CEL on, P0128
Old Jan 26, 2013 | 11:33 AM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
CEL on, P0128
I did see a couple of threads on this (Clkboi's thread) but is it always a bad thermostat? Reading the list on Autozone's scanner tool, I thought I saw "coolant level," or was that just wishful thinking? BTW, this is for my wife's E350, not that I think it matters.....
Old Jan 26, 2013 | 02:38 PM
Yidney's Avatar
2008 CLK550 Cab
If it's the coolant level you can tell by looking at the coolant overflow tank.
Old Jan 26, 2013 | 03:07 PM
eddieo45's Avatar
It was only down a little, so I'm doubting that's it, but I topped it off anyway.
Old Jan 26, 2013 | 03:12 PM
togaclk55's Avatar
CLK55
http://www.obd-codes.com/p0128
Old Jan 26, 2013 | 05:13 PM
eddieo45's Avatar
Thanks toga; anybody have any thoughts as to the timing of this, deep-freeze temps and all?
Old Jan 28, 2013 | 01:50 AM
Clkboi's Avatar
CLS550 4Matic
Ah i remember that code. What is your engine temperature like? Mine stayed a line lower than usual
Clkboi's Avatar
CLS550 4Matic
Also mine was in the winter as well. Very cold when it happened i remember
Old Jan 28, 2013 | 11:11 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
P0128 = thermostat stuck open. It could be the cold weather, but it could be a stuck thermostat. If it takes more than a few minutes before you have heat in the cabin, then I would replace the thermostat.
Old Jan 28, 2013 | 01:50 PM
Glyn M Ruck's Avatar
Super Moderator
Yep! replace the thermostat. You don't want the car operating cold.
Old Jan 30, 2013 | 07:53 AM
eddieo45's Avatar
I note that my CLK runs about a line or two over 80°C, so I asked my wife to report her temp in her car, the E350 w/ CEL on: she says it never reached 80° during her 30-40 minute commute home. I guess replacing the thermostat is indicated, $106.80 on parts.com
Old Jan 30, 2013 | 10:51 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Yes, 85C is the target operating temperature. You can see it go as high as 100C on a very hot day, but by then, the electric fan should kick in. Some engines don't run well above 90C, so there is a setting (via SDS) to have the fan kick on at a lower temperature to help with this.
Old Feb 3, 2013 | 03:11 PM
eddieo45's Avatar
UPDATE: the CEL went off, but running temp still (just) below 80°....do I worry, or assume it's fine?
Old Feb 3, 2013 | 04:24 PM
Flame3g's Avatar
CLK500 SPORT
That's a hard one I would replace the thermostat any way or buy it and keep it handy. best of luck
Old Feb 25, 2014 | 01:59 PM
newamerican's Avatar
E350
what thermostat I have to choose for 2006 MB E350?
Manufacturer: WAHLER
Part Number: W0133-1953845
Description: Thermostat
Thermostat
Is this is wright one for this car?
Old Feb 25, 2014 | 02:28 PM
xsever's Avatar
2012 C300 4MATIC Sport
Thermostat
The MB part code is 272-200-04-15 and it is a WAHLER part.
Old Feb 25, 2014 | 03:53 PM
E350
Here is where I found parts and video:
http://www.fcpeuro.com/products/merc...-2722000415kit
