Will H&R coilovers fit on a 2012 Coupe?
I know I've seen a few brief mentions in the various coilover threads saying that the H&R coilovers will work on a 2012 C63 AMG coupe even though every place online (Including H&R's website) says they only fit the sedan.
Will it for sure fit on the coupe and work as intended with no issues? I want to be sure before buying and get a definitive answer either way.
Yes, they should work. All PFL, FL suspension is the same except the Black Series.
The coupe and sedan are the same physical design except the valving difference due to weight but even then its a not noticeable.
https://mbworld.org/forums/c63-amg-w...ml#post6021046
Shoot ECS a message and verify this wasn't just a generic answer. OR maybe email H&R?
Confusion still abounds.
Wonder if anyone who actually has a coupe in this forum has actually installed them and could chime in...
ECS tuning is reputable.
They Fit. My first set was sold to a guy who put them on in 14 coupe.
Pretty sure BLKROKT has H&R coilovers on his coupe and is swapping to clubsports soon. But I could be wrong.
I think it has something to do with springs rates being slightly different between coupe/sedan. The way I see it, they (manufacturers/distributors) are just being safe so that if there is a failure they can't be blamed as they said they don't fit / they don't recommend it.
I'd believe Kriston here. And a handful of other members who really dive into suspension. They'll bolt up, and work, just be slightly out of recommended spec.
Received 2,848 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
What is your intended us and how much track time are you thinking, if any? If you're only looking to lower the car you should go with just springs. If you're going for spirited canyon runs and track days then coilovers make sense.
So - less about function more about form.
That being said I like the ability to be able to adjust the height to get it right where I want it which is why I was looking at these coilovers vs just springs. The cost of these were attractive too vs say something more expensive like the K&W v3...
