cross-drilled & slotted rotors sanity check
anyway, i called the company back to ask and they claim that's how mercedes does it for my car. however, it just strikes me real odd that 3 of the rotors will have the cross-drilled & slotted patten going one way, while only the front right will have it going the opposite??!?!
have any of you come across this same thing? is the rotor company trying to pull a fast one over me to cover their mistake? any help, pics or ammo would be much appreciated.
so one pic shows the cross-drilled & slotted pattern of the two front rotors. notice they are both going in the same direction.
in the 2nd pic, i tried to show the "vents' within the rotors themselves. since these 2 rotors are of exactly the same mold, one of these front rotors has to be rotating the wrong way, right?
Read mine post #2 regarding rotors rotation....
https://mbworld.org/forums/clk-class...-rotation.html
so klinh, if i understand your insight on that other port correctly while looking at the pic that shows the inside of these rotors... the right rotor is the one that would be going the wrong way, correct?
i've emailed the company twice already and they seem so sure of themselves and continue to tell me that this is the way mercedes does it.
There are directional vanes, and there are radial vanes. Rotors with directional vanes have a left or right side. You don’t put the left on the right or vice versa. Mercedes Benz cars come with either style, depending on the brake package. For example, a W208 CLK55 has directional vanes. A W208 CLK430 has radial vanes. Your photo is of two left rotors with directional vanes. One should be returned for a right side rotor.
I can't believe you guys are still discussing about it!! Excellent infos, MarcusF. Hope the debating stop, now !!
