CL-Class (W215) 2000-2006: CL 500, CL 600
New UK CL600 Owner
Old Oct 9, 2016 | 06:36 AM
stuartph's Avatar
Cl600 TT
New UK CL600 Owner
Hi Guys
Just saying hello
I picked up a 2003 cl600 yesterday
It has a few niggles which i will sort and probably ask questions on here
Pic to follow
Stuart
Old Oct 9, 2016 | 06:37 AM
tusabes's Avatar
Mercedes
Originally Posted by stuartph
Hi Guys
Just saying hello
Pic to follow
Stuart
welcome!!
Old Oct 9, 2016 | 01:41 PM
Welwynnick's Avatar
2006 S600
Whereabouts in the UK?
Nick
Old Oct 9, 2016 | 03:51 PM
stuartph's Avatar
Cl600 TT
Thanks tusabes
Nick i'm in Harlow
Old Oct 9, 2016 | 04:59 PM
Welwynnick's Avatar
2006 S600
I used to work in Harlow - not so far. Shout if you need help.
Nick
Old Oct 10, 2016 | 12:10 PM
stuartph's Avatar
Cl600 TT
Hi Nick
Not far at all , hardly any cl's over this way
Thanks for the offer i might need some help soon had an ABC msg pop up today
Stuart
Old Oct 10, 2016 | 02:46 PM
Welwynnick's Avatar
2006 S600
Hi Stuart,
Check the fluid level in the ABC reservoir.
There's a lot you can tell from the fluid level, but for now be happy if there is still some in there.
If its empty, don't even start the engine.
If you have a warning light on, try to avoid the temptation to change the suspension height, unless you're at home.
Garages generally aren't much help with things like this.
Nick
Old Oct 10, 2016 | 02:56 PM
stuartph's Avatar
Cl600 TT
Hi Nick
There is fluid in the reservoir and its fairly clean
I put the suspension up to its max height yesterday , went to its full height ok but when lowered it fell rather than gently lowered? maybe that caused the message
Its ok it wont be going into a garage , its just me who will do all the work
Stuart
Old Oct 10, 2016 | 04:08 PM
tusabes's Avatar
Mercedes
Hi Nick
Stuart
if fluid is clean and full and it goes up/down when using the ride height button you are probably ok
Old Oct 10, 2016 | 08:23 PM
Jack_88's Avatar
2018 C300
Sudden drop for lowering...sticky solenoid in the valve block, maybe. Did it seem that the drop was sudden for one end of the car in particular? If it doesn't do it again, I'd say don't worry about it. I would agree with Nick, don't start trying to play with things you're unsure of unless you're home. Bit of a pain trying to sort the car out on the side of the road or in a car park.
Old Oct 10, 2016 | 09:49 PM
calgary's Avatar
2001 Mercedes CL500 2006 E350 4-matic
"Fluid is fairly clean" ?? If it is not light green in colour and really clean, I would change it together with the ABC filter.
Old Oct 11, 2016 | 08:01 AM
stuartph's Avatar
Cl600 TT
Guys
fluid in ABC res is above centre mark cold
I shall check level when hot
Old Oct 11, 2016 | 10:37 AM
Welwynnick's Avatar
2006 S600
Hot or cold doesn't matter much. It matters whether the engine is running, and the system is pressurized, in which case the fluid level is lower. The fluid is used to compress the nitrogen in the four accumulators.
If the oil level DOESN'T go down by the right amount, ( either too little or too much) that points to an accumulator problem somewhere.
Nick
Old Oct 11, 2016 | 10:53 AM
stuartph's Avatar
Cl600 TT
Thanks Nick
I shall report back on that
In the following picture of the charge cooler top up cap , should the water level be near the top , I topped up with anti freeze and I know I will need to vacuum bleed
Also is there a dipstick missing from the tube behind in picture
Old Oct 11, 2016 | 02:35 PM
Welwynnick's Avatar
2006 S600
Yes, it needs to be vacuum bled, and yes, the coolant should be at the top.
I bet a lot of V12TT's are like that, and will be much slower than they should be as a consequence.
The Mercedes IC bleeding tool uses a compressed air vacuum pump, which is quite inadequate IMHO. This is what you really need:
Vacuum refill kit:
Rotary vane vacuum pump
Old Oct 11, 2016 | 04:05 PM
Welwynnick's Avatar
2006 S600
There's no dipstick missing, though the dipstick tube cover / cap is missing.
That's the tube for the transmission dipstick, which is a garage tool
Readily available on-line. They stick out of the dipstick tube when inserted.
Definitely worth getting. Both difficult and important to get transmission oil level right.
Nick
Old Oct 12, 2016 | 12:33 PM
stuartph's Avatar
Cl600 TT
Thanks Nick
I found a dipstick cover on eBay and it's on its way
Stuart
Old Oct 13, 2016 | 02:09 PM
stuartph's Avatar
Cl600 TT
Me thinks someone's been in here , sensors both side have a screw missing
Old Oct 13, 2016 | 05:30 PM
Welwynnick's Avatar
2006 S600
Nothing unusual; nothing to worry about.
Its sealed with an O-ring, not a gasket.
Removing and dropping nuts, bolts, screws and washers in the V12 engine
compartment is an occupational hazard.
Nick
Old Oct 14, 2016 | 08:12 AM
stuartph's Avatar
Cl600 TT
Oh that's ok then , they seem secure enough , I'm just not a fan of missing bolts and screws.
I'm still waiting on my cooling system filler to bleed the charge coolers. Is it possible if the pump is dead or system not maintained that the fluid can be boiled out.
Another question front tyres are 255 35 19 , anyone have an idea on a correct cold pressure.
Stuart
Old Oct 17, 2016 | 07:36 AM
stuartph's Avatar
Cl600 TT
Guys
Here is a pic of ABC level with engine running, it's at lower part of dipstick
On start up engine cold and not been run over weekend , loud buzzing can be heard and felt from oil filter housing , went away when hot, oil level on dash display says oil level correct , is the noise normal?
Stuart
Old Oct 21, 2016 | 06:24 AM
stuartph's Avatar
Cl600 TT
It's back , but on re start it's gone
Old Oct 21, 2016 | 04:25 PM
Jack_88's Avatar
2018 C300
Any sign of leaks from any of the ABC hoses or struts? Any corner of the car drooping overnight?
Old Oct 21, 2016 | 06:43 PM
tusabes's Avatar
Mercedes
Guys
Stuart
a loud buzzing on startup is a symptom of a failing pump
Old Oct 22, 2016 | 09:03 AM
stuartph's Avatar
Cl600 TT
Their is wetness on one of the hoses that runs along the front of the car
the buzzing is from the oil filter , could it be transferred from the pump? To the oil filter housing
