C63/C63S AMG
My first misfire - 2019 AMG C63s Coupe
Old Jun 19, 2019 | 01:29 PM
B3NS_C63s_AMG's Avatar
2019 AMG C63S
UPDATE
  • Dropped off the car to my dealer yesterday and received a call earlier and was told that they're going to be installing the LATEST (New) ECU firmware which is about 4-5 hour procedure having AMG Engineers involved. They also got my authorization to drive the car for 25 miles for "AMG adaption"?
  • At this moment, these are the only bit of information I have and I will let update here if I receive any more info.
Question:
  • Do you think this new update has to do with this known issue (misfire) which I assume AMG is aware of?
  • Does it address the pop/crackle issue?
Old Jun 19, 2019 | 02:08 PM
munis's Avatar
2021 Mercedes C63s AMG Coupe
Originally Posted by Ben Khoshabeh
UPDATE
Question:
Questions only you can answer at the moment haha.
Old Jun 19, 2019 | 03:06 PM
MBzW205's Avatar
2018 C63S Coupe
UPDATE
Question:
They haven't provided a root cause from what you're saying. They are assuming it will fix your misfire? AMG adaption is correct, not sure on the mileage but adaptation is in the manual. Although, it's supposed to adapt to your driving style not there's lol.
Old Jun 24, 2019 | 11:03 PM
2019 AMG C63S
Got the car back earlier today with below notes from service dept.
Drove the car in town visiting my client and got my first misfire AGAIN followed by engine light and loss of power and shaking; restarted the car and got everything back to normal but few minutes later, misfire happens again and engine light stays ON no matter how many times you restart the car. Had to drop off to my dealer again. Let's see what's next :/
Old Jun 25, 2019 | 12:52 AM
Profomo's Avatar
2019 C63S Sedan
Feel so sorry for you, this shouldn't be happening
Did they mention at all what the ecu update was for though?
Old Jun 25, 2019 | 01:49 AM
2019 AMG C63S
My service advisor was gone for a business trip so haven't had a chance talking to him yet
Old Jun 25, 2019 | 07:53 AM
  #32
Profomo's Avatar
2019 C63S Sedan
Let us know once you hear back, think many people here on the forum would be interested to know as well
What was your build date?
Old Jun 25, 2019 | 08:03 AM
  #33
bob_ham's Avatar
2019 AMG C63S Coupe
Thanks for following up, it'll be interesting to see how this plays out. At least you have documentation to shut up the "why do you think it was a misfire" crowd.
Old Jun 25, 2019 | 12:34 PM
  #34
2019 AMG C63S
For sure. My built date is Feb 2019.
Old Jun 25, 2019 | 11:23 PM
  #35
2019 AMG C63S
UPDATE: Received a call from my SA earlier and was told that they’ll have to keep the car for a while since previous instructions didn’t resolve the issue. Now MB of U.S is involved.
Old Jun 26, 2019 | 09:31 AM
  #36
Chino075's Avatar
c63s
@Ben Khoshabeh , I just pulled my old invoice and it says the EXACT same thing as yours (other than yours is cylinder 4, mine is cylinder 5). Not sure if you want to show this to the tech to see if he can try it out rather than waiting MB US.
Old Jun 26, 2019 | 02:08 PM
  #37
2019 AMG C63S
Thanks mate! I'll let my SA know
Old Jun 27, 2019 | 03:47 AM
  #38
2019 AMG C63S
@Chino075 per my last conversation with my SA today, exact same bulletin as yours will be applied to my car. Btw, what’s your built and model?
Old Jun 27, 2019 | 04:44 AM
  #39
Profomo's Avatar
2019 C63S Sedan
Did your SA mention what the software update/ECU software addresses?
Old Jun 27, 2019 | 09:10 AM
  #40
Chino075's Avatar
c63s
My build date was September 20, 2017 and it's the sedan. After the tech swapped my coils/plugs (coils being more of the culprit from experience), it's been running strong currently at around 16,000 mi.
Old Jun 27, 2019 | 09:38 AM
  #41
2019 AMG C63S
He called me while I was running extremely busy so I didn’t have a chance to ask but I’ll definitely ask next time as I’m so curious about that.
Old Jun 27, 2019 | 10:34 AM
  #42
munis's Avatar
This is ridiculous, instead of checking the engine with the coil packs changed for 4 and 5, the freaking guy put the coil pack back into Cylinder 1 and 2? Like Cylinder 4 and 5 got messed up a bit, let me do that for all your cylinders? Where do Mercedes hire these guys from?
Old Jun 27, 2019 | 10:50 AM
  #43
Chino075's Avatar
c63s
I see your concern on this and I'm no mechanic, but I can relate on why it was done. I do this with RAM too, if I know DIMM slot 2 and slot 4 are ok, I would want to put the faulty ones in slot 2 and 4. That will prove to me that it's the RAM and not the DIMM slot 1 and slot 3.
Old Jun 27, 2019 | 11:40 AM
  #44
bob_ham's Avatar
2019 AMG C63S Coupe
It's a common troubleshooting technique. I don't think a few miles of missfire is going to mess up the cylinders.
Old Jun 27, 2019 | 11:51 AM
  #45
2019 AMG C63S
Yep. My dad used to be a mechanic and I remember him doing the same thing.
Old Jun 27, 2019 | 12:10 PM
  #46
msd3075's Avatar
'15 C63S
As others have stated, that it an extremely common procedure to check for a bad coil pack and/or spark plug. If the misfire follows the coil/plug, you've found your issue. If the misfire stays on the same cylinder, you carry on with further diagnostics. If they hadn't done this, then I'd begin to question the mechanic's abilities.
Old Jun 27, 2019 | 02:30 PM
  #47
munis's Avatar
No I know this is common procedure to find faulty coil pack, I have done it on my beaten up corollas and civic, but I sure as hell won't play the same game with a 90k car. Specially when the STAR diagnostics is specifically pointing out to misfires in cylinder 4 and 5. Like I said, you are not playing with a Corolla here, we pay a premium for these cars, run to the parts department and get some new coils, put them in 4 and 5 and run diagnostics again. Atleast that is what my expectation would be if I had a c63s in service.
Old Jun 27, 2019 | 04:24 PM
  #48
msd3075's Avatar
'15 C63S
That'd be a waste of two brand new coil packs if the original ones ended up not being the issue. And if your car came in running fine other than a slight misfire, the original misfire wouldn't have caused any damage to the engine internals. No need to worry about any other damage by moving the coil packs to a different cylinder. While our cars are more sophisticated and higher performance than your old Corolla or Civic, the fundamentals behind how to wrench on one are pretty much the same.
Old Jul 1, 2019 | 08:30 AM
  #49
Profomo's Avatar
2019 C63S Sedan
Sorry to ask again, but any chance you figured out what the ecu update was for?
Old Jul 1, 2019 | 01:09 PM
  #50
2019 AMG C63S
I still don't have an ETA on my car as it seems like the parts are on back-order...
I asked about release notes on the ECU update but I didn't get a solid answer. My assumption is that they'll never release those information to owners? But honestly, when i picked up the car last week and before having my second and third misfires the same day, I noticed more pops and crackles from the exhaust but I may be wrong at the same time since I was driving a ****ty C300 loaner...
My Sales Associate was telling me they once had a cab misfiring when they were unloading the car for the first time to dealership few months ago.
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
