CLS digital cluster
From what i know, replacing the cluster is not plug and play. MB knows how to make it pretty complicated. Usually the part is programmed to VIN, so a replacement unit might need to be coded with SDS (Star Diagnostic System / STAR - you name it).
I said that you do not need to buy NEW clusters to swap yours, you can buy USED clusters and I can make them VIRGIN and ADAPT to your cars by remote
now on retrofit, some cases need JUST programming, some need PROGRAMMING & SPECIAL ADAPTER HARNESS
for every case I need a request + vin
needs renewing of used cluster and head unit and coding but also a $2000 adapter harness
so for your car I suggest you find out if someone did this before and what year/model cluster it was
then we can lookup, and verify if a special harness is required
but for sure we can code & renew it for you
send a message there
