VRP M156 Throttlebody Upgrage
Former Vendor of MBWorld
VRP M156 Throttlebody Upgrade
The VRP throttle body upgrade kit includes everything you need to adapt your 74mm throttle bodies to 82mm throttle bodies! It is a drop in modification and incredibly easy to install in your Mercedes-Benz M156 AMG. This upgrade is will drastically increase incoming air volume, resulting in a a noticeably improved throttle response and overall performance.
We saw gains of up to 12 horsepower / 8FT Lbs from upgrading to the 82mm throttle body!
**Actual horsepower results may differ based on the life and health of your motor and your tune.
Velocity stacks now available!
Includes:
Click >> HERE << For Plates
Click >> HERE << For Full Kit
Includes:
- 2x Throttle Bodies*
- Billet Throttle body Adapter plate
- All necessary hardware
Duffer4126 (06-30-2018)
Received 2,823 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Oooh those are pretty.
What about pricing without the plate?
I have a stage 3 blower i dont need plate as throttles mount on y pipe
You know what would be really useful? If you guys could also come up with a bolt-on/clip-on velocity stack for the 82mm TBs themselves. A bunch of us have cobbled together solutions using glue or welds, but nobody has come up with something as OEM-like as is used on the stock TBs or the kit that RENNtech or Kleemann make....
ghh923 (11-08-2018)
BLKROKT (11-07-2018)
I used lock Tite fearing screws would come loose.
Yes it could be done, unfortunately it is not in the works for right now as we have other projects requiring immediate completion including a supercharger conversion kit and a new carbon fiber intake.
hopefully intake is like the renntech one or better without their outrageous price tag lol
This is worthless without the velocity stacks.
They’ll still likely work fine without the stacks. And you have plenty of options for doing stacks if you want, it’s just a little more of a project.
I made my own stacks but would if been way better if they had something that would be plug and play.
I just snuck a video wire into my intake to see if they are still glued on and good to go so far.
Can you please post up some information about the carbon intake? That is going to be my final mod to my car lol
yfz rock (12-14-2020)
