C63 AMG (W204) 2008 - 2015
Look Inside the PCV Valve
Old May 31, 2022 | 12:13 PM
fflmlf's Avatar
2013 C63
My PCV valve hose shattered when I moved it to remove the intake manifold, so why not cut it open and see what's inside?
Interesting and simple design. Tip of spring points towards pipe to engine block.
Thanks,
Ted
Old May 31, 2022 | 01:53 PM
eightysixtuned's Avatar
W211 E63 AMG
pretty simple...that thing is still good, i don't see any tears. just cut off the hard hose and add rubber hose to a catch can.
Old May 31, 2022 | 02:04 PM
fflmlf's Avatar
2013 C63
Catch can is in, replacement PCV was part of the plan before I give you a call for tuning
Old May 31, 2022 | 06:24 PM
WidowrRacing's Avatar
C63 AMG W204
What are the symptoms of having a bad PCV on the M156?
I’m assuming some oil use and possibly some smoke on start up?
Does it affect driving performance?
Old May 31, 2022 | 07:13 PM
W211 E63 AMG
blue smoke out of exhaust, low oil light being triggered often, and if it's really bad, you'll trigger a lean idle code. another thing to mention is, as its trending towards being really bad, your idle fuel trims will be far from 0, but also if you have filters, row airboxes, or headers, your fuel trims will be way off already, so it would be difficult to advise you on those items.
Old Jun 1, 2022 | 08:27 AM
skullbox15's Avatar
2014 C63
I replaced mine around 70k on 2014 model. Mine was still good but compared to the brand new one but the tube on the old one definitely felt brittle compared to the brand new one.
Old Jun 1, 2022 | 07:47 PM
Chemical7's Avatar
2014 C63 AMG Edition 507, 2008 E63 AMG, 2016 C300 Daily
My car blows a little smoke if I do not fully warm up car before shutting down and upon restart up. The previous owner had the PCV replaced, but I did notice the car had its secondary cat removed. Car doesn't smoke every time its not warmed up, maybe once a month or so. Do you think the cat removal may play a role?
Old Jun 2, 2022 | 12:41 AM
W211 E63 AMG
shouldn't be puffing "blue" smoke if the PCV is correctly functioning. white smoke is coolant or condensation in the exhaust system. black smoke is running rich from fuel.
Old Jun 2, 2022 | 10:20 AM
Chemical7's Avatar
Thanks for the response, I will look into the PCV replacement.
Old Jun 2, 2022 | 11:48 AM
W211 E63 AMG
if your PCV is still working correctly you may just simply need a catch can. the PCV does a great job with limiting oil vapor from pooling, but as the PCV gets worse oil pooling within the intake manifold will continue to get worse thus causing blue smoke.
Old Jun 3, 2022 | 09:41 AM
Chemical7's Avatar
I see.
Great information, I may look into a catch can as well.
Old Jun 5, 2022 | 08:21 PM
go team's Avatar
2012 C63, GL63, 1989 300CE
If you plug that “whistle port” the whole pcv is rendered useless. It is the evacuate to atmosphere port.
Old Aug 17, 2022 | 01:11 PM
retna7's Avatar
2000 E430 Sport
Cylinder 7 before:
Cylinder 7 after:
RedLine poured in through spark plug mount, left to work for a few hours, then shop vac.
Old Aug 17, 2022 | 01:40 PM
W211 E63 AMG
i'm sure this last post was meant for another thread...but a good perfect tune would clean the pistons a good amount as well. hopefully those divots are an illusion from the carbon specks and not pitting from detonation.
Old Aug 17, 2022 | 01:57 PM
retna7's Avatar
2000 E430 Sport
Wrong thread. My bad. Thanks! Mods please delete...
Old Aug 21, 2022 | 09:40 PM
See63Run's Avatar
2013 C63 (W204)
arent those divots the relief for the valves? i think this is relatively common in engines.
Old Aug 22, 2022 | 03:33 PM
W211 E63 AMG
i meant the small black specks...hard to tell if they're pitting in the alloy or shadow from the carbon bits. to me it looks like massive detonation as the leading and trailing piston crown seems to have massive pitting.
Old Dec 11, 2024 | 01:13 AM
Henrychung828's Avatar
C63 AMG
Barry, need your advice. I just replaced the PCV valve and added Weistec oil/air separator few months ago. And I keep receiving CEL light which were mixture too lean and also keep asking to add engine oil. Also I could see the oil collected from the separator after few hundreds miles and recently developing the smoke from the exhaust. (my friend told me its blue smoke). is there anything wrong with the PCV valve or the oil/air separator?
Thank you so much,
Henry
Old Dec 11, 2024 | 06:52 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Thank you so much,
Henry
Did you hook the hoses up to the OAS backwards?
Old Dec 11, 2024 | 08:07 AM
C63 AMG
Yes , it’s connected to the Oil/Air Separator .
Old Dec 11, 2024 | 08:30 AM
Joshinator99's Avatar
ML 63 AMG
Thank you so much,
Henry
Sounds like unmetered air (vacuum leak)…
Old Dec 11, 2024 | 08:57 AM
C63 AMG
Thank you. Any idea where should I looking at first? (Locate the vacuum leak).
Old Dec 11, 2024 | 01:16 PM
ML 63 AMG
Every connection you touched… The PCV valve you replaced and the oil separator are both items that can result in a vacuum leak if not sealed up properly (or if the catch can is piped in wrong).
You can always have the system smoke-tested with a smoke machine to help find leaks.
Old Dec 11, 2024 | 09:49 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I asked if you hooked up the hoses backwards. There's an inlet and outlet on the OAS and it's very important you have the hoses in the right orientation.
Excessive oil in your intake can cause a lean condition.
Old Dec 12, 2024 | 09:44 AM
C63 AMG
Thank you Jason. Do you mean the pipe on Weistec oil/air separator , one is in and one is out?
