HELP CL55 Vacuum doors and trunk Not Working
Mercedes CL55
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
Hey guys, just picked up an 03 CL55, seems as though it has a few electrical problems....
One, it seems as though I may have the valet key, whenever I hit the engine start button the car is saying chip not recognized. The keyless-go unlocking doesn't work aswell, and i'm thinking it is for the same reason.
Two, my vacuum doors, vacuum trunk and auto trunk close button are not working, yet I can hear the pump going.
Three, the guy I bought it from says it needs a new amp, which is why the entire nav, phone, and audio isn't working. I pulled the trunk pieces back and there is just multiple boxes and wires sitting loose all over the place. Not even sure what's going on there.
Four, the dash is saying some silly message about the phone system, probably has something to do with the mass of unplugged wires and boxes protruding inside. PLEASE HELP
1st,
The '03 uses a black key-card, about the size of a credit card, for the Kyeless-Go system. It's not embedded in the key fob like the '04 and newer cars.
2nd and 3rd.
Looking into the trunk, behind the panel on the left, just above and forward of the CD changer is the manifold for the vacuum system. If there are any cracks or leaks there, you'll have problems with the door soft close. If someone was in that area trying to fix/replace the amp, they could have easily damaged the vacuum system.
More 3rd
The COMMAND (audio, nav, phone, CD changer) system is all connected via a fiber optic link. If any one component is removed, the link is broken and the system is dead. Sounds like someone may have tried to replace the amp or something but didn't know what they were doing. Wish you the best of luck there.
4th
(See "More 3rd")
Mercedes CL55
Oh Boy.....
1st,
2nd and 3rd.
More 3rd
4th
(See "More 3rd")
1st,
2nd and 3rd.
More 3rd
4th
(See "More 3rd")
http://www.ebay.com/itm/OEM-MERCEDES-BENZ-SMART-KEY-CARD-KEYLESS-REMOTE-KR55WK48028-/281104676276?pt=Motors_Car_Truck_Parts_Accessories&hash=item417324f5b4&vxp=mtr
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Yes that is the card. NO DON'T buy it from Ebay, as it wont work.
You need a new "GREEN" (un-programmed) card in order to have it coded for your car.
Mercedes CL55
Oh really? What do you mean by "green" card, and where can I find one of these? Is it a secondary piece to the key, just like the original ?
Super Moderator
I may have confused the subject. When you get new smart keys they need to be GREEN which means (VIRGIN NEVER PROGRAMMED).
Once they have been programmed/coded and paired to a vehicle, they can never be used on another vehicle again. Same goes for it you remove them from the coding on a vehicle.
However, the keyless go card may be able to re reporgrammed.
See:
http://bayhas.com/mercedes/cl215/con...key_assign.htm
See:
