tpms on dash after low tire pressure, help
thanks
thanks
verify that all sensors show live, if not, the flat tire one is dead
let me know
make sure you have it activated in dash
then as I show you ect
if you reactivate with the dash button, you must drive for a few miles
sometimes it works, sometimes not
insist, with das or dash button
that for all tires
didn't that work ?
if not you'll need the read the code on each sensor and input it manually
also, for some fonctions you need Developper Mode activated in DAS
btw, what does 4 BAR translate to in LBS?
maybe they use a standard code, the same 4 each time
try using 1001 1002 1003 and 1004
no matter how many times I try resetting it keeps coming back every time I start the car . Annoying but I'm not going to spend $100 to have someone with star fix it
you have to be aware that these sensors have a short lifetime
a few years only
they die and don't have enough sending power
mine were not working when I bought the car
buy a new compatible set from ebay
write down the codes from each sensor, that goes like 5D5V45 ect
then in DAS enter this manually withe the option you need time to buy them and you don't want the light, go in das Cluster variant coding, mark tire pressure NOT PRESENT
then in Central Gateway, variant coding, NOT present and you'll have no more warnings in DAS
This is what I did when I switched to my Brabus rimms
the white error reappears at every restart .
bought a set from ebay, couldn't get them work
by entering the serials manually it worked immediately
also, some workshops use a sensor reader, with that tool you can wake up the sensor and read the codes from outside the wheel, that is why they are so quick
