Do these “normal” temps see high?
The only thing I like about the Sport cluster is that everything goes from blue to red in the MBUX. This is nicer at night as it’s easier on the eyes. I really would like it the MB had the capability of red in the other clusters also.
That said, it is doctored:
https://mbworld.org/forums/w212-amg/...-liar-too.html
https://mbworld.org/forums/e-class-w...inda-liar.html
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Transmission somewhere between 150 and 225F.
There may be an int er cooler between the transmission fluid and the coolant.
This would stabilize the temperature.
Engine oil between 200 and 250F.
Unburned gasoline gets past the rings on a cold start and ends up in the oil.
Water from combustion allways drips past the rings and into the oil.
To evaporate these, you want the oil to run about 212F.
There may be a slight vacuum in the oil pan wich would help.
Coolant between 185 and 230F.
Most current cars have a 195F thermostat that regulates coolant flow.
In addition there are fan(s) that may be activated to blow air through the radiator
and air conditioner condenser.
There may be an inter cooler between the transmission fluid and the coolant.
(A 50/50 mix of Ethylene Glycol and water under 15psi of pressure has a boiling
point of 230F.)
