Used Transmission Valve Body
I'd imagine it's about the same in USD perhaps? Maybe $1400USD all in if you replace all 8. Less if you only replace the failing ones.
Car shifts perfectly now into 2nd and 1st in sport mods and comfort. Only has the occasional random harder downshift, but nowhere near as bas as it was before and still not terribly bad. Manual mode is still horrid esp on the shift down into first. Apparently it's a characteristic of the tranny mode. Who knows. I hardly use it anyway tbh.
Yeah 2nd to 1st was pretty bad and 3rd to 2nd wasn't great either. It's as smooth as MB intended now. Going down into first at very low speeds (less than 10mph) in manual still is a bit to harsh for my liking but apparently 'they're all like that'.
On my car, I think the solenoids were replaced only.
You cannot install a used valve body, these require online SCN programming at the dealer to be done properly. If you get a used one you will likely not even be able to use it and even if you find someone to hack up the programming you will probably still run into issues and end up at the dealer. These are also security released parts and cannot be purchased over the counter your dealer will likely charge you around 6 hours @ 175 per hour plus the part and a trans service.
