FINALLY INSTALLED MY CLK55 Airbox w/ Green Filters
Subscribe
Mar 31, 2007 | 04:57 AM
  #51
Quote: Just got my airbox and even faster then i thought. Got all parts from OEM and everything looks great. anxiously waiting my green filters to have evrything installed.
jalberto let me know what the deal is holmes. your input determines if i buy the airbox or not. thank you sir
Reply 0
Apr 5, 2007 | 01:36 AM
  #52
Quote: jalberto let me know what the deal is holmes. your input determines if i buy the airbox or not. thank you sir
Airbox from OEMPARTSDIRECT arrived about 5 days after placing the order. I live in PR so it takes awhile. Paid $419 for the set-up and all looks good. Just got my green filters ($100) today so i will be installing tomorrow for the road test. keep you posted on how it performs...
FINALLY INSTALLED MY CLK55 Airbox w/ Green Filters-clip_image002.jpg
Reply 0
Apr 5, 2007 | 01:52 AM
  #53
CLK55 Airbox looks great.
I prefer the Green Filters to the K&N. The K&N was too oily and used a cheaper typr of cotton filter material.
Reply 0
Jul 16, 2007 | 02:28 PM
  #54
Jalberto, post your results!
Reply 0
Jul 16, 2007 | 06:27 PM
  #55
tight **** i might have to add this to my list of upcoming mods.. holy pwnage of the jury when dude posted a pic of his ferrari lol..
Reply 0
Jul 17, 2007 | 12:29 AM
  #56
its time to replace my filters, where's a good place to buy the green filters and what is the brand???
Reply 0
Jul 17, 2007 | 07:42 AM
  #57
Quote: its time to replace my filters, where's a good place to buy the green filters and what is the brand???
Try this place out, this is where i got mine. www.autopartswarehouse.com
2000 - 2002 Mercedes 430 Series Green Air Filter Air Filter Price: $48.95 Qty: 1 Part #: G512240
Reply 0
Jul 17, 2007 | 08:59 AM
  #58
Quote: Try this place out, this is where i got mine. www.autopartswarehouse.com
nOooo dont buy from those idiots...they sent me the wrong items and then took forever with a refund and i ended up losing money on having to ship the filters back to them...their customer service sux cuz their all a bunch or retards !! ....i got mine from www.morethantires.com ....no problems at all and arrived fast and might have even been slightly cheaper...just verify that you're ordering the correct part numbers...
Reply 0
Explore
Jul 18, 2007 | 12:45 PM
  #59
Definately go with morethantires.com and ask for Rick.
Reply 0
Jul 18, 2007 | 12:48 PM
  #60
Quote: Jalberto, post your results!
ok...so i couldn't dyno the car before and after which is the best bet. I did the next best thing...my friend has a G35 coupe and we did some racing before and after just to test any difference.
Airbox gives you a lillte more roar from the motor and racing results prior to airbox we would remain side to side after airbox half a cars length after about 40 mph.
Mod approved!
Reply 0
Jul 18, 2007 | 06:30 PM
  #61
thanks guys for the info.
do any of you have any preference for the green filters or k&n ???
Reply 0
Jul 18, 2007 | 06:36 PM
  #62
Reply 0
Jul 18, 2007 | 11:01 PM
  #63
Guys, help me out here, no matter which airbox you use, seems to me to make no difference. It's not the airbox that matters ,it's the amount of air taken in verses the amount of exhaust you get rid of. You can mount a OX tank on the hood and feed it all the air you want but if you don't change the exhaust volume, what has changed? also the amount of air coming in is limited by the size of the intake scoops at the sides of the radiator, no one has mentioned increasing the size of those. If the filters are the same size green/stock, the difference is only min . I actually do have a green filter on my C class, but bought it because it's reusable not for hp gains. The O2 sensor reads the air/fuel mix and keeps it at factory presets, so where are these 25hp coming from? maybe some of you mechanical engeneers can help ?
Reply 0
Jul 19, 2007 | 12:45 AM
  #64
did you change to the 55 hoses?
Reply 0
Jul 19, 2007 | 02:51 AM
  #65
Quote: Guys, help me out here, no matter which airbox you use, seems to me to make no difference. It's not the airbox that matters ,it's the amount of air taken in verses the amount of exhaust you get rid of. You can mount a OX tank on the hood and feed it all the air you want but if you don't change the exhaust volume, what has changed? also the amount of air coming in is limited by the size of the intake scoops at the sides of the radiator, no one has mentioned increasing the size of those. If the filters are the same size green/stock, the difference is only min . I actually do have a green filter on my C class, but bought it because it's reusable not for hp gains. The O2 sensor reads the air/fuel mix and keeps it at factory presets, so where are these 25hp coming from? maybe some of you mechanical engeneers can help ?
Josh K did a before and after dyno and the *only* thing he changed was the airbox. There was a difference in the dyno number.
I'm working on a DIY section for my website and it’ll have ramblings about airflow. Hopefully that will be of some help. If nothing else I'll be able to cut back on the all night emails responses about how cars work. Anyway, airflow . . . . . . . . let's think about this, a normally aspirated 4.3 liter, spinning at 6000 RPM, at 100% volumetric efficiency (which we'll never come close to seeing), can only flow 455 CFM. Do you think there’s an exhaust impediment that limits flow below 400 CFM?
Lastly, O2 sensors are not used at WOT.
Reply 0
Jul 19, 2007 | 06:34 AM
  #66
Quote: Josh K did a before and after dyno and the *only* thing he changed was the airbox. There was a difference in the dyno number.
The stck exh is killing the potential of the M113 motored cars. From the exhaust mani's all the way to the tailpipe.
Reply 0
Jul 19, 2007 | 10:48 AM
  #67
Quote: The stck exh is killing the potential of the M113 motored cars. From the exhaust mani's all the way to the tailpipe.
Lets look at what doesnt work (could be designed better) on the CLK430 exhaust system.
Is the log style manifold that has exhaust pulses banging off the back wall a problem? Definitely. Is the 90˚ bend in the exhaust tubing a problem? Absolutely. The low pressure zone created by the resonator? It could be better. The low pressure zones created by the cats are minimal and unavoidable (unavoidable if one wants to pass smog in the land of fruits and nuts). The size of the stock tubing? On a non-boosted 262 CI engine that doesn’t see more than 6K RPMs, hollow 2.5" exhaust tubing isn't the problem. Going bigger *may* produce a bigger peak dyno number. However, the problem with going too big is the velocity will fall through the floor, killing any semblance of scavenging along the way. Without midrange scavenging, the dyno will show lower numbers below peak, and the qtr mile trap speed will drop.
Have I got it all wrong? Possibly. But I'm in good company. The GM powertrain engineers think 3" ID tubing is good for the z06, but that engine is over 60% larger and revs to 7K. I know enough about air flow to know that my theoretical blathering about what sized tubing is OK can ONLY be proven using dyno numbers and backing those numbers up with trap speeds.
Going back to benzover's question, I don't *think* the exhaust is strained to the point where the AMG air cleaner assembly doesn't make a difference. Josh K's dyno numbers reinforce my opinion in this area.
Reply 0
Jul 19, 2007 | 11:36 AM
  #68
You are correct in thinking that only so much air may come into the tubes if the intake is the same size. However, with a different size and shape box, as well as higher flow filters, there will be different amounts of air flowing
1) past the hoses to the filters (less turbulence)
2) through the filters b/c it will allow a higher flow rate
3) and maybe (havent looked closely) from the filters to the manifold.
4) making this flow go through faster leaves slightly less time for the air to get heated up by the engine as well.
So as you see, the 2 challenges after the intake hoses are shape for direct flow and high CFM filters. Turbelent flow isn't terrible because it will enhance your gas mileage. However, the laminar (or normal) flow is better for volumetric intake and HP.
Reply 0
Jul 19, 2007 | 12:52 PM
  #69
Lol funny wut my thread turned into....all I know is that I felt a somewhat notable difference when I put in the amg box wit green filters....so for me...it was worth that 500 or so I spent for the minimal hp gain esp wen its so hard ta get significant numbers outa car without spendin thousands....
Devilsangel....I went with green cuz of the good things and gains that I've heard others gettin from usin them n also cuz I herd that many ppl who tried the k&n's ran into MAF issues after cleanin/reoiling....
Reply 0
Jul 19, 2007 | 07:42 PM
  #70
Quote: Devilsangel....I went with green cuz of the good things and gains that I've heard others gettin from usin them n also cuz I herd that many ppl who tried the k&n's ran into MAF issues after cleanin/reoiling....
Ok that works! I'll definitely give the green filters a chance. Thanks for the info.
Reply 0
Sep 24, 2007 | 06:47 PM
  #71
Wow, I thought moving from Toyota forums to Merceds would introduce me to perhaps a more mature group. Apparently not. The Jury has some serious confidence issues to have to post pics of something completely unrelated to the thread to help boost his ego.
Making fun of someone's out of producting car and then flaunting an old *** car is probably not the smartest thing to do. A nice house and nice car, but unattractive personality is so sad. I hope he pulls his head out of his *** soon and joins the rest of the mature folks here who can have a normal conversation without all the craziness.
I wish people like The Jury would either change for the better or completely get off the forum and leave this place for the normal people to speak amongst themselves without their insanity messing up the forum.
Good night.
Reply 0
Oct 8, 2007 | 11:17 AM
  #72
Guys, is this any different from the guy selling the Carbon Fiber Airbox here for $1,500? I believe that the hp gains claimed are about the same.
https://mbworld.org/forums/w211-amg/155686-1-500-cf-airbox-hp-benefits.html
Reply 0
Apr 13, 2009 | 05:25 PM
  #73
ANYONE HAS ! FOR SALE??
Reply 0
Apr 13, 2009 | 09:17 PM
  #74
Quote: ANYONE HAS ! FOR SALE??
Check for sale threads they pop up from time to time
Reply 0
Apr 14, 2009 | 02:51 AM
  #75
can anyone confirm if a C32 or C55 airbox fits in our clk430? i need to kno asap as i have to ppl that has forsale right now
first pic is a C55 airbox, second is from a c32..
FINALLY INSTALLED MY CLK55 Airbox w/ Green Filters-c55stockairbox.jpg   FINALLY INSTALLED MY CLK55 Airbox w/ Green Filters-c32.jpg
Reply 0
