C63 AMG (W204) 2008 - 2015
Loud chatter/ticking sound Only on a Cold Start
Old Jul 7, 2020 | 03:11 PM
Paul Sapio's Avatar
c63 AMG
Angry Loud chatter/ticking sound Only on a Cold Start
Hello all,
I have had this car for a little over 2 years, and out of the blue, this sound started happening. I have had MB look at it, they replaced the adjusters, but the sound is back. Any ideas what this is?
MB is saying that the motor needs to be replaced after replacing one side of the adjusters. Which I feel is a little excessive.
https://www.youtube.com/watch?v=reRI...ature=youtu.be
Old Jul 7, 2020 | 05:13 PM
cornerjunkie's Avatar
none
I've got the same sound and it can be pretty loud at certain times... I haven't been able to find the fix either.
Old Jul 7, 2020 | 06:56 PM
Paul Sapio's Avatar
c63 AMG
Yea, I have searched the forms, nothing that I am finding sounds the same was this.
Old Jul 7, 2020 | 10:11 PM
none
So replacing the adjusters didn’t alleviate anything? That’s the only fix I’ve read, but have read others replacing as well and not rectifying the noise. It only lasts for 1-3 seconds, correct?
Old Jul 7, 2020 | 10:27 PM
lemonstand's Avatar
2014 C63 507 Edition Sedan - Mars Red
~1 out of every 10 cold Starts, I’ll experience the same. It’s only for 0-1 seconds at cold start and It never happens when I rev or drive after. Curious if this should be looked into as well. I’ve read into it and from what I gathered there are some that just live with it, others have fixed cam adjusters only to find it didn’t fix anything.
File Type: mov
Old Jul 7, 2020 | 11:33 PM
lemonstand's Avatar
Also found this thread which goes back and forth about it being normal/not.... not sure if anyone from that thread has updates ?
https://mbworld.org/forums/c63-amg-w...-normal-3.html
Old Jul 7, 2020 | 11:47 PM
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
It sounds like your Cam Adjusters.
A lot of M156's start like that sometimes.
Old Jul 8, 2020 | 01:34 AM
Paul Sapio's Avatar
c63 AMG
No, nothing. I sounds like a timing chain rattle. How MB doesn't know what is causing it is beyond me.
A master at MB was telling me it takes a few seconds for oil pressure to build up, which leaves the chain lose on cold starts. MB said next step is to replace the motor... like my car only has 70k miles on it.
Old Jul 8, 2020 | 01:37 AM
DRBC43AMG's Avatar
New engine? Sounds like a master twit to me.
Old Jul 8, 2020 | 01:38 AM
Paul Sapio's Avatar
c63 AMG
See the sound in a lot of those videos are continuous sounds. Mine only happens with in the first 1-2 seconds of start and then nothing. Car drives normal and everything.
Old Jul 8, 2020 | 01:40 AM
Paul Sapio's Avatar
c63 AMG
That's what I told him. After the adjusters, they just have no idea what to do next, its like they have never seen this motor before.
Old Jul 8, 2020 | 01:49 AM
Paul Sapio's Avatar
c63 AMG
Both sides are brand new -
A rock fell out of a construction truck i was behind, and I couldn't slow down in time. Bent the exhaust up which is why you see the exhaust parts on there as well.
Old Jul 8, 2020 | 02:46 AM
Cwagon's Avatar
You have only replaced 2 out of the 4 Cam adjusters.
They most likely only replaced the inlet ones since it is the inlet camshafts and lifters that have the most wear problem.
Watch this video from the 31minute mark about Cam Adjusters.
Tasos probably knows more about the M156 than most stealership master techs.
Old Jul 8, 2020 | 07:46 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Like Cwagon said, they only replace 2 of the 4 adjusters, so could still be an adjuster for sure, not a lot of part numbers on that work order, hopefully the washer screw line includes the diamond washers and new bolts to hold the cam adjusters on as they are single use. Also seems they didn't replace any seals for the cam covers or cam adjuster covers according to that.
Seems they are pretty light on smarts if they are saying it needs an engine cause they are too dumb to figure out a problem especially since they only replace half the cam adjusters which is one probable source of the noise.
Old Jul 8, 2020 | 08:17 AM
skratch77's Avatar
2005 E55
Could also be the solenoids on the adjusters. There are 4 as well.
Old Jul 8, 2020 | 08:32 AM
none
OP, I'll take a video of mine and post it. I believe you and I are chasing the same issue... The fact that the dealer told you the only other option was to replace the motor is comical at best. I would start looking for another shop.
Old Jul 8, 2020 | 09:26 AM
skratch77's Avatar
2005 E55
No go get a new engine lol its under warranty and I would do it.
Old Jul 8, 2020 | 10:19 AM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
This. It's a $30,000 reset button you can get for free. Jump on that!
Old Jul 8, 2020 | 10:23 AM
skratch77's Avatar
2005 E55
Yea man same thing happened to my brothers e350. He went in for a valve tic and the dealership said you need a new engine lol he had a nasty loaner for a month and got a brand new engine.
I then went to same dealership and they told me my car was fine and normal so if you have a dealership saying new engine JUMP on that.
Old Jul 8, 2020 | 10:24 AM
G_Money's Avatar
duplicate - delete
Old Jul 8, 2020 | 10:27 AM
SDR's Avatar
SDR
'99 C43, '12 C63, '13 E350, '14 Sprinter
Jump on that!
Not sure I'd trust that shop to swap a motor for me.
Old Jul 8, 2020 | 10:29 AM
skratch77's Avatar
2005 E55
Dont matter. You know how hard it is to get dealer to put a new engine in a c63 is? Its literally a 35k dollar job.
Old Jul 8, 2020 | 11:39 AM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
Hello all,
Willing to bet it is a bad camshaft adjuster. I replaced those F***ers and they still rattle once every 3 or 4 months. I say drive & enjoy the car, until it starts throwing a CEL or if the noise occurs during every startup.
Good luck.
Old Jul 8, 2020 | 12:09 PM
none
I may have missed it, but I don't see where the OP said that MB would cover it under warranty. With 70K miles, I doubt they would foot the bill.
Old Jul 8, 2020 | 12:10 PM
skratch77's Avatar
2005 E55
Cpo warranty covers unlimited miles
