Best tires for 2014 c63 amg coupe
Best for what?
Comfort?
Track use?
Longevity?
Dragracing?
Or do you want best overall?
Overall tire i would with my own experiance Continental sportcontact 6
I´m on second season and there is still good amount of thread left, both front and rear(About 10k miles on them)
They won´t outperform semislicks such as pilotsport cup in grip, but offers slightly more comfort.
And there are sportcontact 7´s aviable now, probably offers a little more grip due to more rubber on the road.
Best for what?
Comfort?
Track use?
Longevity?
Dragracing?
hey thanks for your response. I’m going to purchase these ones after doing some research. It looks like they are the best option.
the previous owner put new nexen nfera su1 tires on the front right before I purchased the car, so these have about 9mm left on the tread currently. Upon reading about the nfera su1, my understanding is that this is an OK tire. Not a good one for the c63 amg, but an okay one.
would it be alright if I had pilot sport 4s tires on the rear and kept the nfera su1’s on the front? Would I see a massive performance decrease?
this previous owner cheaped out on this 63. The rear tires are one Bridgestone and a delinte. The car pulls one direction when gunning it and I assume it’s because of the low tread and crappy rear setup. Also slips a lot.
I was choosing between the both when i bought my conti´s, the pilots were on backorder at that point so my choice was easy.
But i´m pleasantly suprised by them.
They were actaully not cheaper.
My rims are 18” and I am in the USA. Does anyone know if I can get the contact sport 7 tires in the USA in an 18” size? I can’t find them anywhere online. Might have to import them.
The Pilot Sport Cup 2 Connects are also a good street tire as they are quiet and have large circumferential grooves making them pretty good wet tires also. I am sure they won't last as many miles as PS4S on the road, but they do provide more grip and better lap times in dry conditions if ultimate performance on a streetable tire is the goal. They came out of a national Time Trial event at Sebring which included at least 10 track sessions over 3 days and were still in good shape. They are more predictable and controllable at the limit of traction than the ps4s, but you won't be able to get that extreme on the street to take advantage of it.
Avoid mixing brands front and rear. You'd likely get away with it as traction control would probably keep things in check under an extreme situation where the front and rears might act differently. But if you are using traction control or if you are getting away with mixing tire brands you definitely aren't driving the car properly.
