C63 AMG (W204) 2008 - 2015
Steering rack is gone... Best price ?
Old Jun 5, 2020 | 07:45 PM
J0HN_R1's Avatar
'19 4runner TRD / '12 C63 AMG
So the G/F took the car to work a couple months back (was -35c / -30f outside), called when she arrived and said the "power-steering failed" and was leaking fluid.
Then she decided to drive it home ~15 KMs (10 miles), after I told her to leave it there... I was pretty choked. Car's been sitting since.
Last week, after we figured out the power-steering system isn't covered by the aftermarket warranty, I called my Indi-shop owner. He said bring it in.
They took it in, diagnosed it as the pump. After confusion on his end, the pump ended up costing $1200 Cnd (installed) instead of the (verbally) quoted $900.
It was supposed to be done today, but the mechanic called @ 4:30pm as I'm leaving to go get the car and says -
"Ahh, something is wrong with the rack. Feels like air but it's been bled twice."... Yada yada yada.
Waiting for the quote, but pretty fukin pissed at both the shop-owner and my G/F...
Anyone got a lead on a smokin-deal, or possibly even used ? And is this the right part # (it says Coupe) ?
https://www.mbonlineparts.com/oem-pa...YtM2wtdjgtZ2Fz
Thanks in advance.
John
Old Jun 5, 2020 | 10:24 PM
Dogtag114's Avatar
2009 c63
I just replaced mine a few months ago and think I spent much more than that. I need to dig up the invoice.
Old Jun 5, 2020 | 10:31 PM
J0HN_R1's Avatar
Much more than what ? The $1650 USD cost of the rack I linked ?
Thanks for any info you can provide...
Old Jun 6, 2020 | 12:57 AM
bhamg's Avatar
C63 AMG
Rock Auto remanufactured:
$438.89 + $160 core charge = $598.89
https://www.rockauto.com/en/catalog/...nd+pinion,7388
Old Jun 6, 2020 | 09:38 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
If you want OEM new, I find this place on Long Island (is a Merc dealer) always has the lowest prices, they are $1460 for the part you linked, if it was me, I would probably do the reman though.
https://www.mynewbenzparts.com/oem-p...y-204460200080
Old Jun 6, 2020 | 06:13 PM
J0HN_R1's Avatar
Thanks guys ! Much appreciated...
I agree, and so does my wallet, that the reman'd unit is the best avenue.
Old Jun 7, 2020 | 08:12 AM
Vladds's Avatar
2010 C63 2019 GLA45
I walk to the parts counter in Long Island and threaten to buy the parts from an online dealer and tell them the price, and they still did not suggest i buy from their online portal???
That's why I thought that none of them has one, in Long Island.
With the Subaru, I order online and pick up at the counter ...
Old Apr 13, 2023 | 03:15 PM
C55.vick's Avatar
C55 AMG
did the remanufactured rack turn out ok? I’m considering ordering from rock auto but saw a couple posts elsewhere that discouraged me. Lmk and thanks!
Old Apr 15, 2023 | 05:49 PM
NZ-Merc's Avatar
W204 C200, BMW E30 M3, 1980Gt Mini, Toyota Corona, KTM 200 EXC.
I would think that you may be looking at a leaking hose from the start, it got low on fluid and may have damaged the pump.
Next up replaced the pump and now air-rated fluid, I would think turn off and just let the fluid settle top up start up rotate the steering wheel several time then shut off and let the bubbles settle out and repeat would work.
Ultimately what you are looking for is where the fluid was leaking first, if it was the rack it would be leaking at the rack boots.. Have your guy loosens the boots while you are personal their watching and see if either left or right rack boots are full with oil if not Don't replace the rack.
If the rack boots are not full with oil have a very close look at your hoses as I think this is where the problem began and is affecting the bleeding.
I may be wrong but all too easy to order new parts until the problem goes away with out prober diagnosis.
