Problems to put 19inch rim on my 2004 CLK320
Old Oct 18, 2011 | 10:42 PM
just-tt's Avatar
2004 CLK320
I'm considering to change to 19" rims for my w209 clk320, what is the best tire size and offset that fit my car. Is rims size: 19x8.5 front, 19x9.5 rear, tire size: 235/35/19 front, 265/30/19 rear with ET35 fits my car with no rubbing problem??? Can anyone help!!!!!
Old Oct 18, 2011 | 10:49 PM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
The answer to your questions can be find here.......................
https://mbworld.org/forums/search.php
Old Oct 18, 2011 | 10:55 PM
just-tt's Avatar
2004 CLK320
I did......but still do not have the exact answer....... someone said 235/35/19,265/30/19 with ET35 is fine but someone said it rubs......tired to search again,,,,,Can someone help better with pics
Old Oct 18, 2011 | 11:27 PM
Mka77's Avatar
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
https://mbworld.org/forums/clk-class...nt-thread.html
Old Oct 19, 2011 | 01:13 AM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
The tire sizes are correct but the wheel ET is debatable. Here's the problem - an ET35 from one maufacturer may fit where as one from another may not. I have learned from first hand experience that just because the retailer says "yes it will fit", it might not. Front with ET30-35 should be okay if they clear the caliper, rears at ET35 are a good fit and will still clear if you're lowered.
The biggest problem I've had is that some retailers don't have a damn clue what they are talking about when it comes to the products they are selling, buyer beware.
Old Oct 19, 2011 | 02:19 AM
mikata's Avatar
Mercedes CLK 320 W209
True words!
Old Oct 19, 2011 | 02:30 AM
Kevwood's Avatar
Sad but true. I'm not going to say anything more for the time being but man 'o man have I ever biting my lip for a while now...
Old Oct 19, 2011 | 02:34 AM
mikata's Avatar
You got to let it out mate
Old Oct 19, 2011 | 02:47 AM
Kevwood's Avatar
All I'll say is this - I am giving a certain wheel retailer ONE MORE WEEK to resolve my ongoing issue in an acceptable manner, until then, I am staying quiet.
I respect retailers/forum sponsors but I am looking for the same in return.
Old Oct 19, 2011 | 02:56 AM
mikata's Avatar
Sounds fair to me.
Old Oct 19, 2011 | 12:50 PM
michoblb's Avatar
CLS400 4Matic 2016 / ML 350 2009 / clk 320 w209 sold/ sl 500 1996 sold/ cls550 2008 sold
good luck man!!
Old Oct 19, 2011 | 04:51 PM
just-tt's Avatar
2004 CLK320
thx man, if I want to lower my car, shall I only lower the rear or I need to lower both front and rear?? and which way is better to lower the car(minimum harm to the car): change H&R spring or change bilsten shock? or I need to change both the spring & shock
Old Oct 19, 2011 | 05:19 PM
EuroTra$H's Avatar
19 C300
one other thing... it makes a big difference on the brand of tire you use. some brands have very square profiles others have a more rounded profile... like Toyo fro example. you can run a very aggressive tire size with Toyo's like I do where you could not run that same set up in a more square brand like Goodyear or Kumo.
your best bet is to go to a good tire and wheel shop where try will test fit different set ups for you.
Old Oct 19, 2011 | 05:41 PM
just-tt's Avatar
2004 CLK320
actually I'm considering to use michelin tire in size 235/35/19F, 265/30/19R.....I'm not worried about the tire cuz, dealer can help to find the one that fits my car on 19" rim, the only thing I'm worring is the way to lower the car......
Old Oct 19, 2011 | 09:11 PM
Mka77's Avatar
H&R springs. Shocks....optional
Old Oct 20, 2011 | 05:09 AM
just-tt's Avatar
2004 CLK320
Has anyone tried 235/35/19F,265/30/19R, ET35 all around, Bilstein pro-kit(B12) or bilstein SP(B8) coilover system(both spring and shock)with no rubbing issues?(NO Spacer!!!)
