C63S Ticking Noise
I asked for one of the old secondary chain guides back so I can show everyone that it is just an annoying sound and you don't have to be worried about your timing chain, or timing components harming your engine. Here's a video of the old arm and how it rattles. The noise is caused by the plastic guide being loose against the metal arm. Also, the plastic pad that the tensioner pushes on can also rattle. The shop told me the new tensioner arm is redesigned to be one piece that includes the arm itself and where the chain rides.
I hope this puts some people's minds at ease. Your car will be fine if it has this noise. But, I am glad I was able to get mine fixed, because it sure would be hard to explain if / when I sell it.
This post alone will now help owners forever and at least we have confirmation that it's just an annoying sound which is harmless.
A win for the C63 boys (and girls) 👍
this is the first nice car i have ever owned, I've only had it for 4 months and now out of nowhere I'm getting this bad noise. what do you guys think it is? i feel like I've been done a disservice and the guy that sold it was dodgy i guess. i had it pre inspected but nothing was picked up. it could be coincidence i guess, its been 4 months.... i haven't had it serviced myself yet, as i haven't hit the kms, but was planning too very soon, then this happened. From hero to zero in 1 start up.
Its a 2017 C43. Zip file is all i could get to work, seems weird lol.
IF it is a timing chain component you are risking catastrophic engine damage if the chain jumps timing. What happens is the valves will hit the pistons and bend, and the valves may also put holes in the pistons.... basically.... new engine time if it jumps timing.
and second chain guides of the timing chain (PFL).
(The chain guides are updated ( sliding rail on aluminium support to sliding rail on plastik support) I hope you understand what i mean - if not ask.
Has someone the partnumber from the purge valves ?
addendum: A2054708701
Your P001177 code is for a "intake camshaft position actuator", which kind of confirms my thoughts. That intake cam shaft is out of position and setting a code. I suspect a timing chain guide tensioner is leaking, or a variable cam timing solenoid (aka "position actuator") is clogged or bad, or something similar in the timing chain system. Either way a qualified mechanic needs to get in there.
The danger is that if it jumps timing during that time when everything is "loose" and it's rattling then the damage is done.
If you want to try a good engine oil treatment cleaner (like BG "EPR") and then do an oil change with OEM spec oil to see if it clears up a blockage, maybe you'll get lucky and it was just some sludge blocking an oil port or passage in a tensioner or solenoid or something.
Again, when everything is loose and rattling like that you run the risk of it jumping several teeth on the timing gears and you will have almost instant catastrophic engine failure (faster than you can react)... By the time you hear a bigger knocking / problem the damage is done.
Have you no statutory warranty if you buy from a commercial dealer ? The C43 engine (6 cyl) is not bad - i heard nothing bad about it.
