C63/C63S AMG
C63S Ticking Noise
Old Mar 21, 2021 | 12:09 PM
Djordy's Avatar
C63
Originally Posted by Jimmy_c63s
Argh. Sorry to say this but that's the timing chain guides. Same issue @velosdesignwerks had, as mentioned above.
Is yours under warranty? If not, argue for goodwill and get it sorted asap.
I've been following a thread on the German forums about this (over here).
No warranty. Any idea about the costs? Am I thinking of thousands of euros / dollars or more like 1000/1500?
Old Mar 21, 2021 | 12:11 PM
Jimmy_c63s's Avatar
Have a look at the link I posted above. Guys in Germany reporting about 7000€ was their bill so around $8500 USD.
Bear in mind that most of these fellas went through Mercedes dealers so an indi would be cheaper.
Better still, ask for goodwill at Mercedes. Escalate it and make them pay for at least half.
Old Mar 21, 2021 | 12:13 PM
untamedd's Avatar
2019 AMG GT R
That's it. Louder ticking on the right side of the engine when standing in front of the car I meant.
Your car is all good bro she's still going strong after all these years. Apart from the old secondary cat delete fiasco you went through with the dealer 👍
yeah man but that too was a blessing in disguise because it made me get the AWE Track exhaust. Warranty is up this summer so might upgrade to the 275/305 combo and get a tune.
Old Mar 23, 2021 | 04:26 AM
Jimmy_c63s's Avatar
After 6 minutes that noise is gone. Something to worry about?
Hi, got your visitor message. I posted the link above. Good luck.
Old Mar 23, 2021 | 09:44 AM
notabenex's Avatar
C63 W205 17' + W205 C250@brabus + NSX 95'
c63 engine noise
Guys can you hear any weird noise? My engine has over 100 000kms, and 60000 with the tune..
thanks
Old Mar 23, 2021 | 09:56 AM
Jimmy_c63s's Avatar
thanks
I couldn't hear anything irregular, but could you take another video just a bit further back from the engine bay please? The sound we don't want to hear is the cricket sound of "tek tek tek tek".
In your video all I could hear was the normal injector sound but the video was a bit short and close to the engine.
Old Mar 23, 2021 | 11:08 AM
  #32
FLC63s's Avatar
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
agreed.. step back a bit, you can actually close the hood and film from the outside next to the wheel wells and hear it if it was the timing guides.. (the crickets)
Old Mar 23, 2021 | 05:27 PM
  #33
Ksun_w205's Avatar
W205 C63 S
Hello, can you all please also listen to see if I have the sound. I do hear a sound but it isn't exactly the same as the video Jimmy_C63s posted and its actually a little more pronounced when you hear it through your phone rather the computer.
Its more of a slight whistling noise then cricket/ tek tek sound.
Thanks!
Old Mar 23, 2021 | 05:31 PM
  #34
FLC63s's Avatar
Thanks!
https://youtu.be/KgSxJtZDVJU
thats normal
Old Mar 26, 2021 | 12:09 PM
  #35
Jimmy_c63s's Avatar
Yes yours is normal no problems at all 👍
Old Mar 30, 2021 | 06:50 AM
  #36
Djordy's Avatar
C63
The dealer said they found the problem, it's my fuel pump and they replaced it yesterday.
I know c63 w205 fuel pump is a common problem.
This morning with a cold start I can still hear that sound.
I'm going to test it again at the end of the day, if I hear it again I want an explanation from the dealer.
velosdesignwerks How did the dealer find out it was the timing chain guides?
Old Mar 30, 2021 | 10:24 AM
  #37
FLC63s's Avatar
This is the first time I am hearing of a Fuel Pump (common problem) ... but any ways.. understand this......
The fact that your dealership "found" or said they found a problem, is sorta suspect to me, as I didn't hear a clip of what sound you were referring too, but since you posted in this thread, I have to go with the sounds that most reported here and those by far were NORMAL noises our cars make. ( if you have a Chirp and or Cricket sound, then its possibly something more serious)
A Fuel pump noise (which are cars do make, and they make noises when they PRIME up for start, and so forth) can fail. and do fail just like any other part , more so if there was bad fuel or crap that blocked the hoses, and or added more resistance to the fluid flow that caused the pump to wear and tear more then normal.
If you want to go hunting for a problem, you are most likely to cause more then you bargained for......
What exactly is it that you are going to TEST ?? none of your post below make any claim to an issue, other then a SOUND, that was NOT as loud as others, and it went away after 6 minutes ??
In my opinion, dealership prob said / replaced fuel pump to get you out the door.. ( and since I dont know you, I cant make any statement to the adverse )
Just saying... IMO
Old Mar 30, 2021 | 10:30 AM
  #38
Jimmy_c63s's Avatar
No man it's not your fuel pump and has nothing to do with it. Your dealer is full of sh*t, don't let them stuff you around. That sound will continue to be there until the real issue of the timing again guides are sorted.
Exactly bro.
Old Mar 30, 2021 | 10:34 AM
  #39
FLC63s's Avatar
No man it's not your fuel pump and has nothing to do with it. Your dealer is full of sh*t, don't let them stuff you around. That sound will continue to be there until the timing again guides are sorted.
That is my point, but the poster didnt supply any sound clips, and he stated it wasnt the same sound as the Timing Chains... I think he doesnt really understand what he is hearing ,and is just "Freaking" himself out on something.
Hence why I asked, what type of TESTING he says he does, or what ever.. Our cars make all sort of noises, if you want to hear some crap to freak you out do this:
1) park your car
2) turn off car, remove key and just SIT
3) site nice and quiet for 2-3 minutes
During which time you will hear your car basically doing all sorts of crap ... all 100% normal.. same crap happens when you start up your car.. ( more so on an AMG)
Another reason, you just dont START and DRIVE, these cars need to warm up, cycle thru its checklist and get stuff ready to go
Old Mar 30, 2021 | 10:54 AM
  #40
Djordy's Avatar
C63
1) park your car
Here's a video of the sound. By testing I mean just listening again at the end of the day haha.
Old Mar 30, 2021 | 11:01 AM
  #41
FLC63s's Avatar
Exactly bro.
https://youtu.be/FZuv_Qp3vzk
Well that KNOCKING sound (if thats what your stating, is def NOT a fuel pump)
Old Mar 30, 2021 | 11:08 AM
  #42
Jimmy_c63s's Avatar
Good video. It's the timing again guides 100000% you can hear the chirping/crickets sound very well. It's very distinct.
How long have you noticed this sound happening in your car for?
Old Mar 30, 2021 | 11:10 AM
  #43
FLC63s's Avatar
10000% agree with you Jimmy_c63s , if I would have seen this video before, I would have said the same... Fuel pump my **** ...
Old Mar 30, 2021 | 12:43 PM
  #44
Ksun_w205's Avatar
W205 C63 S
Just wondering should timing chain guide and a belt squeal sound the same? I occasionally get a cold start belt chirp squeal but never a sound of this tone, rhythm, and frequency. Would you say a belt chirp is more like a bird sound while timing chain guides are like a hollow cricket sound?
I read another thread where someone had this issue and brought it to Mercedes and on their receipt invoice it says "We are aware about number of AMG vehicles with this sound. We assume, it is going from valve gear (chains?) Customer need to know, that this annoying noise doesn't harm engine, nor performance of the car. As the car is fully usable, your service stuff can reassemble car and it can be given to customer. At this time we have no solutions for it, but we will inform you as soon as we find it."
Old Mar 30, 2021 | 12:55 PM
  #45
Jimmy_c63s's Avatar
That's fine the squeak is your pulley and accessory belt needing replacement soon. Even after replacement you will still get the occasional squeaks on cold start especially if the car hasn't been driven for a few days or after heavy rain (as mentioned above in this thread).
The timing chain guides sound, as you described is that distinctive, hollow, cricket sound of tek tek tek tek on cold start. That's the bad one.
Just to be clear so far on M177 noises:
⛔ Timing chain guides: Cricket sound tek tek tek tek that disappears after about 5 minutes after cold start (Bad, Urgent & Expensive)
✅ Injector sounds: Tick tick tick tick sound especially louder on right side of engine when standing in front of the hood (No issue & Normal)
✅ Belt and pulley: Squeaks which usually disappear after car is warned up (Fine & Not urgent)
Old Sep 29, 2021 | 12:26 PM
  #46
amg8's Avatar
MY17 C63s Sedan
CRAP! I think I have this cricket noise!!
Old Sep 29, 2021 | 12:32 PM
  #47
George_1992's Avatar
C63 S Coupe
nah?? U sure....... how long have u had the noise for?
Old Sep 30, 2021 | 03:44 PM
  #48
amg8's Avatar
MY17 C63s Sedan
Is this the cricket noise?
Old Sep 30, 2021 | 03:45 PM
  #49
Jimmy_c63s's Avatar
https://youtu.be/763SKr2lHtU
No that's your belts/pulleys.
Old Sep 30, 2021 | 05:14 PM
  #50
amg8's Avatar
MY17 C63s Sedan
hmmm sounds about the same as the videos above? Where's the distinction? Also is this normal for only 25k miles on the clock?
