C63 AMG (W204) 2008 - 2015
Some more info about the SLS intake manifold
Old 01-12-2019, 09:03 PM
Vladds's Avatar
2010 C63 2019 GLA45
I decided to take a look at the SLS intake manifold.
It's not sold in one piece like ours.
There's a top cover that is not expensive, it's like $300, there's a main and lower box that is around $2000 and there are the guts that are around $3000.
The guts have a separate part number for the SLS black series and I'm not able to pull a price for that. But I wonder if the extra HP that the black series had vs the normal one, once again had to do with an even better manifold and even better cams.
It's possible that the lower box includes the throttle bodies but I'm not sure of this.
djr48312 (11-09-2023)
Old 01-15-2020, 07:46 AM
Kid Dynamite's Avatar
C63 AMG W204
Wink
Let me know if you need so infos or dimensions ive one complete M159 Intake manifold in stock.
The intake has follow parts : velocity stacks / frame / cover / air mass meter left and right / fuel lines with injectors / air pump on the bottom
Best regards
Alex
Old 01-15-2020, 08:46 AM
skullbox15's Avatar
2014 C63
Are you thinking of replacing the M156 manifold with the M159? Would that even work? I assume there would be enough hood clearance if people are bolting superchargers to the top of the M156. Although expensive, sounds like and interesting project.
Old 01-15-2020, 09:17 AM
C63 AMG W204
Wink
I was planing to install the SLS manifold in my C63 AMG but now the car are sold ;-) The prefacelift C63 AMG gearbox cant handle that much extra tq as the facelift gearbox can. That was the reason to stay NA with the SLS manifold for getting more power and not that much tq.
Old 01-15-2020, 10:23 AM
roadkillrob's Avatar
12 C63BS Magno Alanite Grey, 22 X3M Brooklyn Grey, 08 BMW E93, 22 Ducati Desert Sled, John Deere 3R
Tasos has a few youtube videos on a c63 they put an M159 intake on
The following 2 users liked this post by roadkillrob:
djr48312 (01-07-2023), Ludedude (01-17-2020)
Old 01-15-2020, 10:29 AM
C63 AMG W204
WOW .....amazing work !!!!
Old 01-15-2020, 10:56 AM
Kriston's Avatar
C63 AMG
You need to re-work your hood to make it fit as well.
Realistically not even sure what we can net with this thing on a FBO car. Any guesses?
Old 01-15-2020, 11:11 AM
BLKROKT's Avatar
Received 2,842 Likes on 1,677 Posts
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I’m pretty sure it’s in the 35whp range.
Old 01-15-2020, 11:13 AM
deadlyvt's Avatar
2010 C63 AMG
I am guessing ~15-20hp ish
probably give up a little in the low end
Old 01-15-2020, 02:23 PM
C63 AMG W204
I think over 600 hp crank are possible - my C63 AMG with ECU + TCU tune + headers and sport catalysts was making 574 hp at crank and running 100-200 km/h at 8.0 corrected
Old 01-15-2020, 02:48 PM
Vladds's Avatar
2010 C63 2019 GLA45
Does anybody know what the functionality of the center box is?
This is the box that shows between the two air filter boxes in pictures of the M159 engine.
Is this the equivalent of the vacuum reservoir of the M156 at the back, by the firewall?
And what about the wiring harness? I'm guessing that the wiring harness needs to come with the intake manifold and hopefully its a plug and play.
As far as the two throttle bodies, I was never sure if the M156 ones open together, or sequentially. If they open together, maybe the engine would start with the M159 manifold on. If not, it will probably not.
Then again it seemed that Tassos started his before tuning, or so it seemed.
The loss of torque must be something too, as there is no variable manifold anymore and the cams are not M159.
Old 01-15-2020, 03:19 PM
BLKROKT's Avatar
That box is the oil tank for the dry sump
Old 01-15-2020, 03:40 PM
Kriston's Avatar
C63 AMG
There are member on here who are making north of 500 WHP with just basic bolt ons.
This is interesting to me, but costs vs a S/C. Makes no sense imho.
Old 01-15-2020, 03:45 PM
The M159 cams are much less pointy than the M156, so the valves are open a bit longer, I would really think you would want the cams and airbox together and then tune it to match the flow and timing. The M159 revs higher also, so it is really leveraging the additional high RPM flow and valve duration to make the power as the M159 makes the most HP at 7-7500 rpm
Old 01-15-2020, 08:06 PM
SPONSOR
hachiroku's Avatar
2007 Mercedes E63 AMG
for that cost...i'd go custom ITB's...with custom airbox to utilize airflow sensors.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old 01-15-2020, 09:27 PM
BLKROKT's Avatar
Pretty sure the SLS intake is the more budget option here...
The following 2 users liked this post by BLKROKT:
hachiroku (01-16-2020), Ludedude (01-17-2020)
Old 01-15-2020, 10:20 PM
Jasonoff's Avatar
Received 1,598 Likes on 940 Posts
2010 C63 AMG
for that cost...i'd
... get a different fkn car.
The following 3 users liked this post by Jasonoff:
BLKROKT (01-23-2023), hachiroku (01-16-2020), Kid Dynamite (01-16-2020)
Old 01-16-2020, 03:44 PM
mr747's Avatar
c63
Like this
The following 2 users liked this post by mr747:
Kriston (01-17-2020), ZephyrAMG (01-17-2020)
Old 01-16-2020, 11:39 PM
roadtalontsi's Avatar
10 C six trizzle
My guess is 50whp for the sls intake. However get ready for a dive in torque probably 50wtq loss.. Without the variable runners on the stock intake, you'll be hurting especially down low where all your street / daily driving is happening. Sls is about 500lbs lighter which makes a huge difference. The black series rev's to 8000rpm so Id imagine it's intake has even more torque loss, but higher ultimate hp especially past 7000rpm. I hope someone actually does this. A tuned sls with long tubes is a very impressive car. For a street car it'll just feel like you gained some turbo lag lol.
While people have posted this, I feel without E85, race fuel (anything over 93 octane / pump fuel) or nitrous these are b.s. claims and hyped numbers.
Sure these cars lay down quick 1/4 mi times but their MPH is very lacking and that tells the real story.
A blower car is night and day from a bolt on car. Power isn't only about peak numbers.
The following 2 users liked this post by roadtalontsi:
djr48312 (11-09-2023), Phil1305 (01-18-2020)
Old 01-17-2020, 05:21 AM
C63 AMG W204
Exclamation
Just change the rear diff ratio from 2.82 (stock C63 W204) to 3.23 for example (SLS AMG does have 3.67 ratio) then your tq loss will not that problem.
https://www.jegs.com/i/Richmond-Gear...153-1/10002/-1
With raised rev limiter to 7400 - 7500 rpm it should be working fine !
Old 01-17-2020, 05:37 AM
mr747's Avatar
c63
is this fitment confirmed
Old 01-17-2020, 06:20 AM
C63 AMG W204
Yes a friend of mine does rallye cross with his C63 AMG W204 and this 3.23 ratio.
MB is calling the diff HAG 215 (H)inter (A)chs (G)etriebe 215(mm) so this crysler 215mm will fit !
The following 3 users liked this post by Kid Dynamite:
djr48312 (05-05-2021), G_Money (01-17-2020), mr747 (01-17-2020)
Old 01-17-2020, 09:22 AM
skratch77's Avatar
2005 E55
Can he tell us how to program the car for it? I have a diff sitting in my garage waiting to try this.
jumping to a 3.23 will make our 3rd gear almost feel like second.
Old 01-17-2020, 09:57 AM
Kriston's Avatar
C63 AMG
Brad, damn so SLS Intake + Turbo setup!!!!!!!!!!!!
Originally Posted by mr747
Like this
djr48312 (06-21-2023)
Old 01-17-2020, 01:05 PM
C63 AMG W204
Another good friend of mine from Germay can reprogram the TCU for you - he also write ECU / TCU maps for some famous tuner in the USA - more with PM ;-)
djr48312 (01-16-2024)
Quick Reply: Some more info about the SLS intake manifold
