AMG GTS differential leak
Mercedes amg gts
Hello I was wondering if anyone knew if this is a recall on my Mercedes amg gts or if anyone has had a similar problem or knows how to fix it . It’s leaks small drops from the differential. If anyone has any recommendations or ideas . Thank you [img]blob:https://mbworld.org/84beda5b-3f6d-4fc3-8bc6-cb4ae0971eed
2022 AMG SL63
Hello I was wondering if anyone knew if this is a recall on my Mercedes amg gts or if anyone has had a similar problem or knows how to fix it . It’s leaks small drops from the differential. If anyone has any recommendations or ideas . Thank you [img]blob:https://mbworld.org/84beda5b-3f6d-4f...6-cb4ae0971eed
Mercedes amg gts
The following 2 users liked this post by 300blackout:
sno (11-05-2018),
thebishman (11-04-2018)
Sorry for the miss, blew right past it viewing from phone. Hopefully that helps the OP.
OP-call dealer and mention your concern, give them you VIN, and they can easily look up if this bulletin applies to your car. If not, get it in anyway to find the source of leak!
If you post your VIN I can tell you if your car applies.
I have replaced one for a leak due to that bulletin. Not really a big deal, but since dealers aren't yet allowed to service those Getrag units in house, we get a whole new/reman one to put in and ship the old one back to be repaired by Getrag eventually.
Philippe Rizk (07-27-2020)
Are the replacement units factory new or are they actually refurbished units at this early age? Are there even furbished units available being that this is such a new model?
I'm sure they aren't listed as remanufactured but if they are being sent back for a leaking seal, I highly doubt Getrag is throwing them in the garbage. The same models are used in multiple vehicles, and it has been around since the SLS so it's not really "new"
300blackout (11-09-2018)
‘24 BMW iX M60
ItalianJoe has already made it know that if you need a replc4ment DCT it will be either new, or remanufactured:
Its not only a seal problem, its a hardware problem. First 733 GT are afected.
Yed SLS have the same gearbox and Ferrari 458, 488 Ferrari FF and other models. But many parts inside changes over the years.
Interesting. I complained about a hypoid oil smell from the rear fenders ever since I bought the car. During the last service call I had them check it. My master technician went as far as removing the transaxle to see if any seals were leaking. I do not see any physical leaks. But it is worth taking another look next time (or myself for that matter).
Ford GT uses same gearbox as Mercedes-AMG GT; costs double
https://uk.motor1.com/news/275870/fo...mg-gt-gearbox/
The following 2 users liked this post by AMG 17GT:
300blackout (11-11-2018),
ean (11-12-2018)
Oil leak detected from the transmission for a 2015 AMG GYS
This is a Lebanese car, this is why it is in Arabic, the chassis number starts with WDDY..
S99pharb (01-07-2021)
Oil leak detected from the transmission for a 2015 AMG GTS
Good morning. I have the same issue it seems, Oil leak detected from the transmission for a 2015 AMG GTS. My mechanic says he need to open the gearbox and replace the seal and other recommended to replace the crankshaft seal since the gearbox seals are rarely damage! Any assistance is appreciated
AMG GTS gearbox
AMG GTS gearbox
PierreJose (05-26-2021)
I Hope you're safe im having the same problem
WDDYJ7HA2GA003787
This is the vin number can you please check it for me
thank you so much
