Premature Rear Tire Wear
I can think of one thing that comes to mind is that you might have a problem with your rear shock and there could be rubbing. I had this happen to me with my front right strut which is bent and the tire creates vibration through rubbing. Vibration is not the worst of it all, it is also the wear.
I suggest you bring to a stealership or have an indy shop take a look.
Yup, you need to answer his questions before we can help you. Here's some signs of abnormal tires wear. Center - over inflated, inner and outer - under inflated, inner only - negative camber, outer only - positive camber, spot wear all over - bad balance or bad strut/shock.....etc.
I found that for my 2004 CLK320, the rear right tire always wears more than the left. 2 technicians from MB told me in separate occasions that for cars with traction control, the rear right tire is the tire who rotates first to test the traction.
Andy
Andy
Damn I'm putting the V12's on in a week. Hope I don't have that problem.
Haven't heard much from the OP in this thread
