tire question
Old Feb 26, 2010 | 05:47 AM
arashsheikhpoor's Avatar
2002 CLK55
tire question
If you have old tires, Or bad shocks (and also the front ones and back ones are different brands) will it degrade your ride quality greatly? Because at this point I have changed Lower control arm bushings, drag link assembly, motor mounts, and ball joints...And I can still feel every crack on the road...I'm just out of ideas and don't know how I can fix my car( I've had 2 different mechanics tell me that my suspension is perfect)
Any help would be greatly appreciated
Old Feb 26, 2010 | 09:55 AM
BeltFedBob's Avatar
From: Lynnwood in summer, Fountain Hills during the rainy season in Wa.
2008 Maserati QP EGT, 2005 SL55AMG , 2002 CLK55AMG 2002 C230K Coupe
Yup and yup. Worn tires and shocks will "degrade ride quality". That being said the CLK55 does have rather stiff suspension stock, my wife says my CLK55 rides like her Mini ;-)
Old Feb 26, 2010 | 08:02 PM
Chappy's Avatar
AMG
Talking
Check the steering damper...replace if necessary.
Old Feb 28, 2010 | 06:12 AM
2002 CLK55
steering damper was already replaced
Old Mar 1, 2010 | 06:54 AM
Chappy's Avatar
AMG
What is your wheel/tire setup?
Has the car ever been wrecked?
Old Mar 1, 2010 | 09:04 PM
2002 CLK55
I have the oem clk55 wheels...225-45-17 in the front and 245-40-17 in the rear, and no, the car has not been in a crash
Old Mar 1, 2010 | 09:56 PM
RRnelcheeze's Avatar
CLS55
I had old tires on my W210, i suspected the shocks. MB said shocks were fine. I got new tires and she rides like a dream again.
Old Mar 2, 2010 | 12:31 AM
MarcusF's Avatar
2002 CLK430
As others have said, old tires will degrade the ride. The way you wrote your post, it appears that you have different brands of shocks, front and rear. If that's the case, unless they are the stiffest shocks known to man, it won’t matter. However, if you’re stating you have different tire brands, that is going to make a very big difference. Especially if they’re worn. TRIPLE especially true if one pair of tires is known for tramlining (cough cough Yokohama cough). When you write "feeling every crack in the road", do you mean you feel it in the steering wheel (tramlining), or through your seat (rough riding)? Also, what tire brand(s) are you running?
Old Mar 2, 2010 | 06:55 AM
Chappy's Avatar
AMG
The MB-spec Michelin PS2s are the best tires I've ever had on my CLK55.
Old Mar 3, 2010 | 02:35 AM
2002 CLK55
thanks for the responses....I had bought a set of used blistein hd's from my friend and had been using those...But i'm having the mechanic put my old ones back on( I think they have about 35-40k on them) as for the tires, they have been replaced with falken tires all around, but unfortunately the mechanic put the wrong size tires on ( It said 215-45-17 on the door for the gas, So he put those all around on staggered wheels) I had him order new tires for the back, I'm going to leave the front with the 215's and change the back to 245's...is that okay?
and finally, I feel it through the seat, not just the steering wheel...
Again thanks for the help.
Old Mar 3, 2010 | 02:37 AM
2002 CLK55
I agree with you 100% ...unfortunately I'm in college and can't really afford those
