C63 AMG (W204) 2008 - 2015
Anyone using a Braille or lighter-than-oem battery?
Old Sep 19, 2016 | 01:44 PM
c63er's Avatar
09 C63 AMG
I was looking at the "weight" thread and the weight savings from running a smaller, like a Braille B2015, battery are not negligible. I live in California so it never gets really cold here. What are the disadvantages of running such a smaller battery? I am trying to shave off some weight from the car and between the battery, spare tire, and going with 2-pc rotors the savings are very reasonable without really affecting the comfort of the car. I might also switch to a CF hood.
Old Sep 19, 2016 | 02:22 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Braille B2015 = 425CCA. I don't even think that would turn the motor over lol.
IIRC 850CCA is OEM.
Old Sep 19, 2016 | 02:32 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
https://mbworld.org/forums/w211-amg/...5-battery.html
Old Sep 19, 2016 | 02:42 PM
deadlyvt's Avatar
2010 C63 AMG
I use the deka 15lb battery (I believe the same as the one you are looking at asthey manufacture the Braille)
works fine I would suggest keeping a trickle charger on it if you don't drive it often and if you do a lot of short trips to use power using accessories sparingly otherwise it works perfect
Old Sep 19, 2016 | 03:35 PM
mthis's Avatar
Anything W/4Wheels
I used it before. Just dont leave anything on and you will be ok. If your worried about it use the 17lbs .
Old Sep 19, 2016 | 03:54 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Is it actually 425CCA? It fires the b¡tch over ok?
I remember when my battery was on its last legs. It was only putting out 600CCA and it would turn over slowly.
Old Sep 19, 2016 | 04:40 PM
ritalin's Avatar
07 Z06, 2011 c63pp
I am using a braille b3121 21lbs battery for track days. I used it for a couple of weeks this summer and with my short duration drives to work it would not keep up. Had to boost it after 2 weeks daily use. I leave it on a trickle charger and when i go to the drag strip i put it in for the day. No issues that way.
Old Sep 19, 2016 | 05:41 PM
deadlyvt's Avatar
2010 C63 AMG
mine fires up almost instantly and have had it for over a year...only times I've had problems was with driving short distances to get fuel and then to a store or car wash while using accessories otherwise flawless
Old Sep 19, 2016 | 06:15 PM
marioflex's Avatar
c63 AMG
I have the Braille and it don't last too long. In my case maybe the two pumps for the ice tank demand too much, but I need to charge it during events.
Old Sep 19, 2016 | 06:47 PM
mr747's Avatar
c63
this is my version 850 CCA every day use 3 kgs
Attached Thumbnails Anyone using a Braille or lighter-than-oem battery?-battary.jpg
Old Sep 19, 2016 | 06:58 PM
ritalin's Avatar
07 Z06, 2011 c63pp
That is sweet. Lithium gives you the best of both worlds. Lightweight and powerful.
Old Sep 19, 2016 | 07:00 PM
mr747's Avatar
c63
It works great mate
Old Sep 19, 2016 | 08:18 PM
deadlyvt's Avatar
2010 C63 AMG
It works great mate
im probably going to go lithium too next spring....
what battery is that ?
Old Sep 19, 2016 | 08:24 PM
mr747's Avatar
c63
http://www.lithiumax.com.au/
Old Sep 19, 2016 | 11:49 PM
gzim335's Avatar
c63 coupe p31weistec stg3 SOLD,2013 C63 BLACK SERIES.
Voltphreaks 7lb,you can dd with it no problem
Attached Thumbnails Anyone using a Braille or lighter-than-oem battery?-img_0032.jpg
Old Sep 30, 2019 | 08:45 PM
Marth Leon's Avatar
2013 c63 amg coupe p31
Where can on find this battery
Old Oct 1, 2019 | 02:59 AM
bradsm87's Avatar
W204 C63 Wagon
I'll give you a hint. Scroll up two posts
