C63 AMG (W204) 2008 - 2015
Free hp mod
Old 08-11-2019, 12:07 PM
skratch77's Avatar
2005 E55
Free hp mod
Here is a free mod since alot of people dont post much about our platform much.
Buy a e63 or ml63 intake y pipe. It is alot bigger and will out flow our y pipes.
You need to be creative on the vacume canister but you get the idea.
Weapon507 (07-09-2020)
Old 08-11-2019, 12:09 PM
skratch77's Avatar
2005 E55
Old 08-11-2019, 12:18 PM
BLKROKT's Avatar
Received 2,836 Likes on 1,674 Posts
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Nice job
Old 08-11-2019, 12:25 PM
Rick X Joaquim's Avatar
C63
Why MB showing the sane part number if is different?
Are you referring the FL e63? With the turbo?
Old 08-11-2019, 01:30 PM
skratch77's Avatar
2005 E55
Early m156s had a different intake
Old 08-11-2019, 02:19 PM
skratch77's Avatar
2005 E55
Guys get them while u can before they dry up
Here is one for 65,just make sure the tabs are not broken
https://rover.ebay.com/rover/0/0/0?m...2F173682572781
Old 08-11-2019, 03:39 PM
gzim335's Avatar
c63 coupe p31weistec stg3 SOLD,2013 C63 BLACK SERIES.
Awesome find good job.
Old 08-11-2019, 04:09 PM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
What's the P/N?
Old 08-11-2019, 09:34 PM
brad65ford's Avatar
2020GLC63
Sweet find!
Old 08-11-2019, 10:49 PM
C63
If is better, why MB updated to the smaller
one?
Old 08-12-2019, 03:34 AM
Catchyname's Avatar
2012 C63 w204 sedan
one?
Smaller pipes have faster velocity at lower flow, possibly the 451hp version c63 got more midrange from smaller Y than it lost it top end. The 507hp e63 could probably use the extra flow.
Probably a very good mod if you already have tune and headers or tune other mods.
Same reason you don’t put a 6 inch exhaust on a car.
For another car example
The bmw m60 v8 had large intake runners and it was updated in the M62 to smaller runners as it gained 20nm through 2000rpm of mid range vs giving up 15hp over 500rpm.
Liquid10 (08-13-2019)
Old 08-12-2019, 09:06 AM
skratch77's Avatar
2005 E55
one?
There was a design change in 2008 or 09 that has a black vaccum box that sits Inbetween the y pipe. That line goes to the throttle bodies and has serious vaccum there. I'm not sure why the added a box to hold some air or better yet let the car have a little air and then get no vaccum but I'm sure it's for emissions.
The r63,ml63 and e63 were also rated 520hp and also have 3in exh piping
Also the only car that had the m156 was the c63 from like 2010 to 2015 so mb probably needed to comply with usa smog testing.
Old 08-12-2019, 01:33 PM
PeterA90's Avatar
c63
Could have sworn that middle piece had to do with the brakes... I’ll find out from my mechanic.
Old 08-12-2019, 01:34 PM
skratch77's Avatar
2005 E55
What ever it is it ends up tying into the throttle bodies
Old 08-12-2019, 02:26 PM
Jyoung63's Avatar
C63 507 Coupe
Is this worth it on a 507
Old 08-12-2019, 02:45 PM
Vladds's Avatar
2010 C63 2019 GLA45
The brakes vacuum reserve is in the Master Cylinder Power Brake actuator. Larger volume than this.
I wonder what this plenum extension will do to the fuel trims. Then again, the Renntech piece doesn't come with a tune, right? Which means that the ECU can adapt to it.
Old 08-13-2019, 01:14 PM
SPONSOR
hachiroku's Avatar
2007 Mercedes E63 AMG
its pre metering sensor so you'll be fine.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old 08-13-2019, 01:49 PM
skratch77's Avatar
2005 E55
Its before the air flow meters so it might cause a higher idle.
Old 08-15-2019, 01:36 AM
bradsm87's Avatar
W204 C63 Wagon
Anyone else thinking of doing this, could you log manifold pressure doing a 3rd gear WOT pull to redline before and after?
I'm a bit disappointed with 95kpa at redline at WOT and I have a tune with the throttle wide open.
There must be a few cheap intake mods to unlock a few more kpa. This may be one of them.
Old 08-15-2019, 07:03 AM
Alex-r-1's Avatar
C63AMG Coupe 507, GL X166
If to install intake y pipe from ML63 where to connect a vacuum hose?
Old 06-24-2020, 10:36 AM
HLG600's Avatar
R230 SL63 | W220 S55
Tried to order a new E63 / ML63 vacuum canister and was SOL. Apparently they are no longer produced and MB's answer is to ship the newer Y-Pipe in place of the older vacuum canister. Silver lining is that I have a brand new OE Y-Pipe assembly that cost me half of what it's usually priced at.
@skratch77 , your OP showed that you initially removed the plastic canister but a later post shows you switched to the older canister. Why did you move away from the first solution?
Old 06-24-2020, 11:07 AM
skratch77's Avatar
2005 E55
I ended up finding one on ebay . I tested with and without the canister and the engine is a lot louder without it. I wanted to be as oem as possible and the few homemade canisters were not good at all. It can be done if you use something that is strong and tight but I just wanted the oem version.
Old 06-24-2020, 11:14 AM
Jasonoff's Avatar
Received 1,594 Likes on 938 Posts
2010 C63 AMG
+1 on this question. Just cap it at the inlet?
Old 06-24-2020, 11:28 AM
skratch77's Avatar
2005 E55
No your intake will sound really loud and weird and you will chase a vacuum leak that doesn't exist lol.
Old 06-24-2020, 12:06 PM
HLG600's Avatar
Makes sense, thank you. Where did the external canister bolt on for you? (Hoping there's a factory spot for it on newer M156s.)
Quick Reply: Free hp mod
