Adjusted links and ABC visit workshop on.
When I returned home I tried to raise and lower to see what happens and pump did not work. So I shut car off and tried it again and it worked Workshop light not on anymore. Not sure what happened, do you think by me raising and lowering it numerous time to adjust links somehow locked something up. The pump still works and it will raise and lower but as soon as I drive and park it will not work unless I turn the car off first.
Any advice to try first, or should I leave it overnight to see what happens?
I just recently experienced this 2 days ago when I was raising and lowering to adjust my links evenly. My mechanic next to our shop specializes in Jaguars and Mercedes and has changed alot of ABC suspension told me to check the struts I may have a leak . I don't notice any sagging on any sides of the vehicle. Most problems I have found of forums are having pump problems and cars with uneven height. My pump is actually working fine. I am just unable to control the pump as soon as the car ABC workshop light comes on at 30mph unless I shut the car off and start it up again. Any ideas please advise.
I thought it would solve but no luck. I will be bringing it in to get it checked out, crossing fingers.
Never had a problem with this 'lower' level.
Sometimes a level calibration is all that is needed. Sometimes it is sensor(s).
Sometimes valve blocks leaking although in your case I'd guess one or both of the first two.
I pretty much got the vehicle leveled all around and fluid level right.Also saved some money going to the dealer for now.
I pretty much got the vehicle leveled all around and fluid level right. Also saved some money going to the dealer for now.
R.K.
P.S. links are fine a lot of ppl run them on their car, I have a Renntech V3 module on order but im going to run both links and a Module so I can go really low
I got the error ABC workshop light to stop coming on. I dont think it is absolutely fixed but I narrowed the problem down to my rear pass sensor. When I was adjusting the height before the problem occured. The right rear sensor was not adjusting accurately and the link was at max as far as lowering. I guess the system recognizes the sensor was bad or the height diff and shuts the system down at 25-30mph. What I did was swapped links on the rear to see if I still have the same adjustment problem and I did. Ever since the swap of the rear links and slightly higher height adjustment all around the error hasnt come on yet.
I have the LOMO V2 with remote which is the same one that Renntech uses except it costs a lot less.
R.K.
I run a Brabus lowering module set in position I.
