Active sound module
Why does the C63 not like the rear exhaust valves being unplugged at the back Box? Does this alone definetly put it in limp mode? I’ve Done this on my previous a45 and that was happy?
With all the uncertainty around the asr module and 2018 cars I’m thinking of trying the bypass connectors that are around £50 and keep it 100% open and apperntly fool the ecu. Will these have the same issue as the asr module on a 2018 car ?
Yes, you can use the O2 sims (ie AWE) to keep the valves open, but I would suspect it would be the same result as the ASR Module (as this is exactly what the ASR module does). I think if you have a 2018, you're just SOL.
Guess, as I’m a 2018 owner may take a punt on the sims and see where I get. Rather spend £50 to test it instead of £300. If it works ok can always add ASR to give full control.
Wish I used the gash mask though. My head kept spinning the entire day after breathing all that fumes in, haha.
Loaners a brand new cls 53 so so could unplug these and test ! ( only joking). Nice car but could do with some extra noise. Dash is pretty awesome though!
Hi, no not really. Units received but the merc dealer messed up what they were supposed to be doing so my cars back with them, so not going to fit until they’ve sorted the bits. Probably be a week or so until the cars back and I can fit.
Im not doing that in my 90k car lol but bypass plugs sound similar? Do you have a link to where you found them.
I want more on start up and idle, as I’m sure everyone in this 22 page topic agrees haha. My w204 with cat delete was nice haha.
at least these will keep it tidy. £58 in the uk, but think others available in us, again mentioned previously in this thread.
https://www.ebay.co.uk/itm/Mercedes-...72.m2749.l2649
