Partial Service History... What to do immediately?
Hi all,
My newly acquired 2011 c63 is missing some service history and I want the car to be up to spec with maintenance. I understand there is a service schedule online but wanted to get your opinion what to service immediately.
Car had 60,000 miles or 100,000 kilometerss
Here's what's been done:
1. Oil change
2. Spark plugs and coils
3. Valve gasket seals
4. Rotors and pads
5. Brand new tires
Should I change out all the fluids? If so what fluids exactly? (I'm new to the c63)
Please list all the items you'd change or service. I'm open to preventative maintenance as well. Thanks!
1. Oil change
4. Rotors and pads
5. Brand new tires
Ive just gone through this and always do all the fluids when buying a second hand car.
in addition to what you did
- brake fluid bled
- trans fluid change
- diff fluid if LSD
-coolant, i know it says 10 or 15 years but i did it anyway
- power steering fluid ch11s
I also bought intake manifold gaskets and PCV to do pre emptively.
- brake fluid bled
- diff fluid if LSD
- brake fluid bled
- diff fluid if LSD
- brake fluid bled
- diff fluid if LSD
To find out if ypur car has an LSD paste your vin number into an online mercedes vin checker and looks for limited slip differential or locking differential in the options list.
rear wheel drive so no transfer case and no front diff.
Looks like I don't have lsd.
Any other fluids like transfer case or anything of that nature?
If you have no intention of upgrading to LSD then change by 150,000km if ypu want it to last past 200,000
You don't HAVE to do a diff oil change.
But you have to check the level.
As such you should spend the money and acquire the tools that for the drain and fill plugs and the oil to top it up with.
As such, might as well change the fluid and get rid of that mud with shavings that sits at the bottom of the diff.
Also with misc cars, each time I changed the oil, the diff didn't start to sweat and then drip oil.
When I didn't change the oil ... it did happen.
You should start with transmission fluid, your behind on that schedule. And of course the oil filter.
I would hurry up with the air filters too. Some cars people just ignore them.
Other than what was already posted, hurry up with the idlers and while at it change the belt too. The idlers have been seen failing right around the mileage you have.
I did all these, the pcv and intake Gaskets, you can change the injectors and o rings ( there are some good prices for Bosch ones and you avoid the potential problem of stuck injector )
The oxygen sensors might start to be tired by now and there could be benefits in power and gas mileage by replacing them, there are 4.
It's strange that someone decided to change the coils in your car.
See if your car has still the factory battery, especially with low miles it may mean it sat a lot so the battery may be tired and need to be changed at this point.
Where do you buy the PCV valve and intake manifold gaskets? Whats the going price for those items?
I am in the works with Shardul to buy UPD Billet Pulleys and will order a local serpentine belt at Lordco. Is there anything else I should change while I am doing the UPD Billet Pulleys?
Anything else?
Anything else?
Yea the trans service and pulleys I would do immediately. If one of those pulleys goes, it doesn't take long (minutes or seconds) to shear off metal. On my C32, one of mine went out and I ended up needing a water pump as well because it shaved off some metal from the bracket and the pulley would no longer fit flush.
Thanks. I just put an order through for UPD BILLET PULLEYS. I will order a serpentine belt as well. Is that the belt that I should replace when doing the pulleys? Any other belts or things to do while I am doing Pulleys?
You should consider doing the belt tensioner assembly as well when installing the UPD idler pulleys. Yes, replace the serpentine belt at the same time.
The UPD set comes with a new tensioner pulley. If you can buy the tensioner assembly without a pulley then get that, if not swap the pulley on the new tensioner assembly with the UPD pulley.
