Idling High. Lurching in gear.
Old Nov 1, 2011 | 02:49 AM
Stumbling Corgi's Avatar
2001 CLK430 Cabriolet
I had a new bumper put on my 2001 clk 430, this past weekend and upon return of my car i noticed the outside temp gauge was not re installed correctly and reading 136,after fixing this problem i now notice that i'm idling much higher than normal, Around 1,100 in park. Also when ever i put it in gear the rpm dives to about 400-500 and then soars up too 1,600 then back to around 1,000. Causing the car to lurch forward/back if my foot is not placed firmly on the brake.
Does anyone know what i may be able to do to solve this problem?
Old Feb 26, 2013 | 12:10 PM
mauricekan's Avatar
clk320
I have the same problem here.
The idle is around 1100 at parking and around 800-900 at D with full brake.
The car would automatically accelerate from 1000 to 1500 when it is running without putting on the fuel pedal neither brake.
Please help
Old Feb 27, 2013 | 10:28 AM
mauricekan's Avatar
clk320
anyone can solve this problem?
Will it be related to
1. MAF?
2. Throttle Body?
3. Battery?
4. Idle sensor/pulley?
5. ECU?
6. vacuum leakage?
Please help and this problem is driving me mad and frustrated.
Old Mar 2, 2013 | 02:57 PM
mauricekan's Avatar
clk320
anyone? please help!
Old Mar 2, 2013 | 04:24 PM
Birdseye's Avatar
2013 C63 P31 Eurocharged, 2006 SLK55 R171, 2013 Audi RS5
Have you checked visually for vaccuum leaks?
Also, hesitation and bogged accelleration is common MAF
Old Mar 2, 2013 | 11:17 PM
mauricekan's Avatar
clk320
THANKS FOR REPLY!!!
But I have changed the MAF and the problem goes on!
and I have cleaned the TB too.
How to check Vacuum leaks? seems its hard to trace the leaks by visual?
I have tried to find vacuum leaks but seems no leakages there!
Old Mar 10, 2013 | 10:30 AM
mauricekan's Avatar
clk320
problem solved.
Changed all the vacuum hose around the engine and throttle body.
Changed the Crankshaft Position Sensor (CPS)
Changed the MAP sensor (manifold air pressure sensor)
Changed the Throttle Body Ring.
Problem is solved finally!
Old Mar 26, 2013 | 02:12 PM
mauricekan's Avatar
clk320
fxxk
problem comes back after a few days....
should i change the Throttle body?
Old Mar 27, 2013 | 01:36 PM
bobbyjo9's Avatar
02 clk 55, 13 GL 450
Have you pulled codes yet? You should before wasting anymore time and money throwing parts at the problem. (hint) The CPS would not have anything to do with your problem.
Old Mar 28, 2013 | 12:21 PM
mauricekan's Avatar
clk320
I tried to connect the OBDII and read codes. But there was no code stored.
