C63 AMG (W204) 2008 - 2015
Engine whining noise...
Old Jun 28, 2020 | 08:51 AM
one80's Avatar
n/a
Engine whining noise... and now misfires
After having my camshafts, lifters and adjusters all replaced I now have a whining noise, which after the tapping/clattering is now driving me crazy.
It follows the sound of the revs and is particularly noticeable down low.
Sounds almost like straight cut gears.
Any ideas what this might be? Only started after having the above work done.
As a side, the tapping noise of the lifters is still there also, so it seems that it's just the nature of this engine and these will wear down....
*edit:
updated with video:
https://imgur.com/a/ya4eAVY
Old Jun 28, 2020 | 09:31 AM
ecohen2's Avatar
Alternator or water pump failing?
Old Jun 28, 2020 | 06:27 PM
HLG600's Avatar
2009 SL63 AMG
Do you have any audio of it?
Power steering pumps like to whine when either low on fluid or on their way out.
This guy had a whining noise that he claimed to be the oil cooler:
Old Jun 28, 2020 | 11:24 PM
one80's Avatar
n/a
Will try to take a video - my phone just doesn't pick up on the noise all that well.
Is there anything simple that I can do that will give an indication of whether it's likely to be either of the above?
Old Jun 29, 2020 | 02:49 PM
ecohen2's Avatar
Listen under the hood while someone revs the engine slightly.... Alternator, power steering and water pump are far apart enough from each other that you should be able to tell which is making the noise...
Old Jun 30, 2020 | 02:28 AM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
those videos are of the oil cooler fans. my W211 E63 has pretty audible oil cooler fans when they are on.
we'll need a video of the noise. as others mentioned if your power steering mesh filter is slightly clogged it'll make a whining noise as well. my mechanic cleared my screen when he replaced my fluid a few years back. power steering whine has yet to come back.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Jul 1, 2020 | 07:29 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
It is concerning that the tapping is still there, I had cams, lifters and CA's replaced in mine and it is dead quiet, so quite, never knew and M156 could be so quiet, if you still have lifter tapping after all that work I would be concerned.
One way to rule out the accessories is to pull the serpentine belt and run it for a 15 seconds with the belt off and see if the sound is gone.
My only other thought would be that the cam adjusters have a gear plate on the back of them that is tensioned to keep the cam adjusters tight against the gear with no slop, if someone didn't put the new ones in right and that has no tension on it when installed I would imagine that could cause a whining noise.
Maybe get a mechanics stethoscope and pinpoint the noise if it is coming from an accessory or under the cam cover.
Old Jul 12, 2020 | 06:23 AM
one80's Avatar
n/a
Have just come back from a week's holidays and was going take a video to get your thoughts on this issue, but...
Started the car OK and let it warm up.
Went off down the street and found the engine was really unresponsive, and then started to get vibrations and CEL light.
Limped back home and turned off.
Had the local RAA come out and he read the following codes:
  • P0017 - Crankshaft Position Sensor
  • P0301 - Cylinder 1 Misfire detected
  • P0302 - Cylinder 2 Misfire detected
  • P0303 - Cylinder 3 Misfire detected
  • P0304 - Cylinder 4 Misfire detected
It's going back to the shop tomorrow.
Is there any chance that this issue and the whining noise are related?
Old Jul 12, 2020 | 06:25 AM
one80's Avatar
n/a
Yes... I was surprised that it was still there too, though from reading other threads on here it seems that it's not uncommon to have the noise return?
Reading what you've said above re. the adjusters and my new issue (see above), I'm wondering if these are related?
Old Jul 12, 2020 | 09:56 AM
Top Answer: 1
So looking at those codes, seems like a bad camshaft adjuster or cam position sensor, due to you having the cam adjusters replaced and then getting a noise, would bet on it being a cam adjuster issue, either a random premature failure or an issue related to the install maybe.
Seems the full code should be something like this p0017 crankshaft position-camshaft position correlation-bank 1 sensor B, so it is unhappy about the crank position compared to the cam position of one of the cams so mostly likely a cam position error based on the work you have had done.
https://mbworld.org/forums/c63-amg-w...code-help.html
Old Aug 29, 2020 | 07:26 AM
one80's Avatar
n/a
The misfires were fixed.
The services record shows clearing of codes and camshaft (re)learning procedure?
Anyway, that is all working fine now.
The whine is still there however.
I've uploaded a video now, so interested to get peoples thoughts before I take it back yet again.
The whine is fairly apparent in the audio, to my ears at least.
Old Aug 29, 2020 | 07:52 AM
Top Answer: 1
Certainly not normal and very apparent on the video - mine with new CA's, cams and lifters is dead silent, quieter than I ever thought the car could be.
To me it sounds like power steering pump whine, does it change in tone at all if you move the steering a bit?
Not sure how technical you are, one easy test would be to remove the serpentine belt for a minute and see if it goes away, that will tell you if it is an accessory or not. The other option is a mechanics stethoscope and and probe around and see if the sound is the power steering pump or another accessory or from the cam covers or somewhere.
Old Aug 29, 2020 | 12:27 PM
Tehvine's Avatar
W204 C63
Mine has made this noise for years, I think it's the transmission pump. When you first start it, the noise isn't there. As soon as the car starts to get warm it happens. When I did my fluid change it was dead silent until the fluid was nearing the temp for setting the level. The noise was extremely apparent that it was coming from the transmission while under the car. Yours is a lot worse. I'm getting a lift in a little over a month and I'll probably check on that noise again since it has been a while. Trans needs to be rebuilt / replaced anyway since it slips sometimes on 2-3 at WOT. It's one of the reasons for buying a lift.
Old Aug 29, 2020 | 06:05 PM
one80's Avatar
n/a
Thanks for the replies.
And at least I’m not imagining it either...
I’m nearly due for a service so will get them to look again, though last time they thought the noise was usual... it’s hard to find a good mechanic.
Old Sep 14, 2020 | 08:21 AM
one80's Avatar
n/a
Just had a B service on the car and asked them to look at the noise. The mechanic could hear it also.
After removing the serpentine belt, the noise was still there.
They tested a few other '63 cars in the workshop also, and they all had the noise to varying degrees.
The conclusion they came to was that it's the camshaft adjusters and drive gear. These are essentially straight cut, which is the noise, and it's common to all M156s.
Logically would follow the rpm of the engine also.
Old Sep 14, 2020 | 01:35 PM
Hans Delbruck's Avatar
What I like!
Hello,
I’ve owned my ‘08 since new and it has always had this whine. Yours seems a little louder but might just be the video quality. I wouldn’t worry too much!
I’ve found that reading the forums can make you find “problems” that aren’t really problems. Sometimes that can decrease your enjoyment of a really great car. Mine has been flawless, minus a faulty Crank Position Sensor that was replaced right after I took delivery.
Take care,
