C63/C63S AMG
Did the dealer just give me the wrong spark plugs?
Old Jun 29, 2025 | 09:11 PM
MBEnt63's Avatar
c63s
I got these spark plugs for my C63s from the dealer, and I told the parts guy my cars vin number and everything and when I googled the part number on these plugs many websites said these are not the ones for my car while the parts guy insisted that they the correct ones. so I’m a bit confused right now. Would these work on the M177 or should I return them?
Old Jun 30, 2025 | 12:02 AM
G63GT63SE's Avatar
2025 AMG G 63 SUV /// 2025 AMG GT 63 S E Performance 4 Door Coupé
Merc USA parts site say they’re for 2.0L L4 - Gas specifically in the Metris and Sprinter
Old Jun 30, 2025 | 01:07 AM
Jimmy_c63s's Avatar
Those plugs are for a sprinter van 😂
Old Jun 30, 2025 | 02:02 AM
jj18's Avatar
2019 C63S Coupe
. The spark plugs installed at the MB dealership were Part# 0001590500. I have a 2019 C63s coupe. The plugs were replaced on the 5 year Service in April 2024.
Also note photo below for reference
Old Jun 30, 2025 | 06:50 AM
MBEnt63's Avatar
c63s
bruh I'm cooked
Old Jun 30, 2025 | 06:56 AM
Jimmy_c63s's Avatar
bruh I'm cooked
Hahaha don't worry just return them. I swear dealers are retarded
Old Jun 30, 2025 | 07:00 AM
MBEnt63's Avatar
c63s
uhh the mechanic installed them, but I still had my doubts. The dealer parts guy did say if they were the wrong ones I could return them even if I installed em so hopefully they will accept it lol.
Old Jun 30, 2025 | 07:10 AM
Jimmy_c63s's Avatar
That's not good man lucky you checked. Whatever you do, don't drive the car like a madman until it's got the new plugs. Dealer must take those plugs back and give you the proper ones, it's their fault.
Our cars are sensitive with the plugs and wrong ones will cause problems. Not trying to stress you but having the wrong plugs can create a lot of issues including damage to the engine as noted here. So get those plugs out and put new ones in asap.
Old Jun 30, 2025 | 07:13 AM
MBEnt63's Avatar
c63s
funny thing is, I replaced those plugs cause my car was having a misfire and just bought new coils cause new plugs didn't solve the issue. Thanks for the help appreciate it
Old Jun 30, 2025 | 07:17 AM
Jimmy_c63s's Avatar
Don't worry lots of us have gone through these issues and similar with dealers and mechanics. Really good work you checked them though.
Your car will be fine, please let us know how it goes 🤝
Old Jun 30, 2025 | 08:03 AM
hyperion667's Avatar
2012 CLS63
LAME! Imagine the people that are not checking! You'd think the almighty 'dealership' would have the correct knowledge but this goes to show!
Thanx for sharing
Old Jun 30, 2025 | 09:22 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Thanx for sharing
That would never happen at the dealership@SW20S goes to 😉😉😉😉
Old Jun 30, 2025 | 11:47 AM
2012 CLS63
Old Jun 30, 2025 | 01:51 PM
C43 Fun Haver's Avatar
2015 ML63
This is bad.. these aren't even sold for any eight cylinders so the fact the parts person grabbed eight is just brutal. Sorry you gotta make another trip back.
Old Jun 30, 2025 | 02:09 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
Literally nothing would surprise me! I think you have me confused with somebody that trusts dealerships, quite the opposite!
Old Jun 30, 2025 | 05:51 PM
MBEnt63's Avatar
c63s
Thanx for sharing
Yeah either their program is faulty or something cause they kept on checking these plugs compatibility with my vin number and their system kept on saying it's compatible. I wasn't bothered with that so the parts guy just replaced them for me and apologised lol.
Old Jun 30, 2025 | 09:00 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
MISFIRES IGNITION TUNED-UP
Your all-new ignition tune-up did not prevent misfirings... you're not alone.
Does this come with laggy throttle, right?
I think your ECU may well be enforcing lean penalties.
Go ahead and simply "clear faults", this will restart normal cylinders fuel spraying. Good until ECU relearns same penalties.
Keep us posted on progress to solve this.
Old Jun 30, 2025 | 09:18 PM
MBEnt63's Avatar
c63s
First thing was I replaced the plugs, drove the car for less than 0.1 Km’s and the CEL came back so it instantly went back to the garage and the mechanic said coils were the issue. I got that today and my mechanic will replace them tomorrow since he was quite busy with other cars today. I’m in the Middle East and I heard in USA they replace those coils for free, sadly that’s not the case here. I will update you guys tomorrow when the new plugs and coils are installed!
Old Jun 30, 2025 | 10:04 PM
I hope new coils do solve your misfires.
Old Jul 2, 2025 | 09:33 AM
MBEnt63's Avatar
c63s
sad update, changed plugs and coils, CYL8 misfire is still there I got a “slightly” used coil since a new one isn’t available and I have strong feeling this used coil is faulty, I took it to an actual Mercedes specialist and he’ll check my car using xentry and check everything else. Hopefully it’ll go well. Will update you guys asap
Old Jul 2, 2025 | 11:54 AM
WEAK CYLINDERS COMPRESSIONS
All good ignition still misfire... this is now inching its way towards leaky cylinder contribution:
  • (leaky valves)
  • (bore score)
  • #1: carboned rings!
Ask for a relative compression test BEFORE replacing any of the pricey injectors. It will show a weak Cyl.8 plus a few marginal cylinders.
Then visual inspection to confirm how pistons crown look washed off.
Old Jul 2, 2025 | 12:45 PM
MBEnt63's Avatar
c63s
  • (leaky valves)
  • (bore score)
is that really the case? The cars done 30K miles only and I just serviced it 1000 Km’s ago, it was running very smooth, the old plugs didn’t seem worn out badly so I feel like the coil is still the issue, I’ll look at what the diagnosis says and hopefully it’s not the engine cause I barely drive this car and it’s my joyride car
Old Jul 3, 2025 | 08:23 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
until the diagnosis is done, who knows. The visual inspection of that cylinder will be telling. If an injector was stuck on and washed the cylinder, it may have scored relatively instantly. The mechanical inspection of the cylinder will give you a numerical answer.
Old Jul 3, 2025 | 08:31 AM
Wait, have you tried a NEW coil yet? I mean, not to be a dick, but - if you can not afford a coil at any given moment...this may not be the right car for you. I keep three new coils in my garage at all times (I have three MB V8 cars that use the same coils).
Old Jul 3, 2025 | 08:34 AM
MBEnt63's Avatar
c63s
My guy if you could read I did write new coils weren’t available where I live and they’re on back order. the parts guy here in the dealer doesn’t know **** about AMG’s I’m convinced they have new ones and he doesn’t know it. I bought a used one from a friend and I will order a new one online in case if it’s coils that are causing the issue. Have a good day 😁
