Oil level check
Old May 10, 2013 | 07:32 PM
dudley07726's Avatar
2023 BMW M340i, 2025 MB CLE53 AMG
Oil level check
I have a 2013 E350 Cab. There's no dipstick.
My manual shows a dipstick. How do you check the level?
Old May 10, 2013 | 10:28 PM
Cavu's Avatar
Current: 2019 M5 Donnington Gray, 2021 GLE53 Diamond White Met. Previous: 2010 C63, 2012 E550 Coupe
There is definitely a dipstick. It might be in another location than showed in the manual.
Look for the red thing. Mine (E 5550) is near the back of the engine.
Old May 10, 2013 | 11:25 PM
gavrocool's Avatar
e350 coupe
Back of the engine,left side.
Old May 11, 2013 | 06:15 AM
Do not see it. My BMW X3 does not have a dip stick. It's electronically measured through the IDrive system.
Attached Thumbnails Oil level check-001.jpg   Oil level check-002.jpg   Oil level check-003.jpg
Old May 12, 2013 | 12:48 AM
Hk91308's Avatar
04' CLK, 09 997.2 GTS, 22 992 C4S
I have a 13' e350 coupe and it does have a dipstick- if you are facing the engine from the front og the car it's to the right of the engine.
Old May 12, 2013 | 07:42 AM
Found it! Thanks. Stupid manual has it on the left and the handle of the stick in color as well. I'm looking for this bright colored handle on the left side of the engine when it's a grey colored handle that blends in with everything else on the right side of the engine.
Old May 12, 2013 | 11:40 AM
Hk91308's Avatar
Yeah, it's quite annoying when the manual is not correct even on simplest things as this.
On another topic- does your backup camera have parking guidelines on the screen?
There's been discussions here about them being on some e coupe cars and others don't have it....mine doesn't have them and its annoying trying to figure out what the car suppose to have, dealer has been no help.
Old May 12, 2013 | 12:47 PM
No, it does not have parking guidelines. Does your passenger side mirror tilt down when you reverse?
Old May 12, 2013 | 01:12 PM
Hk91308's Avatar
Thank you on the parking guidelines, feel better now I'm not the only one with a 2013 and his topic.
My passenger mirror Does tilt when on reverse. Just make sure you have the side mirror adjustment button set to passenger side- it will not tilt down if the setting is put onto the drivers side and in the middle position on other german cars FYI .
Let me know if it works out for you..
Old May 13, 2013 | 06:04 AM
I set it up but did not try it yet. I was confusing the digital manual with the
Command digital manual and could not find the info. Then I realized there were 2 digital manuals. I hate having to read it on the computer. I want them printed in front of me.
Old May 13, 2013 | 01:58 PM
I have now programed the mirror to tilt on reverse and it does it just fine.
They sure make it complicated. Just have it tilting from the factory.
Old Jun 25, 2013 | 04:07 PM
C230Brit's Avatar
2010 E550 Coupe
Hi,
Is there a digital way of checking the oil level? My old 2003 C-Coupe could do this with the key in the ignition...
Thanks,
Richard
Old Jun 26, 2013 | 12:25 PM
C230Brit's Avatar
2010 E550 Coupe
Having searched back in the C-Class forum, I recall now that the oil check was accessed through the Dyno Mode, which so far, I believe is not available on (at least) the C207...
Has anyone been able to get a digital oil level read out?
Old Jun 26, 2013 | 04:39 PM
C230Brit's Avatar
2010 E550 Coupe
answered here:
https://mbworld.org/forums/e-class-w...vel-check.html
