C63/C63S AMG
Active sound module
Old May 12, 2018 | 12:20 PM
  #301
-krikke-'s Avatar
C63 S Coupe
V8rumble, you have secondary cats removed?
Old May 12, 2018 | 01:02 PM
  #302
KJ's Avatar
KJ
2020 GLE 53 AMG
That sounds like no cats at all to me!
I have the secondary cats removed and I don't think the car has ever sounded that loud.
Old May 12, 2018 | 01:21 PM
  #303
V8rumble's Avatar
C63
yes secondary cats removed
Old May 12, 2018 | 01:22 PM
  #304
V8rumble's Avatar
C63
That’s secondary cats removed with the module! Do you have the asr module?
Old May 12, 2018 | 03:24 PM
  #305
AlexZTuned's Avatar
2017 Porsche 911 C4
That sounds freakin awesome. I don't hear any rasp, just way more volume with the OEM tone
Old May 12, 2018 | 03:58 PM
  #306
-krikke-'s Avatar
C63 S Coupe
Sounds good man!
Old May 12, 2018 | 04:52 PM
  #307
V8rumble's Avatar
C63
Thanks lads. Another short vid
Old May 12, 2018 | 04:57 PM
  #308
AlexZTuned's Avatar
2017 Porsche 911 C4
I told myself I could wait a little longer before doing the secondary cat delete. But after hearing this, oh man... now I'm looking up local exhaust shops
Old May 13, 2018 | 01:20 AM
  #309
V8rumble's Avatar
C63
Old May 13, 2018 | 08:39 AM
  #310
Fordgt40's Avatar
C63 amg esate
Originally Posted by ezatnova
It won’t work to upload by sending it to YouTube then attaching the link here?
Thanks, I’ve never done it before so I hope it works, if it does you can see it make hardly any difference between stock and module
Old May 13, 2018 | 08:56 AM
  #311
WellesleyGL's Avatar
'16 E63s Wagon
Experiencing sound is a very personal thing but I can definately hear a huge difference compared to stock. Windows closed is not such a great difference because these modern b*tches are way too isolated inside the cabin.
I drive with my left window open (10cm) and then it's a big difference.
Try this:
-start the car in Comfort mode with factory valves closed.
-now get out of the car (keep it running) and use the ASR key remote to open the valves.
If you're still not able to hear a big difference than there is something wrong with your unit or you have a hearing problem...
Lower the seats, you can hear more pops and bangs.
Old May 13, 2018 | 09:52 AM
  #312
skim7x's Avatar
Mercedes-Benz E63s AMG
That's definitely not right... did you install correctly? maybe it's a faulty module? I hear NO difference, that's definitely not right.
Old May 13, 2018 | 10:00 AM
  #313
ezatnova's Avatar
2016 C63S
Also cutting a hole in the floor board should enhance them as well
Old May 13, 2018 | 10:02 AM
  #314
ezatnova's Avatar
2016 C63S
https://youtu.be/xawfA3WPfgE
thanks for the vid, it did upload properly.
Can you shine a flashlight all up in there and record record what happens with the various buttons? I agree it sounds like no difference between factory and “open”, only “factory/open” and “closed”.
  #315
Fordgt40's Avatar
C63 amg esate
I don’t think it’s installed wrong the connectors wouldn’t fit the wrong way round and anyway I can hear the valves doing something so the module must be activating them.
What year are the cars that you guys have installed the module on, mine is 2018 and I’m wondering if it works on the latest one.
Old May 13, 2018 | 10:04 AM
  #316
Fordgt40's Avatar
C63 amg esate
Can you ahine a flashlight all up in there and record record what happens with the various buttons? I agree it sounds like no difference between factory and “open”, only “factory/open” and “closed”.
Yes I’ll do that when I’ve got a moment.
Old May 13, 2018 | 11:12 AM
  #317
-krikke-'s Avatar
C63 S Coupe
Mine is a 2017 coupe.
Old May 13, 2018 | 11:26 AM
  #318
-krikke-'s Avatar
C63 S Coupe
The install is only one way so you can't miss...
Your module is indeed changing the valves (the hearable mechanical noise) but there is no sound change... I know from previous experience that hearing the mechanical clicking noise of the valves not necessarily changes the sound level...
The only thing you can do from your side is to try and find someone with another C63 and try your unit on that car for double checking. If that gives the same result than I would contact Daniel or Michael at ASR and ask them what to do.
Old May 13, 2018 | 11:29 AM
  #319
V8rumble's Avatar
C63
Definitely something wrong there mate.
This is mine in S+ using module to open and close
Old May 13, 2018 | 12:10 PM
  #320
Fordgt40's Avatar
C63 amg esate
Is that on a cold engine, mine does that but when hot it’s how you see it on the vid, have you switched between the top two buttons to see if there’s a difference, the right one, as far as I know switches back to stock and allows the original button to work, well it does on mine and as you see on the vid it makes no difference.
One advantage is it starts on loud without having to press the start button twice with foot off the brake.
I’m not with the car at the moment so I’ll have a good look to see what happens to the valves movement between stock and module tomorrow.
Old May 13, 2018 | 12:54 PM
  #321
V8rumble's Avatar
C63
Ive not tried the top two. I’ll give that a go
Old May 13, 2018 | 06:21 PM
  #322
AMGWagon's Avatar
2016 C63 AMG Wagon
Maybe the rear valves are opening OK, and that's the mechanical noise you can hear. But the center H valve might not be opening and from what I understand, this is the one that is fully open on a cold start and then closes. So having the H valve fully open makes a big difference to the noise output.
Old May 13, 2018 | 06:37 PM
  #323
skim7x's Avatar
H valve isn't controlled by the module, so it does its own thing whether you have the module or not, and he is still having a different outcome than everybody else... It's not the h valve that's the problem
Old May 13, 2018 | 07:09 PM
  #324
KJ's Avatar
KJ
2020 GLE 53 AMG
Are you in "comfort mode" when hitting the button?
I can definitely hear a difference in tone when you press the button, but in comfort mode, the car idle's at a lower RPM, so the sound difference won't be as pronounced as trying this in Sport+ mode.
Old May 13, 2018 | 07:17 PM
  #325
AlexZTuned's Avatar
2017 Porsche 911 C4
Wouldn’t surprise me if he didn’t know or even notice how idle speed and sound increases in Sport+/Race.
