I NEED WHEEL HELP!
My local tire shop advised that I use HUB CENTRIC spacers. He did not have enough time to take measurements so I need help
. I have seen 10mm, 12mm, and 15mm spacers. Which ones would you guys recommend?Thank you.
On the back of your wheels you will find an offset. This is a number somewhere between say 25 and 50 or so. It will show as ETXX (XX being a number). Where you want to be with your car is probably around the ET30-35 for good fitment and good looks without rubbing(anyone feel free to correct me). So if your wheels say for example ET45, you need to add 10mm (per wheel) spacers to get to ET35 and 15mm to get to ET30. Easy?
ALWAYS go hubcentric, in our country its even illegal to have the ones that aren't for many reasons.
To get an idea of how far your wheels would come out with different sizes and ET values, check this thead:
https://mbworld.org/forums/clk-class...nt-thread.html
hope this helps.
Welcome on the forum btw... got some pics of ur car?
The only thing that concerned me is the center bore. I am pretty sure the hub on an AMG is slightly different. Do you guys think that this spacer will fit my car?
I will take pictures tomorrow morning of the current setup and the wheels that I plan on putting on. Hopefully this will help somebody else in the future.
Good thing u got some AMG wheels, that will really transform the car. I have the OEM's as well but I'm changing them to bigger wheels as you can see in my new thread in the w209 AMG section.I hope everything will work out well for you and that you become a valued member here that we can learn from!
(THESE ARE THE WHEELS I PLAN ON PUTTING ON
(THAT IS THE SPACER THAT THE DEALER PUT ON THE FRONT. I AM PRETTY SURE THAT THE SPACER IS THE TROUBLEMAKER.
So what I did was take the spacers and put them on the rims currently on the car. They fit perfectly and guess what? The shaking is finally gone
. I knew the car was shaking from those cheap spacers. Ill snap some pictures tomorrow to show you guys what I mean. Hopefully this will help the next guy.Why do you guys think that those AMG rims would not fit? Maybe I am running the wrong tires?
Sorry guys but when I it comes to tire sizes and offsets I am still learning. Please be patient with me.
