Please check my VIN for Balance shaft issue?
Old Sep 18, 2013 | 06:36 PM
  #326
Hintowan's Avatar
Mercedes C63 AMG
2008 E350
Hello everybody I have a 2008 Mercedes Benz E350. VIN: WDBUF87X48B262216.
is this engine affected?
Old Sep 18, 2013 | 10:30 PM
  #327
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
MBZ has always made great engine built for the long haul. The problem is that the supplier for this part screwed up. Some percentage of them in the known affected range will fail. Unfortunately, MBZ is very tight-lipped about the percentage of failures, and to make it worse, they are very inconsistent in their out-of-warranty coverage. As for the cost, it's a simple matter of hours to do the work times their labor rates. Maybe European labor rates are lower. Around here, it's $100-$150 per hour.
Old Sep 18, 2013 | 10:31 PM
  #328
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Nope. M272 #801057.
Old Sep 22, 2013 | 10:03 PM
  #329
IslandS62's Avatar
05 E55, 05 Cayenne TT, 06 Carrera S X51
Aloha Rudeney. Although i hate for my first post on a tech forum to be an ask, but i am looking at a beauty of a 2008 E350 sport and would really like the peace of mind that comes with knowing it is outside the affected range of balance sprocket failure.
VIN is WDBUF56X08B188504
Old Sep 22, 2013 | 11:41 PM
  #330
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
you have M272 engine #671980. As expected with a MY2008, you are beyond the affected range.
Old Sep 24, 2013 | 05:34 PM
  #331
Michae52's Avatar
528 BMW
Hello everyone. I have a 2007 350 CLK. The vin is WDBTK56G07T086250. Do I have the kiss of death. Thanks in advance.
Old Sep 24, 2013 | 10:37 PM
  #332
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBTK56G07T086250 has M272 engine #623943 - it's beyond the range for balance shaft issues.
Old Sep 25, 2013 | 09:27 AM
  #333
MonsterLoad's Avatar
2007 CLK550, Tundra Limited TRD
Hi, please decode my vin.
2004 CLK500
VIN: WDBTJ75J35F146254
Old Sep 25, 2013 | 10:10 PM
  #334
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Here you go:
http://benzbits.com/WDBTJ75J35F146254.pdf
Old Sep 26, 2013 | 09:37 PM
  #335
papadou's Avatar
CLK 350 Cabrio
Hi Rodney,
Can you check my 2006 CLK 350 Cabrio VIN WDBTK56G46T072995 for balance shaft issues. Thanks in advance.
Old Sep 26, 2013 | 10:05 PM
  #336
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBTK56G46T072995 has M272 engine #366295, which is in the range for potential failure. I am fairly certain all M272/M273 engines through MY2006 will be in the range.
Old Sep 27, 2013 | 02:19 AM
  #337
papadou's Avatar
CLK 350 Cabrio
Thanks for the info Rodney. Now I gotta figure out what to do. Warranty just expired in June...
Old Sep 27, 2013 | 11:08 PM
  #338
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
It's not a death sentence. in fact, few engines int he range actually fail. My advice is to get a cheap OBDII scanner and check periodically for stored P0016 or P0017 codes.
Old Sep 28, 2013 | 01:43 PM
  #339
papadou's Avatar
CLK 350 Cabrio
Thanks Rodney. Got an OBDII after the CEL came on - here's what it said:
----Confirmed Codes Scan Report----
2 Confirmed Trouble Codes:
1:P0016 - Powertrain Issue
Crankshaft Position - Camshaft Position Correlation Bank1 Sensor A
2:P0017 - Powertrain Issue
Crankshaft Position - Camshaft Position Correlation Bank1 Sensor B
Old Sep 28, 2013 | 02:55 PM
  #340
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Yep, those codes are the tell-tale symptoms of balance shaft failure. It will continue to get worse until the MIL is constantly illuminated. The repair is around $5K (some dealers charging even more). My advice is to either get ready to pay that or sell it NOW before the MIL comes on.
Old Oct 1, 2013 | 05:05 PM
  #341
CST3132's Avatar
2009 ML350 4Matic
Hi, Could you help to check if my 2009 ML350 has the the shaft balance issue base on the engine serial number? here's the VIN: 4JGBB86E29A507649. Appreciate.
I'm trying to register on the https://epc.startekinfo.com/epc/ with no success.
Old Oct 1, 2013 | 10:26 PM
  #342
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I don't think there will be any MY2009s with balance shaft problems, and your engine is a"31" series so it's far out of the affected range.
Here's the datacard:
http://benzbits.com/4JGBB86E29A507649.pdf
Old Oct 2, 2013 | 01:54 PM
  #343
CST3132's Avatar
2009 ML350 4Matic
Thank you Rodney for the look up.
Old Oct 3, 2013 | 01:50 PM
  #344
RCorney17's Avatar
2007 GL450, 2003 BMW 325i
2007 GL450 with P0025 code thrown yesterday along with the CEL with ~80k miles
Can you check this VIN for me? Thanks so much for posting!
4JGBF71E37A248365
Old Oct 3, 2013 | 06:21 PM
  #345
chopperpilot's Avatar
2007 Mercedes ML350, 1999 ML430
Good news and bad news. The bad news is you have engine number 30 130661, which is in the affected range for the potentially bad balance shaft. The good news is the P0025 code is for the cam sensor magnets, which is a cheap fix.
Old Oct 3, 2013 | 06:48 PM
  #346
RCorney17's Avatar
Thanks chopperpilot. So from what I've been reading, replacing all four "cam sensor magnets" is recommended and is a DIY, but to regularly check for the dreaded P0016, and P0017 which are symptoms of the bad balance shaft failure.
I called my SA at my Dealer and they want it for a couple of hours for diagnosis. I'm not opposed to having them do work, I'm just a lot cheaper and just as capable when it comes to relatively simple mechanical replacements. There are no apparent leaks at the cylenoids as described on this thread and elsewhere. No driveability issues.
Old Oct 3, 2013 | 08:43 PM
  #347
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
You've got it - for about half of what you'd pay the dealer for diagnosis and about the same amount of time spent waiting in the customer lounge, you can replace these cam sensor magnets yourself and just keep watching out for the P0016/P0017 codes.
Old Oct 4, 2013 | 07:39 PM
  #348
benzoolie's Avatar
e500
Looking at getting into an 06 E350, VIN: WDBUF56J46A792040 . 87k miles, great price. Appears clean as a whistle. Would you be so kind as to tip me off as to whether I should run screaming from this car, or run to the dealer and pay cash today?
Any way to tell if the issue exists and was fixed under warranty? (VMI I've read it's called?)
Thanks guys!
Old Oct 4, 2013 | 09:58 PM
  #349
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBUF56J46A792040 has M272 engine #061793, which is in the range for potential balance shaft failure. My advice is, unless this one has already been repaired, pass on it. There are other cars out there (not MY2006, maybe MY2007) that will not be in range and will be as good. As for the VMI, only dealers can pull those, and most will not give them to customers, although they might look at it and tell you if it's had the balance shaft replaced.
Old Oct 4, 2013 | 10:01 PM
  #350
benzoolie's Avatar
e500
You are a gentleman and a scholar
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
