MB bluetec lawsuit in USA
But the settlement has a provision for extending Oct deadline.
Thanks for advice!
Put a piece of cardboard underneath to protect the garage floor. The snapshot is on Day 4.
Thanks for advice!
I had similar dilemma, when I had air bag code reset by my friend in his shop. When I left his shop and made U-turn on highway, the CEL come on and engine went into safe mode, what I did not notice right away as it was still giving about 80% of the power.
I drove it home and only there, having scanner I check that MAF gave up at that very moment. Did I say that sometimes **** happens?
Spending $2000 on radiator without pinpointing the leak makes not much sense to me. Can very easy be water pump.
If you plan to visit dealer and come back with estimate below $8000, you better change the brand.
Here is the video I received from dealer:https://youtu.be/-RZ5zJ70Y24
Correct?
If I was told so, and see the evidence of the leak. I will ask the dealer: is the coolant level down? And can this related to the oil cooler seal?
If the coolant level is normal, then the leak is truly minor.
I will reject the dealer's suggestions to replace the radiator. And stop by an auto parts store to buy something from Lucas to stop coolant leaks.
If the coolant level is very low, I will ask whether there is a deep discount. If not, ask an independent shop to do it. Should be at least 30% cheaper.
Correct?
What do you mean by "buy something from Lucas to stop coolant leaks"?
Single fill for mpg calculation is inadequate as small, not visible to human eye tilt of pump pad will leave air bubble.
Also there are lot of factors that affect mpg, where biggest is the speed and air speed.
When I drive Sprinter, I always set CC to the same speed, yet calculated mpg comes with up to 20% variations. That is due to heavy winds I often have on deserts.
You reported DEF system work, who is emission system, having no effect on engine work.
Since AEM:
Jan 22 - Replaced Timing Belt - covered by AEM
Jan 22 - Replaced Low Pressure Fuel Hose - not covered
May 22 - Replaced clean air line \ mass air sensor - did work myself since I assumed it was not covered since not listed in covered components
Aug 22 - Replaced EGR - covered by AEM
Sep 22 - Replaced Right Charge Air Intake Hose. Covered by AEM (I was surprised this was covered since not specifically mentioned in covered components list)
This was interesting because it was giving me a Mass Air Sensor error code and behavior was similar to sensor failure (but worse) - no acceleration, would not shift. Acted like Limp Mode. I took it in because that was the only way I could have gotten warranty coverage on the Air Intake line I purchased in last May.
Love the car - but it is in the shop quite a bit since purchased! AEM warranty has been a godsend. Also - my local MB dealer service dept has been great and diesel mechanic seems quite knowledgeable.
Marty - Walnut Creek, CA
Since AEM:
Since AEM:
What do you smoke Marty?
I know those dealers. MB of WC used to be good, but still diesels are not that common in the area.
MB of Oakland per my experience is much better with diesels.
So far I have no complaints on diesel service. I suspect it depends on the mechanic they have in house at the time.
-Marty
Many people are quick to think that mercedes pulled the same s*** VW did by purposely cheating the tests with defeat devices and deceiving the public, which is not true. Mercedes vehicles for the most part, met emissions requirements and only turned off the emissions system in cold temperatures, like gas cars as you mentioned! If I’m not mistaken, the EPA actually never found any defeat devices with similar purpose as VW’s.
It is my opinion that when people saw the success of the VW scandal and the lawsuits, they jumped all over it with Mercedes for the cold temperature shut off. With this logic we should recall most gas cars!
Mercedes-Benz USA, LLC Clean Air Act Civil Settlement
(Washington, DC) – The Department of Justice, the Environmental Protection Agency (EPA), and the California Air Resources Board (CARB) have resolved a civil enforcement case against Daimler AG and It's, they installed cheat software.Mercedes-Benz USA, LLC (collectively, “Daimler”). This settlement, filed on September 14, 2020 and entered by the Court on March 9, 2021 (the “Effective Date” of the agreement), resolves violations of the Clean Air Act and California law based on Daimler’s cheating on emission tests and failing to disclose unlawful defeat devices in approximately 250,000 diesel vehicles sold or leased in the United States.
Source: https://www.epa.gov/enforcement/daim...vil-settlement
Meaning whatever MB was accused for, it was not proven.
MB per my understanding admitted that his advertisement promised more, than vehicles deliver and that is why it is paying.
If somebody have seen any proof that MB did cheat on EPA, I would like to see actual numbers quoted?
considering my om651 got 44.5 mpg over 560miles commuting this week and in 2014 gas passenger vehicles many of them getting 22mph straight highway via the vs test makes no sense to me.
MB does not admit fault. They fight every lawsuit with their every being. MB is either forced into action or they settle if they feel it will be cheaper than the alternative. If these lawsuits did not have merit, they would not settle. They are a global corporation to make money - I get it.
