W208 vs W209 engine mounts
Old Feb 22, 2013 | 10:18 PM
787's Avatar
787
2002 CLK430
I have not seen this reported on this forum. I put the W209 engine mounts in place of the worn out W208 mounts and they helped a great deal as the old mounts were trashed. But I had a slight vibration though the wheel and door that would not go away. I changed most every thing you can think of over the past few months until I changed the motor mounts back to W208 OEMs. Vibration is gone, just an FYI.
Old Feb 23, 2013 | 11:50 AM
dlbehrns's Avatar
99CLK320,
I have heard the 209 mounts are superior to the 208 but never heard of your issue before. Thanks!
Old Feb 24, 2013 | 10:08 PM
787's Avatar
787
2002 CLK430
I should clarify that the vibration only happened in drive at idle after the engine warmed up (idle is dropped down). Not a big thing but annoying.
Old Feb 27, 2013 | 10:53 PM
Pancho's Avatar
2000 CLK430 Cabriolet
I did the same change-out replacement 2 years ago, and have not had a problem. Might be that a mount was loose or not installed correctly. Who knows? These MB's are fickle mistresses. Glad that you squared away your prob.
Old Mar 1, 2013 | 02:49 PM
787's Avatar
787
2002 CLK430
I doubled checked the install and I'm pretty good with a wrench. I am idling around 550 rpm in drive which could be the difference, or like you said - fickle bit*^*^ in regards to vibrations
Old Mar 1, 2013 | 09:33 PM
Birdseye's Avatar
2013 C63 P31 Eurocharged, 2006 SLK55 R171, 2013 Audi RS5
What's the best argument for going for W209 mounts? I guess I was considering that but OP's experience makes me hesitant. My GF who owns the car is verrrry sensitive to even the slightest vibrations at idle.
Old Mar 1, 2013 | 09:38 PM
dlbehrns's Avatar
99CLK320,
FWIW: I have not replaced my mounts. I have change my intake to vipclk's cold air intake and I get some vibration/hum when the engine is idling low in gear at a stop sign. If you look at the throttle cable where it meets the braket before it attaches to the sending unit you can see where you can adjust the idle up and down by rotating the cable with a small wrench. 1/4 of a turn made all the difference to eliminate any vibration/hum that I experienced.
Old Mar 5, 2013 | 08:47 PM
28-psi's Avatar
2011 E550 Coupe, 2002 CLK55 AMG
Any input on Deutsche Parts for motor mounts?
Hey guys...its been a while
Just looking for advice on vendors for motor/tranny mounts. I am aware of the W209 upgrade being far superior to the W208 mounts but looking to do all three since the tranny mount is pretty dead. Any input would be greatly appreciated!
Old Mar 5, 2013 | 11:48 PM
Pancho's Avatar
Did job about 2 Yrs. ago on my W208.
Got OEM parts in MB boxes at Parts.com
2 W209 Mtr. Mounts Part# 2202400617 $214.80
1 W08 Tran Mount Part#2122400418 $35.40
Here's an instructional I did on the Mtr. Mts.:
https://mbworld.org/forums/clk-class...or-mounts.html
Here's an instructional I did on the Trans. Mt.:
https://mbworld.org/forums/clk-class...cabriolet.html
Old Mar 12, 2013 | 11:32 PM
28-psi's Avatar
Thanks Pancho...I will be ordering them tonight!
Old Mar 13, 2013 | 12:36 AM
Pancho's Avatar
You are most welcome.
Old Mar 13, 2013 | 03:02 AM
rorf's Avatar
clk320 and sl320 V6
I also have a slight tremor (vibration) every now and then at idle even though I changed the engine mounts with Lemfoerders a few months ago at 160 000kms.
My SL with the v6 motor idles beautifully - possibly because it has a different engine mount to the CLK.
CLK also idles at 550 when warm and the SL at 750.
The vib with the CLK320 seems to be a common concern on all the Merc forums.
Old Mar 13, 2013 | 03:27 AM
Pancho's Avatar
Just my opinion, derived from the years and years of "CLK vibration" postings, coming from all corners.
CLK's vibrate, period.
Of my 13+ years of CLK ownership,
I've had about three that were vibration free.
The only way to get rid of your CLK's vibration, is to sell it, but then there will be night after night of weeping, and baleful laments, as you pine at the absence of that fickle, but beautiful, beast.
Hey, it's a CLK thing. You either love them, or you love them more.
Last week I was gassing up my 13 year old fickle beast, and a fellow in a pick up gave me a "nice car". I thanked him. Thirteen years, and she still turns heads.
Old Mar 13, 2013 | 03:38 AM
rorf's Avatar
clk320 and sl320 V6
Yes Poncho you are right - these are still awesome vehicles, hit the loud pedal and it goes like a scalded cat with great fuel consumption to boot
Old Mar 14, 2013 | 01:32 AM
MarcusF's Avatar
2002 CLK430
Two adjacent cylinders, 7 and 8, fire in that order. I always thought that was odd and probably why the engine has a natural vibration. That said, the MB enngineers who designed the engine obviously know more than I do.
