Rear brake disc wont go on - Help!
I've tried altering the slack on the spindel wheel thing and moving the shoe assembly up/down to provide clearance. However it doesn't appear to the shoes that's causing the obstruction. It's the white/rusted thing on the right side of the assembly that looks like it's fouling the new and old disc. Any suggestions/tips?
Also....ans I'm sure this isn't normal either. The bare hub itself without the disc sitting on it is extremely hard to turn (yes it's in neutral). I need to stick a wheel bolt with a rachet to get it to rotate. I'm pretty sure the passenger side wasn't like this but I can't remember for sure (when random things like this happen, they make you question your sanity). No grinding or harsh sounds from the hub...just extremely stiff.
For reference, my hand brake has always been rubbish and never really worked, eventhough i apply it all the time after shutting the car off. I wonder if the prev owner/technician tightened the cable that leads to that drum from an adjustment point inside the car or in the transmission tunnel (if this car has an adjustment point there)
I'll try any and all suggestions tomorrow as it's 9pm here now.
actually I had an issue with my c32 rear brakes now that I think of it something similar to what you are having can't remember what the issue or remedy was though
BTW, I have good news, New part number front rotors with the current OEM front brake pads = no more outer lip on the rotor. They finally got the pads to completely sweep the rotor, with no lip left.
Anyway: rear parking shoes mechanism is always just a funky, spring-loaded mess to align.
I mean, do you have access to the wis?, have you covered any possible adjustment?
And I have a question: why do all seem to engage the parking brake? Is there a weakness in the transmission? Or do only MCT guys do this?
Nothing that would be sorted out with a hammer, a punch and some daylight.
Thanks for any/all suggestions. I'm now 6lbs lighter on either side of the rear
You installed rear rotors with no parking drums and attached mini parking brake calipers on two-piece rear rotors?
Need more details....
Yeah no, simply a pair of rear two piece rotors, but the parking brake is retained (and now working the way the good Lord intended) and I have the same calipers....
Dunno if you guys know this, but the W212 E63 has 360mm rear discs....i know some of you like bigger brakes for track or baller factor...you should just get the calipers and discs from a W212.
Dunno if you guys know this, but the W212 E63 has 360mm rear discs....i know some of you like bigger brakes for track or baller factor...you should just get the calipers and discs from a W212. I am also pretty sure the fronts are 390mm....but i haven't measured mine to validate this claim.
1. You convert from a 2 rear brake caliper system to a 4 rear brake caliper system. This means that you add to your two normal rear calipers an additional two "mini" calipers. these additional two are clocked 90 degrees from the existing ones with an appropriate bracket and they are cable operated, not hydraulic.
2. These additional two rear cable operated mini lightweight calipers, complete with pads, take up the function of the parking brake drum/shoe system.
3. Now that there is this alternate parking brake, you install alternate rear rotors, that do not feature any drums. You also remove all the drum brake components, shoes, mechanism, springs, dust shield.
4. Because you remove the rear drum function, you can now have true two piece rear rotors, where the bell is completely aluminum and light weight
When I read the weight savings you posted, I thought you went this route. This, under my opinion maxes out the rear weight reduction.
I am not aware of a C63 kit, but can post a picture on a different car and can say that many times the mini caliper is a Brembo or WIlwood and they are known to make kits.
Mine is nothing particularly fancy unfortunately. It has an iron liner on the inside for the parking brake. Here's stock vs the ones that have just been fitted. Stock is ~10.5kg (although this pic shows ~10kg, i know), new is 7.3kg (according to a digital scale).
So for those that don't mind to spend a few bucks on rear brakes, check out Brembo rear calipers with integrated electric parking brake mini calipers...
For what it’s worth, the RacingBrake BS-spec BBK has a 360mm rear rotor with alloy hats that are modified to fit over the existing parking brake drum. (you do need the BS rear calipers for it to work)
