Help AMG GTS leak in boot
i hope someone can help
i have started getting a lot of water into the boot of my gts, I’ve take all the plastic trim out and I’m suspecting that the middle drain under the spoiler has got a split in the pipe or is disconnected however I cannot for the life of me figure out how to get access to all the drain pipes seem to be behind the moulded boot metal
does anyone have any suggestions or experienced this in the past at all
thanks for your help
if not send me your number and i will contact you through whatsapp to help
i had similar problem
i managed to take the boot insides apart and removed the spoiler ERC and indeed the rubber seals in the spoiler have deteriorated.
fortunately I managed to get Mercedes to replace it under warranty.
thanks again for coming back to me though much appreciated
2: your car insurance should total the car for you IF you cannot force MB UK to step up and admit the manufacturer was at fault. There is no way this should happen to a brand new car regardless of how long it was left out in the rain!
My friend’s Porsche Boxster had blocked drainage channels and was only 1 year old. Water completely flooded the interior and did major damage. It was not covered under warranty by Porsche.
https://mbworld.org/forums/coupe-roa...ml#post8275051
All the Best,
Acta
