V12 twinturbo intercooler caps
I couldn't get why this kept going on and of course looked a few times at my cap
it looked ok but wasn't
look at the old cap, after buying a new one from MB (only 16euros)
I tested the old rubber and it broke of, meaning it was dead
hope this helps at least a few of you
and of course, vacuum with your home made kit:
https://mbworld.org/forums/m275-v12-bi-turbo-platform/562924-intercooler-circuit-overflow-reservoir-2.html
https://mbworld.org/forums/m275-v12-...servoir-2.html
I've seen that, this was just for those who wan't to keep originalI am having a aluminum tank maker building me a custom 25 liter icebox tank for my trunk. for me the best solution for overturned turbos
once I received the tank I'll see if I need a overflow too and where
if you have any info for icebox tank installs you're welcome
I would have freaked out lol*
I was so surprised that I missed that as visually, and touching with my fingers, that cap looked ok I even bend the rubber slightly but I should have bend it hard first time
thx for your info
look at that
i did that 2 months ago and had since that day no more problems, no limb mode, no CEL,....
very recommend
https://mbworld.org/forums/m275-v12-...atibility.html
and the best of all: the system bleeds by itself
very recommend
very recommend
very recommend
However, it doesn't bleed the system. The system is full of airlocks, that doesn't change, and you still have to bleed it.
Nick
thanks.
p.s. dealer wants $20.17 and is 50 miles away. i'll bet online for half the price if i can locate one.
hi nick. i think that too but at least the water level in the new header tank falled the first three test drives. now the level ist absolutly constant. after this knowledge i am sure it bleeds a bit by itself.
very recommend
A0995003603 full size radiator
A2792000185 Tank
A2790980891 rear metal line to tank
A2790980283 rear rubber hose
you got a real HOT upgrade, for only
+-500eur
I am going for this ! + trunk 7 gallon / 25L icebox
hot hot hot !
I would need those connection plugs, if anyone know if there is a place to buy these without hose or if this is on all models from XXX on EPC they have them but with weird hoses
The connectors are quick release, so you would need the mating receptacles from the matching hoses. I couldn't find them though. Might be able to use a BMW, Audi or VW part?
For my own curiosity, could you measure the L x W x D of the finned matrix?
Thanks, Nick
so I'll go for modifying the in and out
- Parts list -
Mode MD mode Mod. des. overview S-SEDAN LONG WHEELBASECatalog P24Major assembly:
Major assembly MD
Group 50 - RADIATOR
FIN/MD 222176 VIN Sales designation S 600 Assortment class Car Market All
Subgroup 190 - AIR PUMP,
WATER PUMP AND DETACHABLE BODY COMPONENTS
Item no. Part number Designation/description Quantity Version
150 A 222 501 37 91 COOLANT HOSE
FROM RADIATOR TO WATER PUMP
001
170 A 222 500 89 72 COOLANT PIPE
COOLER TO PUMP AND EXPANSION
RESERVOIR
Code: -805-806-807-808
001
170 A 222 500 06 00 COOLANT PIPE
RESERVOIR
Code: 805/806/807/808
