CLK RATTLE
Mercedes CLK
CLK RATTLE
Hi everyone, so I’ve had this constant rattle issue for the past few months and I just can’t seem to find the culprit, as the car picks up speed the rattle gets louder, in trying to fix the rattle I’ve spent a ton of money trying to get rid of the rattle, however the issue continues and the unbearable rattle. The following parts have been replaced which were recommended by different mechanics, it’s been to Mercedes specialist and they can’t seem to find anything.
- Disc’s+Pads
- wheel Bearings
- Inner Tie Rods
- Track Rods
- Water Pump+Thermostat
Coupe or Cabriolet? Is it an interior rattle? Is the rattle plastic? Metallic sound? Any chance you can make another video so we can try to narrow it down.
Gas or diesel?
How old is the belts?
Gas or diesel?
- Disc’s+Pads
- wheel Bearings
- Inner Tie Rods
- Track Rods
Sounds silly but does it still do it if you turn off the interior fan? Or even try pulling the engine fan fuse.
Mercedes CLK
Mercedes CLK
This started all of a sudden like two months ago when I started the car in the morning and took off it hadn’t done that previously. It sounds like it’s hitting something or catching onto something.
Mercedes CLK
Sounds a tiny bit similar to the spokes of a bike spinning or a turbine spinning and has caught onto something.Still rattles if I turn the interior fan off, it probably will cause disco lights to flash up on the dash if I were to take the engine fan fuse. But I’ll definitely look into the fan as I haven’t really paid any attention to that.
Mercedes CLK
Mine's a pre-facelift W209 but the fuse is in the box under the bonnet on the right hand side (left hand side as you're looking at the engine). Opposite side to the battery. On mine I remove the piece of cover trim and then unclip the lid of the fuse box.
Inside the car on the driver's side at the end of the dash there's a removeable piece of trim that covers more fuses. Tucked in there should be a folded paper fuse location diagram.
