K & N vs Green vs BMC
Everywhere I look I get another opinion - I know that they only give a tiny bit more BHP - was looking to get a few more MPG out as I run mostly in town and nicer sounds??
Green: Possible the frame deforms due to heat and lets in all that nice dirt
BMC: dunno, not enough user feedback
REally doesn't matter, alot of ppl will also swear by paper filters. Not worth the dmg to your engine for the 1 hp add.
Im just repeating what i've read. I use green filters myself. If your unsure stay with paper, cleaning aftermarket filters is a chore, popping in a new paper filter is soooo easy and cheap.
but u cant re oil or u will kill your maf
paper if buy new with every oil change
green will melt
bmc i have only seen good from them
but i have a true cold air set up and love it all he way
Can anyone point me towards the sticky or "how to" to remove them - sorry I know its a pretty basic one but these are not cars you need to experiment on and I would rather get it right first time!!!
Did I see it on the 208 Section?????
Simple - pull the front air/snorkels out - Pull off main cover - sort of two bits - the front section clips into the first - not very heavy just tricky to pull upwards and out
11 x 25 torx screws and the back comes open - bit like a crab shell - Big AMG filters very deep and quite clean as the were replaced only 3000 miles ago but underneath quite a bit of small leaves/dust crud.
AMG filters very thick ish 1 1/2" and K and N's much thinner maybe 1/2" much less oily/waxy than I remember them being when I have replaced on previous cars (no more MAF filter queries then)
Good fit - nice and tight
) Sounds - got a bit more growl and deeper rumble
Any better - seems a bit more grunt but almost smoother (possible placebo effect???) - can't see how it would produce less bhp - worth the money probably not but what the hell else was I going to do before going back to work
I clean them every year and follow the instructions properly when oiling them.
Stay away from the green filters !!!! I used them before the K&N for about 3 months until their moulding deteriorated and thankfully got caught by a mesh on the intake. These green filters are the worse enemy for your engine.
I have read comments about the BMC filters having the same issue with the foam moulding falling apart and I will not take a chance with these since I compared them with the green filters and noticed that the moulding material is basically the same just with different color.
