C63 AMG (W204) 2008 - 2015
Ceratec or MoS2
Old Apr 30, 2019 | 05:56 AM
tony63's Avatar
C63 w204
Ceratec or MoS2
Hi all,
I did +- 5.000km ago an oil service with an engine flush first and then Liqui moly 5w40 + 2 bottles Ceratec. Good combination, engine runs fine and smooth. For the next oil service I should only add 2 bottles MoS2, no more ceratec right? Or is it better to stay at ceratec also for the next change?
I found also this: Ceretec bonds to parts and is good for 30k miles/50k kms so you run it, then change the oil and don't put it back in for the next 3 or 4 oil changes, most people run MOS2 in those oil changes instead.
What do you recommend guys, just need some advice, because I will change my oil over a few weeks.
Old Apr 30, 2019 | 06:48 AM
Vladds's Avatar
2010 C63 2019 GLA45
The additives bond to parts that you want them to bond to, but also to parts that you don't want them to bond to.
They bond to the oil rings and in time much reduce the oil scraping function, causing puffs of oil smoke and in time oil smell in the exhaust.
They bond to valve seals and that can go both ways.
They bond to calibrated bores and holes, reducing passage size.
They bond to filtration elements inside the filter, reducing oil filter life, you have to account for this.
I don't even want to think about what they do inside an oil cooler.
So stop being so over enthusiastic about adding more and more additives.
Remember how the manual specifically says not to add any additives ?
Yes, the engine will sound smoother and friction areas get additional protection. But the process is not without downsides.
Old May 1, 2019 | 05:45 AM
tony63's Avatar
C63 w204
I understand that, but since there are alot of good reviews I decided to use it also. Someone some advice for the next oil change?
Old May 1, 2019 | 06:19 AM
Murret's Avatar
2012 Mercedes C63 AMG
Pro-Ma MBL8 is what I add but only very small amounts like 50ml or so. I recommend it! Anyone else ever used it?
Old May 1, 2019 | 01:49 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
not necessarily correct...Ceratec will fill in any pits or valley's to enhance oiling performance. for any friction surfaces, they should not be affected.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old May 9, 2019 | 11:11 AM
tony63's Avatar
C63 w204
Anyone any idea?
Old May 9, 2019 | 01:14 PM
hachiroku's Avatar
SPONSOR
Ceratec is used 1 time a year to treat your engine or 30k miles or 50k kilometers. MoS2 should not be used during the same oil change interval. Your next oil change after Ceratec treatment would then be of only MoS2...once you reach 30k miles or 50k kilometers, you'll want to cycle Ceratec again if that is the intent.
__________________
-BARRY
Old May 9, 2019 | 03:01 PM
tony63's Avatar
C63 w204
Thanks, indeed I already did ceratec+liqui moly 5000km ago. Now I want to renew the oil again, so liquomoly + 1 or 2 bottles of Mos2?
Old May 9, 2019 | 03:04 PM
hachiroku's Avatar
SPONSOR
for the size of the M156 you'll need 2 bottles when treating with either Ceratec or MoS2.
__________________
-BARRY
Old May 30, 2019 | 10:31 AM
tony63's Avatar
C63 w204
Anyone any experience? I did already the oil change 5000km ago with ceratec + liqui moly. Now I want to do again the oil service, but still dont know to add just the liqui moly oil or also Mos2?
Old May 30, 2019 | 03:01 PM
hachiroku's Avatar
SPONSOR
a specific line of oil from LiquiMoly has MoS2 already in it. The others do not. not sure which, you'll have to do your research.
__________________
-BARRY
Old May 31, 2019 | 10:22 AM
clk63cab's Avatar
2019 Stage 3 E85 Audi RS3
Molygen is the one premixed...The oil is bright green...and is recommended to be used in conjunction with ceratec or mos2 as mentioned it already has the anti friction additives in the oil.
Old Jun 6, 2019 | 11:44 AM
HLG600's Avatar
2009 SL63 AMG
Originally Posted by tony63
Hi all,
Here's my strategy for the SL:
  • Ceratec treatment @ 33.5K miles with Liqui Moly 5W40 Leichtlauf
    • Going to run a moderately longer and one-time 6.5K mile OCI to give the product a bit more room to work in.
  • 5K mile OCIs after that with Liqui Moly 5W40 Leichtlauf and MoS2 (probably at every oil change).
From what I researched, the optimal path seems to be Ceratec first and then MoS2. FCP Euro breaks it down nicely and has 2-Step kits for sale:
Step 1 Kit - https://www.fcpeuro.com/products/8-c...i-moly-lmk0005
Step 2 Kit - https://www.fcpeuro.com/products/8-c...i-moly-lmk0006
The only part I skipped was the engine flush. Picked up the car with <32K miles and a detailed service history so I wasn't worried about needing to "flush" anything.
Old Nov 12, 2019 | 09:05 AM
Jimmy_c63s's Avatar
That's funny I just came across this post by doing a search for Pro-Ma.
I've been using Pro-Ma MBL8 for over a decade in all of my cars. I started using it when I had that ticking lifter noise in the past (in one of my old cars) and no other product comes close to it.
Curious to know why you use this product in your c63? Have you got a bit of a noisy motor?
Old Nov 12, 2019 | 02:22 PM
hachiroku's Avatar
SPONSOR
doesn't look like the additive Pro-Ma MBL8 is available in America. it does sound like a similar product to Ceratec. do you have any idea how this compares to Ceratec or MoS2?
__________________
-BARRY
Old Nov 12, 2019 | 03:50 PM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
So it's fine to use Molygen and Mos2 together?
Old Mar 25, 2020 | 05:18 AM
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
Found this from FCP Euro on Liquy Moly additives
https://blog.fcpeuro.com/liqui-moly-..._hsmi=85132180
He talks about using Ceratec and MoS2 @ 5.50 minutes.
Old May 6, 2022 | 11:20 PM
MyMerci-E350's Avatar
2012 MB E350 4matic sedan
Hello, did anyone answered your question? I too would like to know.
Old May 7, 2022 | 12:51 AM
hachiroku's Avatar
SPONSOR
you do not want to add MoS2 to MolyGen as MolyGen already has anti friction agents. I believe its a different compound, but per LiquiMoly, do not use MoS2 with MolyGen.
__________________
-BARRY
Old May 7, 2022 | 08:42 AM
HLG600's Avatar
2009 SL63 AMG
As a follow-up, I did the Ceratec with Leichtlauf @ 33.5K miles but did not run it that long. After further research, I landed on 3K mile OCIs for the M156.
Currently running Motul Xcess Gen2 5W-40 without any additives. Will assess a UOA or two and then take it from there.
Old May 9, 2022 | 07:49 AM
swedepat's Avatar
2011 C63 AMG, 589hp
You asked for more opinions.
No, ceratec and others won´t stack up and restrict oilpassages.
But, i have an another opinion also about those additives, they aren´t designed for making camshafts life prolongued.(akillesheal of m156)
Zinc and Phosphorous is, in short ZDDP.
Half a bottle Red line break in additive is a good start.
And no,, it will not destroy your cats if someone says so.
If running two bottles in our engines(as recommended blend when running in our engines) you might hurt them, but it takes a lot of miles to do so still.
