 10:26 AM
keiphers's Avatar
2016 C63S
Yes, the parts department ordered them for me - they are special order from Germany. Unfortunately, the car is apparently NOT pre-wired for them, making this quite an expensive mod for the benefit. Due to the parts being special order, they cannot be returned. They have to be wired back to the trunk then a setting enabled in the computer.
This is a long-shot, but check out the engineering menu (see below).
Originally Posted by shimmers
Hi All, I'm sure many of you are aware of the Engineering Menu in the W204 C-Class by holding telephone off / # / 1 buttons together. I have also used this to install the backup camera and will also install a retrofit navigation unit soon.
Someone could also try the following, which I found in another thread here: http://www.takingthingsapart.org/ind...d=68&Itemid=88. An email to these guys might be helpful: http://www.benzline.com.sg/index.html. I found a Singapore-based Benz forum, and Benzline seemed to be the go-to company for re-programming the computer to handle retrofitted projector headlights.
Old Jul 5, 2013 | 08:44 PM
keiphers's Avatar
2016 C63S
Okay, so I spoke with the tech who was working on my car. There is not an obvious on/off setting in the menus that he knows how to access, but he said that's not to say it can't be done.
My guess it that because it's not actually used as a DRL in any country, it would likely have to be a deeper programming option to tie it to the lower LED lights.
Old Jul 5, 2013 | 09:00 PM
shades's Avatar
I have a buddy who told me you can use most of the lights as DRL as long as you specify, with the software. He use to work for some import company. He did all the DRL lights for different car manufacturers, entering Canada. Here in Canada it's the law to have DRL. I have a friend who has texza software which he believes can do it but I'm a little apprehensive.
Old Jul 5, 2013 | 09:31 PM
keiphers's Avatar
2016 C63S
Each car's system is a little different, and the intended DRL's required in Canada and other countries actually come programmed with an on/off setting normally.
Here, the system would have to be tweaked a little to tie the headlight LED setup to the lower LEDs when the motor is running, because the only existing link is when the car is locked and unlocked... Someone should try emailing Benzline or using the GUI programmer though. You can't really mess something up just by taking a look.
Old Aug 11, 2013 | 11:35 PM
Veteran: Navy
Anything come of this?
Old Aug 12, 2013 | 03:50 AM
neoprufrok's Avatar
I'm curious as well.
Old Aug 12, 2013 | 10:50 AM
ed4's Avatar
ed4
2010 Audi S4, 2013 MB C63
+1
Tagging along to see if it can be done by software, modifying a relay or a simple rewire.
Old Aug 12, 2013 | 11:45 AM
ParkerK's Avatar
C63 507, 911 Carrera, Range Rover, Disco
I thought I saw a couple of 507 videos with just these lights on...maybe euro versions?
The easiest mod would be to tie in the current DRLs to this circuit and tag along on all of the software programming.
Old Aug 12, 2013 | 12:35 PM
2012C63AMG's Avatar
2012 C63 AMG
If you move the light selector from auto to either left or right it puts the bottom LED running strip on also along with the side lights and the lights you want on.
I have my side markers painted so only the bottom LED and the light you want on is shows on my car.
I realize its annoying to swap between light settings,but I wonder if I disable DRL if it would just put on the lights you want without the bottom led strip..
Does it work that way up in canada eh?
Old Sep 12, 2013 | 11:54 AM
SwedeC63's Avatar
'12 C63 Coupe - P31 - LSD - Eurocharged
Been curious about this for a long time too? Wish some techie would roll up his/her sleeves and get it done... makes the car look so mean!!
Old Sep 12, 2013 | 04:38 PM
rage2's Avatar
C63 BS, GLA45
It's used as DRL for the C63 Black Series in Canada.
It should turn on for the BS if you enable DRL on US cars under the lighting menu? At least that's what MB Canada told me.
Old Sep 12, 2013 | 10:20 PM
Mr Jones's Avatar
2013 C63 PP
Curious.
Old Dec 24, 2013 | 05:54 PM
Aresh's Avatar
C63
anyone figure this out
Old Mar 2, 2014 | 10:34 PM
SwedeC63's Avatar
Exclamation
Still nothing on this?
Everytime I shut the car off, it keeps them both on for a few seconds and it bothers me it can't stay that way.. looks bada$$.
Someone please figure this out soon.
Old Nov 15, 2014 | 10:59 AM
lemonstand's Avatar
2014 C63 507 Edition Sedan - Mars Red
Any updates to this?
