C63 AMG (W204) 2008 - 2015
Critique my 1/4 mile run
Old Aug 24, 2017 | 08:57 PM
Adam Chambers's Avatar
2014 C63 Sedan (SOLD), 2011 SLS Gullwing (SOLD), 2009 SLK55 (SOLD), 2015 C7 Z06 7MT, 2016 C450amg
Went to the strip last weekend. It was hot and humid, low 90's and around 80% humidity. 2014 sedan, deleted secondary cats, deleted carbon filter, Eurocharged V6 tune. Best I could do was a 12.327@114.45. This was at rockingham dragway in NC. Almost all my runs were done using race start, had some tire spin off the line but not a huge amount. Track was pretty sticky and well prepped. I noticed I got my better 60' times with the AC on (kept forgetting to turn it off). These runs were on Continental DWS06 265/35/18 at spec air pressure. I plan on going back sept 9th and hoping for some cooler weather. Should I lower my tire pressures? What have y'all found the best way to launch? I tried just using S+ mode but definitely didn't get off the line as quickly and with the MCT I had trouble holding the brake while trying to pull the RPM up. Race Start seemed to be the way to go for me. Any tips would be great, want to get into the 11's which I thought I would be at with my setup.
Attached Thumbnails Critique my 1/4 mile run-photo810.jpg
Old Aug 24, 2017 | 09:12 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Race Start is junk. Plenty of threads on brake boosting.
Rear tire pressure way too high (24psi)
Turn off AC
Put trans in M and shift 500rpm before redline in each gear
MPH too low for 11's
Old Aug 24, 2017 | 09:15 PM
In M should I run in Sport, Traction Off, or Dyno mode? For the posted run, AC was off.
Old Aug 24, 2017 | 09:17 PM
CarHopper's Avatar
E63S | X5
Second that race start isn't the way to best times. Manual mode, brake boosting, and pedal control is the name of the game.
Practice. lots of it.
Also -- If you want better times a second set of rear wheels / tires and DR's will help as well depending on how often you want to go.
Traction off
Old Aug 24, 2017 | 10:02 PM
BLKROKT's Avatar
Traction on SPORT. If you turn it off you're just going to spin off the line.
Drag radials are a waste of time until you have much more power. You can't get up on them at your power level. Hot sticky and dry street tires are fine.
Old Aug 24, 2017 | 10:29 PM
Infiniti's Avatar
a unicorn tuned p30 e63
Looks like you need some boostane, intake spacers and a v7 tune.
Jokes aside these mct cars are hard to launch, i tried launhing my bros 507 on DR and after the third try i got pissed off and left. However BLKROKT has been kind enough to explain the correct way to drag the car.
"24psi in the rear, 55psi in front. Avoid the water and do a huge burnout and hold it for 5-10sec once your up on it in gear. The launch is the trickiest part, and you have to powerbrake it just for literally a second then go. Don't time the light, who gives a sht about that. Stage, powerbrake when the first light comes down while mashing the gas, and release the brake after just a second you should launch at around 3k rpm. Sport traction with trans in manual, shift 500rpm before redline. You can do 1.7 60' on street tires. Drag radials are a waste of time unless you have more power IMO"
Can't get any better than that.
Old Sep 10, 2017 | 10:15 AM
Went back
Back to the track last night. Cooler temps, new V7 tune and lowering the rear tire pressure to 30psi. Impossible to hook tonight but managed a 11.98@118mph. My goal going out there was an 11.99999 and I got it!
Old Sep 10, 2017 | 03:00 PM
NotABaller's Avatar
2012 C63, 2014 E550
Great stuff!! Nice 60' time
Old Sep 10, 2017 | 05:57 PM
deadlyvt's Avatar
2010 C63 AMG
Solid run and nice improvement
Only difference was the v7 tune?
Old Sep 10, 2017 | 06:28 PM
I am Jeff's Avatar
Steel Grey Metallic C63!!
Lower temps, lower rear psi, ac off, followed Blkrokt's advice, probably lower da, and v7 tune.
Old Sep 10, 2017 | 06:32 PM
chrisridebike8's Avatar
'10 C63
60' is 1.9 on both so you didn't make up anything on the launch. Seems like most of the time is made up on the big end. Pretty good time on street tires with a tune only.
Old Sep 10, 2017 | 08:08 PM
13pp63's Avatar
E63s
If on street tire that's a really good time and 60 was so hard to hook up on street tire for me once I put the drag radial on car worked
Old Sep 10, 2017 | 08:25 PM
Yeah they are continental DWS06 265's. Ran them at 30psi, but when I was running them at the factory 41psi I was cutting the same 60'.
This run compared to last run.
10 degree cooler out this time (74F vs 84F)
30 PSI tires this time (41 last time)
V7 tune (V6 last time)
Same track, same time of night (around 9pm)
Exxon 93oct both times
Both using race start.
Gained 4mph and .35s in the 1/4
Not bad!
Old Sep 10, 2017 | 08:35 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
psi is that low because of racing or do you always keep that...seems too low.
Old Sep 10, 2017 | 10:53 PM
deadlyvt's Avatar
2010 C63 AMG
I had those continentals before total garbage when they are worn get a better tire and the launch should be better
Old Sep 10, 2017 | 11:10 PM
SuckaGDog's Avatar
C63 AMG Black Series
Are you sure you had the same DWS06 tires? Because Contential just released these very recently and they're an awesome all season tire.
You might be referring to their original version of DWS (all season) or their DW (summer).
Old Sep 11, 2017 | 02:17 PM
deadlyvt's Avatar
2010 C63 AMG
yeah sorry not the al season the summers that came with the car stock struggled tge difference switching to pss was almost unbelievable
