Prefacelift Single Fin Grill from 55Tech
Overall the grill is of good quality, the margins on the sides, top and bottom are on point with that of the stock grill. Install took a time consuming 5 minutes from opening the box to getting it on. The only things that I noted are that the web part of the 55 Tech grill is a gloss finish while the stock grill is a matte, and that the this has a slightly more plastic feel that is not quite as pliable as the stock grill. However, with everything on the table, for $229 shipped, it is the answer to alot of prayers for a single fin grill that is affordable and no modification required. Would not hesitate to buy it again. Enjoy the crappy cell pics
As a note to those who have not removed their grill before: the two pins that hold the top portion of the grill on, use a pair of plyers and just grab the top of them and pull straight up. They are a two part pin, this removes the inner part so you can remove the threaded part. After this, press in from the bottom until the taps pop loose and then lift up.
Coupon Code: FREEUSA = free shipping
And the star emblems looks huge.. Is it the same size as oem? Thx for taking the time to share & update.
Is there one in matte black? Any link from where you purchased it?
Thanks for the info!
Sorry I dont see the black one but they have one for the standard c class so i would check back later.
$300AU Landed here. (same as OP)
http://www.ebay.com.au/itm/171234311...84.m1438.l2649
Black Version of the above. Sold in AUS- $300AU free ship
I've found the same grill on ebay for $60 cheaper and the seller has 55tech logo as display picture...
To the OP; are you able to post point by point installation instructions please? It would be much appreciated. Also, better pictures when you get a chance. Thank!
The OEM facelift star is bigger than the pre-facelift star.
The 55tech single fin grill star's proportions appear to be the same as the OEM facelift star.
