Intake manifold broken?
Anyway for the millionth time thank you very much for your help and all your details.
Dave
Btw I had a lot of oil or sludge in my valves, so I sprayed them with valve cleaner but plan to do the BG cleaning
I tightened the manifold bolts in two rounds as after first round they got guite loose after few moments. Propably the gasket was getting squeez'd. Yesterday I did the third round after driving a little over week and two of the bolts got a little more tighten. I have very rare misfires and I'm planning to check vacuum leaks with butane gas or similar this weekend.
But despite those very random and rare misfires the engine works great, so much more torgue and no hesitation at all. Those problems almost got me crazy and I was just about to let the car go. But now I'm so happy that I'm going to keep the car.
Now hopefully I will be able to wrap the wagon with HEXIS pearl white vinyl variochrome "has a pink hue" it's seems to be a European product as well as a European thing so you might have heard of it.
I did a lot of reading prior to breaking into my engine bay and was convinced that my actuator had broken which indeed it had and that that was the cause of my problems. However, it was also clear that the manifold runners were shot as well once I removed the throttle body. I have 120k miles and my guess is they (the originals) are good for only 100k miles. I'm also taking the opportunity to replace the injectors so everything is fresh.
I too had the dealer explain that I needed a new intake and was convinced that all I needed was a replacement actuator. My guess is they know very well what they are doing and what kind of shape these are going to be in once they open them up. After all, why would they want to just replace the actuator and spend all your good money for tear down and the fix only for you to continue to have problems because your intake runners are worn out and not functioning properly. On top of the liability of having them come apart shortly afterwards which I can easily see them doing if you ignore it long enough.
My thinking is do this right and do it once even though I'm selling it. But you better believe I'll be asking a premium for the recently completed work. At least I'll be confident it should last someone another 100k miles.
Express worldwide shipping in only 3 days from Australia for $19.00 using TNT Worldwide Express.
Highest quality and precision - an exact replica of your original broken plastic linkage but in high strength aluminium.
Installation is easy with no fiddly washers or split pins - just clip it all on.
Lifetime guarantee
www.monoglobal.com.au
This should fit your c class. Also I'm in Virginia
I have a 2006 C230 with 138K miles. Recently I got the error codes 2187 & 2006 (intake manifold runner control stuck closed bank 1a). I suspected the changeover lever to be broken (as it was the common cause in the forums). I used a boroscope to check that and found that the actuator arm (from 22/9 in the attached pic) had come off from the lever (attached pic). I managed to push the ball and socket joint together and manually was able to actuate the lever and saw that it worked fine. Couldn't check whether the socket was worn off and expanded. But after few days of driving the joint gave up. If the problem is with this joint, I can buy a lever and swirl valve switchover diaphragm to fix it.
But I also observed that longitudinal switch flap shaft (12/4) on the left side was almost coming off (attached pic). Is it normal for that to be so loose? I could easily pry and move the right side too. For now, I have just pushed them into proper place, not sure whether they move any thing inside the intake manifold.
Should I replace the entire manifold or any other suggestions?
Thank you,
Nanda
1. There is plenty of dirt around the manifold and under the manifold. While removing the manifold, make sure the dirt is not accidentally pushed on to the valves. Make sure = remove manifold in one smooth motion.
2 Same applies when removing the injectors. Remove the metal casing holding all the injectors in one smooth motion (the lower O ring will resist). Make sure the injector tips don't touch dirt and if it accumulates dirt, don't use any metal tip to remove dirt. Compressed air helped.
3. Some mentioned about how the gasket doesn't seat well while placing the new manifold. The gasket has pinch points that match with grooves in the manifold. So, first fix the gasket to the manifold and press the pinch points to hold it there.
4. Remember what came out has to go back in while placing the manifold. I forgot a vacuum pipe (one vacuum hose has to be pulled out from the old manifold and connected to the new one) and so had to remove the just fitted manifold to correct.
I forgot to connect the secondary air pump electric connector and got a OBD code and connected it later.
Now, have OBD codes P2188 and P2190 - running rich at idle. I had these issues a year back and had to change the crankcase ventilation to solve. Will check the connections again tomorrow.
Had to remove the injector rail to replace three (out of 6) lower O rings (had only three new at hand). Applied a little engine oil to the O ring and packed everything.
Drove 350+ miles over the weekend and didn't get the error code. Surprisingly got a MPG of 28.6 over 40 Miles with constant speed of 70 MPH. I tested this couple of times to rule out any subtle road inclinations. It's more than Mercedes spec
I just got my car back from the dealer where it had some tranny work done. Aside from the transmission it had also thrown a P2006 which the dealer checked into and orally told me my intake manifold is coming apart and needs to be replaced. About $1700. On the service paperwork this is what they wrote:
":0521 for intake manifold tumble flaps stored in ME-SFI engine control unit. Performed visual inspection and found linkage rod for intake manifold tumble flaps is broken. Recommend replacement of resonance intake manifold."
So I have some questions. First - please enlighten me! Do I need to replace the entire manifold or can I just replace the linkage rod? The car is running fine - what's up with that? Is this a DIY project, as it seems to involve only a couple hours of labor? Source for the needed parts?
Thanks!
My unit started to fall apart in the 70-75k range and finally died in the upper 80k range. I got the new one at part geek
Does that mean extra equipment/Work to make those threads? The Hella one appears to have it.
Last month at 104,000 miles in my 2007 CLK 350, while driving 65 mph on the freeway I got a check engine light.
My trusted mechanic/cousin plugged in his Snap-On ODB2 scanner and got these codes 0522 (intake manifold tumble flap) and 0856 (thermostat)
The thermostat was an obvious no brainier, the OEM part was $125 and a gallon of coolant $15,
He provided me four options
1) OEM dealer part $1,200
2) Distributor OEM part $850
3) Aftermarket (Chinese) Part $550
4) Repair kit for broken flap $350
I chose option 2
$1006 in parts (also including gaskets)
Labor for manifold $255, labor for thermostat $85
Total damage after tax, etc was $1,436.54
After the repair all has gone well and most importantly NO Check Engine light
Though it was expensive I am glad I replaced the entire unit.
He gave me the old part and I may take it apart just to see for myself
I chose option 2
