Seicane Head Unit for 2009 W209 Harmon Kardon
How was your experience?
Did they give you the right harnesses?
Did you run new wires to the trunk? How did you route them?
Install an amp or drive the speakers off the head unit?
Did you use an optical converter instead of new speaker wiring? How did it sound?
Did your steering wheel controls work or did you need a converter. How'd it work?
Did you figure out how to set the time on your dash clock?
Did you install a camera? wired or wireless? How'd they work?
Thanks in advance.
https://www.seicane.com/review/andro...usb-sd-s018812
I'm looking at this head unit as well...
Check out Car DVD Player GPS Radio Stereo HeadUnit for Mercedes Benz C/CLK-Class W203 W209 on eBay!
https://www.ebay.com/itm/39286745129...is&media=EMAIL
If you have the opportunity, maybe you could view this unit, and see in your opinion, how it compares to the Seicane Head Unit.
You - "Also added a fiber decoder to drive the Harmon Kardon amp. Worked really well and sounds the same as before. But the decoder they sent did not have the red wire (only had 2 wires) to tie into 12V Acc power and would not work. It needs a 12V signal that the ignition is on."
So where did you get the proper decoder from to save me some time? Also, I like my custom CDs, so I'll be keeping the changer, any information on what additional parts may be needed?
Unfortunately I am not mechanically inclined, and will have to pay to get it installed. I wish you were in the ATL area, I'd get you to show me how to do the install, to save some dough.
So happy you find the Seicane Head Unit acceptable and glad you got yours in, it helps narrow the field of choices.
Thx, again!
Do you happen to know how the OEM CD changer was powered? i'm wondering, if i put in the optical loop, I can use what previously powered the CD changer unit for something else (depending if it's always on, or like, how it's powered) --> thinking like rear camera or the optical decoder box thing to keep HK amp/sub and rear speakers (unsure if that's powered..)
1) did you ever figure out steering wheel controls/buttons?
2) i saw you tied "camera power wire into the back-up light power wire in the right rear. And to the R shifter light in the front to signal"; is this b/c of the wireless module needing power (at the back) and a trigger for the HU (in the front). if you went w/ wires, could you power camera all from the front (reverse shifter light), or perhaps that would draw too much power from something meant to power a light (so best only to signal to HU)? for the rear, seems like you used the reverse light (on the right hand side of car), was the video on youtube correct in terms of Pin/Wire #? If i remember correctly, it was #3 from the top? I can rewatch but if the video is correct, would save me a lot of time of not pulling out that entire light assembly.. since, by going wired, need to get to the front, i might do the camera power from 12v ACC and the trigger signal from the reverse trigger light..
3) which optical fiber decoder did ya go with?
Thank you!!
Thx, RE: cd changer power details! Maybe I can use this for rear camera power (for always on camera function)?!
For back up lights, did you get any issues/errors with voltage, etc by splicing back-up lights?
Why is ACC power cord on lighter better than CD power? And is there a different (independent ACC power) that's NOT the cigarette lighter?
THANK YOU
Lighter is located very close to the HU with direct access whereas the CD is in glove compartment. Your choice.
5 - spare relay 2
7 - back up relay 1
11 - spare
12 - power outlet (x58/27)
i'm guessing 5 and 7 are always on (as relay C - next to 5 = reserve and relay D - next to 7 = reserve), where as 11 and 12 are next to relay F and fuse 12 is already power outlet?? just learning how fuses work and idk what a relay is..
__PRESENT__PRESENT__PRESENT__PRESENT__PRESENT__PRE SENT__PRESENT
which HU did you go with? i was leaning towards Sony AX6000 but i just saw that the AX6050 recently came out; it doesnt look available in US though so not sure if it's Europe only or something..
based on this thread, it looks like can just do ACC or any 12v power to camera, and the HU reverse trigger line to the shifter reverse? idk i'm still digging..
__PRESENT
for Steering controls, i was probably going to go with Axxess but not sure if compatible.. can manually program w/ different HUs
Portable Options (No installation required, truly plug and play): https://www.carputech.com/collections/carplay-screens
