C63 AMG (W204) 2008 - 2015
KW Suspension - Steering Noise (video)
Old Dec 23, 2015 | 01:10 AM
cjoy63's Avatar
08 C63 P30
Hi All,
Hoping someone can help me pin point the steering noise that started happening after installing KW V3's on my 2008 C63. Not 100% sure if the V3's are to blame, but it's really the only change point before the noise started. Prior to the V3's, I was sitting on H&R springs for a good year with no problem. Only other mods are MBH headers.
Key things to note:
Noise is not as noticeable from a cold start, but gets louder as more miles are driven
I think it also gets louder when nearing max steering lock, left or right
It is not the spring binding on the perch
If anyone has any clue, please let me know, thanks!
Old Dec 23, 2015 | 02:15 AM
oggie's Avatar
2011 E550 4Matic & 2010 Audi Q5 & 2015 C63 507
Sounded to me some bolts aren't tightened properly after the install. Have you checked all bolts in the front end. When the car is parked, the headers wouldn't be making noise. Perhaps go back to your installer to ask them.
Old Dec 23, 2015 | 02:33 AM
AMG3.2's Avatar
C63 AMG, P30
First of all, I'd check to make sure the strut mount and bearing were assembled correctly. After that, I'd double check to make sure the top nut is torqued to spec.
Old Dec 23, 2015 | 05:11 AM
ahgli's Avatar
Porsche 911 s | 2012 c63 coupe | 2013 Bmw 328xdrive
I had the same noise come out of my bmw a few years ago, it ended up being the stabilizer link
Old Dec 23, 2015 | 08:27 AM
Mort's Avatar
I agree with AMG3.2, I think it is the top plate. The bearing is noisy or the strut is not torqued properly to the top plate.
Old Dec 23, 2015 | 05:48 PM
cjoy63's Avatar
08 C63 P30
@oggie: I actually had the shop uninstall and re-install the front right damper just to check if anything was out. Noise was still there before and after.
@AMG3.2, @Mort: Everything was checked again during the re-install, don't think it's the issue. I guess I should check the torque myself to be sure. Installed did say he checked the top strut mount and didn't find anything unusual with it.
@ahgli: I haven't checked out the stablizer link, will look into it.
I'll try and see if the sound is coming up more on the top of the damper or the bottom. If coming from the top, there is only the top plate and strut mount/bolt to check. But if coming from the bottom, I think it might be a suspension joint.
Old Dec 24, 2015 | 12:05 AM
cjoy63's Avatar
08 C63 P30
Hmm, I just realized that the dealership replaced the front right sway bar end link on my last oil change, which was 1k miles before I put the kw's on. The service noted that the end link was torn. Coincidence?
Old Dec 24, 2015 | 12:06 AM
cjoy63's Avatar
08 C63 P30
Is it okay to remove the sway bar end link only? I want to remove it and see if the noise goes away when I turn the steering wheel.
Old Dec 24, 2015 | 03:16 AM
ahgli's Avatar
its okay to remove, as long as you don't drive it.
Old Dec 24, 2015 | 03:20 AM
AMG3.2's Avatar
C63 AMG, P30
Yes, remove one sway bar end link to relieve the pressure and see what that does.
Old Dec 24, 2015 | 02:18 PM
cjoy63's Avatar
08 C63 P30
So I took a look underneath the car today. I was not successful in removing the stabilizer bar. After removing the nut on the damper, the stabilizer bar does not remove easily. I think you have to wiggle it out when the damper is loose and didn't feel like taking on that project today.
Something interesting I found today is the location of the stabilizer bar. There are two available holes you can attach the stabilizer bar to, and I think where I have it is wrong. Compare my photo to the KW's instruction photo. I have the stabilizer bar away from the brake caliper where KW's instruction photo is on the side closest to the caliper. Maybe this is it?
Old Dec 24, 2015 | 03:46 PM
ahgli's Avatar
That's most likely your problem right there, to relieve stress from the link I usually use a small jack (placed under the brake rotor with a piece of wood) and raise it a little, this will make taking the link out a lot easier, if it's still tight you can slowly bang it out with a rubber hammer.
Hope this helps.
Old Dec 25, 2015 | 01:22 AM
cjoy63's Avatar
08 C63 P30
I did jack up the wheel a little, but maybe not enough. I'm thinking though that I would need to fix the other side too since both stabilizer bars connect to the same sway bar. In other words, if I get the stabilizer bar loose, it won't reach the correct location because it is fixed onto the sway bar, which is fixed by the opposite stabilizer bar.
What I don't get is why it makes the sound on one side only, and only when cold. Weird.
Old Dec 25, 2015 | 09:15 AM
ahgli's Avatar
Probably because they only changed one end link at the dealer, its good to do those things in pairs. its either the old on has gone bad or the new one is faulty.
Old Dec 25, 2015 | 11:20 AM
AMG3.2's Avatar
C63 AMG, P30
You need to have both wheels up in the air to remove the end link otherwise you'll run into this issue.
Old Dec 25, 2015 | 11:48 AM
Wobble64's Avatar
C63 507 with BS Body; 2008 SLK 55
According to the pictures, there is more not right. The front struts need to be installed with the reservoir towards the back (they are handed). That seems to be correct. The KW picture (right picture) then shows the stabilizer link is attached to the rear attachment point and goes straight down. The left picture (from your install?) shows the stabilizer link installed in the front attachment point and it is not parallel to the strut. It goes down and is angled to the front.
Is it possible that the stabilizer bar is flipped and points forward instead of back? Maybe the stabilizer bar needs to be turned to point back and the stabilizer links then attached to the rear attachment points.
Old Dec 25, 2015 | 12:06 PM
AMG3.2's Avatar
C63 AMG, P30
Oh,good catch! I don't think the sway bar is in backwards or anything, I just think the installer installed the end link in the wrong hole. It should definitely be in the hole closest to the passenger as opposed to closer to the engine (where it is now).
Fix that and report back.
Old Dec 25, 2015 | 02:04 PM
Wobble64's Avatar
You are correct, the sway bar cannot be turned, it only fits one way.
I just looked at the setup on my car and checked both the KW setup and stock. The links need to be in the rear attachment point of the strut and point straight down, parallel to the strut, to reach the sway bar.
The attachment points in the KW struts are lower than stock, and hence the links are shorter.
Old Dec 29, 2015 | 04:43 PM
cjoy63's Avatar
08 C63 P30
I haven't gotten a chance to work on the car or bring it to the shop (mainly due to the holidays), however I did contact KW regarding this issue. There response is below:
"Yes I see that we have the link mounted on the opposite side in the install guide compared to yours, honestly I cannot ensure this will remedy the issue. However I would say at this point try it, switch them and see what you got. "
I wasn't looking to confirm if it will fix the sound, but more to know what stabilizer link position is correct per design. This response came from a technical advisor.
Old Dec 29, 2015 | 09:38 PM
Wobble64's Avatar
I just got KW Clubsport coilovers installed (with camber adjusting topmounts). Love them car is very tight, no body roll worth speaking off, no noise. Car runs straight with no pulling either right or left.
The swaybar links are in the rear position (reservoir side) of the shock absorbers.
Old Dec 29, 2015 | 10:29 PM
oggie's Avatar
Wobble, did you need adjustment bolts for your KW install to bring alignment back within specs?
Old Dec 30, 2015 | 10:04 AM
Wobble64's Avatar
I did not want it in OEM spec - I now have a little over 3 degrees of negative camber in front and a little over 2 degrees in the rear.
In front I would have been able to adjust to even way more camber (up to 6 degrees). The rear is not adjustable without special bushings. However, what I have suits me fine for my purpose (spirited driving and tracking). The car is now pretty low
Attached Thumbnails KW Suspension - Steering Noise (video)-2015-12-29-17.31.35.jpg   KW Suspension - Steering Noise (video)-2015-12-29-17.31.45.jpg   KW Suspension - Steering Noise (video)-2015-12-29-17.37.26.jpg
Old Jan 9, 2016 | 03:01 AM
cjoy63's Avatar
08 C63 P30
All, some updates:
KW got back to me and confirmed with their development team that the correct position for the stabilizer bar is the rear position on the damper.
Brought car back to original installer. They found the source of the noise. The V3's I got came with 2 left side stabilizer bars. They are side specific. However, the shop thought it was correct to install it in the front position on the damper because it is the only way it would fit. When we removed the stabilizer bar, it was twisted. Being on the wrong side really maxed out the bushings normal range of travel to the point of damaging it.
We got a hold of KW for a replacement part, the correct right side stabilizer bar. At first the eta was 4-5 weeks, given that it was special order and coming all the way from Germany. After escalating to KW, they were able to overnight the part and should arrive Monday.
In summary, although it was not the cause of the noise, the correct position of the stabilizer is on the rear. However, if we had paid closer attention to the install photos, we could've discovered the problem much earlier.
Old Jan 9, 2016 | 03:46 PM
Wobble64's Avatar
Glad it all fell into place! Yes, I also noticed on my Clubsport set that the stabilizer links were handed. I even think mine were labeled left/right.
Sorry this did cost you time. They owe you free lifetime stabilizer link replacements, :-)
Old Jan 9, 2016 | 07:30 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
The question I have is, did your V3 kit come with two left stabilizer links from the factory, or what? Someone owes you something for that screw-up...
